Document Control - Simple definition of when to control a document
Rob Nix
#11
Wow.
Poor little_cee wanted a "simple definition". All of the preceding is great, but I will attempt something very simple: Whenever a document is necessary for future use or reference, it should be controlled.
Perhaps too simple.
Likes: db
RoxaneB
#12
Thanks for getting us back on track!
Perhaps too simple.
For me it is simple as well....anywhere where the absence of the correct and up-to-date document can adversely impact your impact to meet requirements requires a document to be controlled.
Thinking about the future process is a bit to ambiguous for me. I mean, I know how I'd like to do Internal Audits, but for now, I document the current process. And reference documentation, well, I don't mind it being labelled as Reference, but to control it? I think that might be overkill where I work...but maybe not at another organization.
Make ISO work for you...you don't work for ISO. :)
L
little__cee
#13
Thanks thanks and thanks
All of this is great stuff and much appreciated.
Oh, and thanks! :thanks:
amr1234
#14
More Controlled Document Questions
Our Human Resources manager has inquiredabout, among other items, the Corporate REDACTED Harrassment Policy not being a controlled document. Should it be?
Human Resources Questions: "In addition, we purchase the forklift forms and there is no way of adding a form number to them without incurring cost. Are we supposed to incur these additional costs to satisfy ISO/TS?"
"I find it hard to believe that ISO/TS is intended to add cost by requiring us to contact a safety firm that provides forklift inspection forms and tell them to specially change the printing of the forms for us. Also, if attendance policy needs a date and document number doesn't everything else we have posted?"
:confused: :frust:
L
little__cee
#15
Hmmm
Using Rob Nix's definition above, I'd say yes that the harassment policy should be a controlled document. BUT I am not an HR expert and it is possible that some other governing body (federal regulations, etc) would control the updating and revisions to this unless your company created it.
I know here we had discussions about the Functional Organizational Chart being a controlled document and finally decided that yes it is. I am not sure if it is ever used or referenced but theoretically it could be so yes we went ahead and controlled it, erring on the side of caution.
Randy Stewart
#16
Arm1234,
Set up or change your system to allow departments to control their own policies/procedures.
Question: Do you control owner manuals for any equipment? I would assign that to the maintenance department.
All H.R. Policies, employee handbooks, etc. can be controlled in that department. I have never had a problem passing an audit applying that philosophy.
Wes Bucey
#17
:confused: :frust:
Good suggestions from Covers.
My take:
HR forms are not necessarily part of Quality Management System unless an organization says they are. If yes, then control. If no, no.
Re: fork lift
It is completely acceptable (definitely done in Federal Aviation Administration regulated situations all the time with part drawings) to formally "adopt" another organization's document or form as one of yours.
(Adopting means going through the same approval process as if you had created the document from scratch, with one minor difference - you can't modify the document, only adopt new modifications from the original authoring organization.)
If the numbering system is critical in your organization, add a cover sheet with your numbering system. When organization which is the author of the adopted document revises, your organization adopts the new revision. Once adopted, the document is controlled exactly as if your own organization had created it.
It is never necessary to have the author organization create a special number or form for your organization.
Minor note about unnecessary revision of an "adopted" document:
If you have adopted a "form" from some other organization, it is not necessary to update it when the authoring organization updates unless the update is necessary to your operation. (Think inspection checklist for Forklift Model 2b. Author update includes Models 2c and 2d. If you don't have those Model c & d forklifts, no reason to update (revise) checklist.)
James Gutherson
#18
:confused: :frust:
I agree with a lot of what has been said, however I would add that the issue of Document Control in itself should not be tied just to Quality Management.
I would suggest that it is a *VERY* good idea to ensure that the version of the REDACTED Harrasement Policy that is being used (floating around) is the correct one, and this is the definition of document control.
As long as there is some way of determining the version of the document, and a review and approval history, and a distribution method that ensures obsolete documents are not used, then the document is controlled. Whether this is done by the HR department, or by routing it through a central document control area (to add little numbers) is up to the organisation.
(We do it here by adding an approval date to the footer of the document to identify the version, and by distributing it over the company intranet)
As far as controlling external documents, all you need to do is ensure that you are using the correct version. There are many way of doing this. The document might be posted on the Internet and printed on an as needed basis, in say monthly batches (depending on how often the document changes), or you might decide to have someone responsible for periodically contacting the company to check whether the versions you have on site are the appropriate ones.
The larger issue might be how you refer to these documents in your internal procedures. If you refer to the exact document version, then you will need to make changes to your internal documents *every* time the external document changes. (if this were the case I would look at rewording your internal procedures to be a bit more flexible, ie refer to the 'latest version of the Forklift form, rather than 'forklift form ABC123 R12'. You would then of course need to follow the results to ensure that Non conformaties to not rise because of these changes).
Hope I haven't confused things, just remeber document control is not just for 'Quality Systems'.
K Simple ISO 9001 Compliant Document Control Quality Manager and Management Related Issues 24
R A simple electronic (software) document control question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Simple Document Control Database - Has anyone created their own simple database? Document Control Systems, Procedures, Forms and Templates 23
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
E Document Control MS Access Database Document Control Systems, Procedures, Forms and Templates 42
S Looking for Document Control Templates Document Control Systems, Procedures, Forms and Templates 1
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
tony s Performance Indicators for Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
T Document Control of FMEAs and Control Plans FMEA and Control Plans 5
T Is there a difference between form control and document control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
x-files Proper Document Control Requests Document Control Systems, Procedures, Forms and Templates 1
