Disadvantages of JIT (Just In Time) and Impacts on Costs
#11
and really JIT is a misnomer - or a misinterpretation of the Toyota Production System. (And Ford's use of it early in the last century)
JIT is one small aspect of TPS - and is actually not so much a tool as a result of TPS. In fact those who implement JIT directly are doomed to fail.
Also important to understand - as Ralph has pointed out - is that Toyota and Honda both 'hold' inventory at suppliers locations depending on the material and the supplier. They also carry some levels of safety stock.
TPS/Lean is a journey, not a destination
V
vanputten
#12
JIT must be done with an overall systems view. JIT is inter-related and interconnected to so many process, departments, suppliers, customers, etc. It must be done with the entire system in mind with top management willing to look at the entire business system. If not, you will suboptimize inventories, ordering systems, level scheduling, etc. Suboptimization will result in Just In Case inventories somewhere inthe supply chain.
JIT is a systems concept that affects suppliers, the organization and customers. It is a system wide venture.
Regards,
Dirk
sspoldir
#13
If you carry 10 million in inventory and reduced it by %10 (or whatever number)... thats 1M cash in the businesses pocket.
I don't know if anyone has really mentioned it but inventory costs money to have. When you have large amounts it takes capital to warehouse, it get's in the way and suffers from damage, obscolescence... etc.
JIT manufacturing has been around for many many years, it allows a company to keep the bare minimum of stock at their own plant to keep how much money they have sitting on the shelves as low as possible which is supposedly makes a company save money.
Dimitri
Dimitri
#14
Yes but just because you have it in your pocket doesn't make the company richer, since the company will NEED to buy that 1 million dollars worth of Inventory anyways no ?? :confused:
Dimitri
sspoldir
#15
Just In Case, lol. Unfortunately what happens in businesses that are not enlightened is having too much inventory is a slap on the wrist whereas running out of inventory gets your head chopped off, thus the JIC.
...Suboptimization will result in Just In Case inventories somewhere inthe supply chain.
Dirk
sspoldir
#16
If it was once operating with 10M, then reduced it to 9M and retained the same service level (ie it didn't effect customer lead times, shortages, etc). That freed up money can go to something else (like the owners bonus).
Richer depends on your defintion of inventory, unfortunately your accountant is going to tell you inventory is an asset. Cost accounting is old school, your machine running 24/7 (unless they are all being bought up right away) is not like printing cash if the stuff sits on a shelf for weeks and months.
Dimitri
Dimitri
#17
Yes but if your operating with 10M in inventory and it cycles every 20 days lets say, that means by cutting it down to 9M in inventory, all you've really done is made the bill slightly smaller, but since the inventory cycles from 20 days per "check sent out" till you need to get more stores to repeat the process all over again will now be every 18 days no ?? Which means the same 10M is going out every 20 days regardless of the amount of inventory on hand. :confused:
I don't see how the company makes that million dollars just by cutting it NOW in inventory when it will have to be there LATER. :confused:
Dimitri
sspoldir
#18
Let's break it down in a simplified example... You have three stacks of widgets, each stack is one weeks worth of inventory for that product.
You sell off two stacks and only replenish one of them. Now you have two weeks worth of inventory. If you sell one of the two stacks you replenish it, of course that replenishment needs to occur within a week (thats why you work in reducing lead times by working with your suppliers and/or manufacturing processes).
Previously you operated with 3 weeks worth of widget inventory and now your down to 2. Provided it doesn't cut into fill rates or increase lead time to your customer (if it does you need to tackle the reasons why) you now operate with less inventory. Wash, rinse and repeat. There isn't a "now" you have to sell that inventory off, you simply don't replenish the excess.
Dimitri
#19
I still don't understand how that saves a company money though, since your going through the same amount of inventory anyways. :confused:
Only way I can see it saving money is if the buying company goes under and you end up with inventory you cant sell so it minimizes your losses. :confused:
Dimitri
#20
read Jeffrey Liker's series on The Toyota Way. TPS/Lean is counterintuitive to traditional manufacturing techniques...plus search this site there are other threads that cover this...
JIT is a RESULT of implementing TPS/Lean not something you do.
carrying costs of inventory are real.
plus the costs if you need to purchase extra space or heat and illuminate extra space you could close off)
opportunity cost of paying for stuff and transporting it before you need it are real - ask your finance guy what 'float' is)
revision changes to existing inventory are real (yes we solve problems then have to rework inventory so it won't fail too...)
hidden defects within that mound of inventory are real and large and when you find them will be when you can least afford it.
moving that inventory around to make room for all of the other inventory you need to store can and will cause handlign damage, you will lose it adn that takes time to find it - which is headcount...
there's more but if you are truly intrigued Liker's books will help. or google "thd seven wastes" and "the eight wastes"
E Just in Time Problems - Disadvantages of JIT (Just in Time) model? Lean in Manufacturing and Service Industries 7
S Advantages and disadvantages on IATF corporate scheme IATF 16949 - Automotive Quality Systems Standard 2
F ISO 22000 Disadvantages - Student Exam Question Food Safety - ISO 22000, HACCP (21 CFR 120) 4
S Bridge vs. Portable CMM - Advantages and Disadvantages General Measurement Device and Calibration Topics 4
H Advantages and Disadvantages (costs) of Process FMEA FMEA and Control Plans 9
J Lean Six Sigma - Advantages and disadvantages Six Sigma 3
T Standardised audit programme, advantages and disadvantages General Auditing Discussions 5
Marc RAB vs. IRCA Certifications - Advantages and disadvantages of Lead Auditor status ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 2
D When you're not Lean enough for JIT (Just In Time) Lean in Manufacturing and Service Industries 9
T Problematic Packaging Supplier - Control of WIP and Planning (JIT) Supplier Quality Assurance and other Supplier Issues 2
Marc JIT (Just In Time) Manufacturing - A simple powerpoint .ppt presentation General Information Resources 3
K How JIT (Just In Time) fits in with ISO 9000 and QS-9000 Quality Systems ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
S Medical Device Changes and How to Assess Their Impacts to Essential Requirements EU Medical Device Regulations 2
A ISO 13485:2016 - Validate our use of software that impacts on the QMS ISO 13485:2016 - Medical Device Quality Management Systems 8
B ISO 14001:2015 Aspects and Impacts: Haze occurrence (Supplier related) ISO 14001:2015 Specific Discussions 3
somashekar Industry examples of Significant Beneficial Environmental Impacts Miscellaneous Environmental Standards and EMS Related Discussions 3
x-files [QMS] Identification and Evaluation of Aspects, Impacts and Risks... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
G Positive Impacts in regards to ISO 14001 Quality Manager and Management Related Issues 4
I Feedback on an Environmental Aspects and Impacts Register Miscellaneous Environmental Standards and EMS Related Discussions 5
Sidney Vianna ISO 14006 - New Standard to Reduce Environmental Impacts of Products and Services Miscellaneous Environmental Standards and EMS Related Discussions 1
S Natural Gas Power Plant - Aspects & Impacts Miscellaneous Environmental Standards and EMS Related Discussions 8
K Environmental Aspects and Impacts of a Welding Process (ISO 14001) ISO 14001:2015 Specific Discussions 5
P Environmental Aspects and Impacts while doing Software Development ISO 14001:2015 Specific Discussions 6
S Static Significant Environmental Aspects (ISO 14001 Aspects and Impacts) ISO 14001:2015 Specific Discussions 5
K Establishing the Environmental Aspects and Impacts for a Septic Tank Miscellaneous Environmental Standards and EMS Related Discussions 5
A Environmental Aspects & Impacts Matrix Template Miscellaneous Environmental Standards and EMS Related Discussions 1
A Identification of Environmental Aspects and Impacts - Aspect and Impact Study ISO 14001:2015 Specific Discussions 18
R Impacts on the Quality Manual due to changes in Top Management ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N Envelope Manufacturing Environmental Aspects & Impacts Analysis ISO 14001:2015 Specific Discussions 8
Sidney Vianna ISO Guide 64 will help reduce environmental impacts of products Other ISO and International Standards and European Regulations 1
A Environmental Aspects and Impacts - Duration & detection factors ISO 14001:2015 Specific Discussions 6
P New Process, New Equipment Aspects and Impacts Environmental Evaluation Miscellaneous Environmental Standards and EMS Related Discussions 1
A CB auditor questioning procedure for Identification of Aspects and Impacts? ISO 14001:2015 Specific Discussions 33
H Chemical Release Quantity - Environment Aspects & Impacts Miscellaneous Environmental Standards and EMS Related Discussions 1
A Environmental Impacts for Engineering Activities and Related Technical Consultancy Miscellaneous Environmental Standards and EMS Related Discussions 25
L Aspects & Impacts - Adhesives and Chemicals Stored in Nonflammable Safety Cabinets Miscellaneous Environmental Standards and EMS Related Discussions 25
L Do we need to have a Significant Aspect? ISO 14001 Aspects and Impacts ISO 14001:2015 Specific Discussions 4
M Automotive Mechanical Workshop Aspects and Impacts - ISO14001 Miscellaneous Environmental Standards and EMS Related Discussions 6
T Aspects Impacts associated with the company's products - Nonconformance Miscellaneous Environmental Standards and EMS Related Discussions 8
I Significant Aspects and Impacts for Manufacturing of Pharmaceutical Products Miscellaneous Environmental Standards and EMS Related Discussions 3
S Painting on Floor of Machine Shop - What Aspects/Impacts and Hazards to consider? Miscellaneous Environmental Standards and EMS Related Discussions 10
D CNC Machining Lathe Process Aspects & Impacts Miscellaneous Environmental Standards and EMS Related Discussions 3
Q How to Identify and Evaluate Environmental Aspects and Impacts ISO 14001:2015 Specific Discussions 185
J ISO 14001 Clause 3.4: Environmental Impacts - What is the definition of an 'Impact'? ISO 14001:2015 Specific Discussions 10
W Developing ISO 14001 Aspects and Impacts List - Seeking Help ISO 14001:2015 Specific Discussions 4
D Integrating the FMEA Process to address identification of Aspects and Impacts Miscellaneous Environmental Standards and EMS Related Discussions 5
Q Aspects and Impacts Master List - ISO 14001 ISO 14001:2015 Specific Discussions 44
S Identifying Aspects & Impacts on Control Plan Miscellaneous Environmental Standards and EMS Related Discussions 3
J ISO 14001 - Identify Environmental Aspects and Impacts ISO 14001:2015 Specific Discussions 36
