At our facility, we have talked about gauge families with regards to capability studies. This seems to be a method to prove that the measurement system by design is repeatable, and not every single individual gauge. For example, if we use a digital caliper on the production floor to measure something that is on our control plan/inspection plan, then it has to undergo an R&R, however we dont have to do an R&R on every single caliper in the building. I am wondering if this also can go for machines that are identical. We have some plunge force bench gauges with load cells in them that check the plunging force on joints. All 3 of them are the same construction. Do you think it is feasible to combine these into a family and do 1 of them to cover the 3 gauges? Maybe we could choose a different one every cycle so you are eventually checking all of them? We had the same question about doing R&R's on gauges that are just wheels and indicators. Some of them use wheels to roll the shaft and Mitutoyo dial indicators to check the runout, while others use wheels and Solartron LVDT probes to check the runout. Could we just do the wheels/dial indicator method to cover them all, since this would likely be the one with the most influence?
