GRR (Gage R&R) with Different Scales
F
findthebird
Hello!
I would like to make a GR&R (with STATISTICA) for a device which measure the power of optical lenses. I have data of 15 samples, with 5 trials, 3 operators. BUT the samples' range is from 0 Diopter to 30 diopter. Since this, the part-to-part variation doesn't make sense.
I have nominal values for these lenses. My thought was to take away the nominal value, but i'm not sure. (And there is also an other problem: the nominal values made from the measured. The gauge's resolution is 0.01 Dpt and from that data we round the measured values to nominal classes with 0.5 range.)
Any ideas?
Ninja
Looking for Reality
Howdy findthebird,
Welcome to the Cove!
What are you trying to accomplish with the GRR?
Your own peace of mind? Compliance with a standard? Meet customer requirement?
Are any two or three (or more) of the lenses tested made to meet the same nominal diopter?
What are the acceptability limits (tolerance)?
Can you post the data?
Nuff of the questions...I will often run two different parts in a 3x3x10 GRR for testing the gage, then break the data set into (2) 3x3x5 sets to look deeper into the part variation itself. The part variation is HUGE when I have dissimilar parts in the same set...but that's OK since I know why the variation is so big. The subsets are looked at for info on the variation among similars.
But it all comes down to what you are trying to get out of doing the GRR...
F
findthebird
Thanks for the reply.
After measuring the lens, we categorize it. As I mentioned, the resolution is 0.01 Dpt, but the classes are with 0.5 Dpt. So there are no classical acceptability limits, because after 1 measure, we decide if the lens is in the nominal class, or we have to shift it to an other due to some difference in the raw material, or some manufacturing cause. So basically there is no reject because of the result, for that there are som other criterias.
We have 3 devices. My goal to prove: the devices measure the same results for the same lenses, with the same error. And the operator (and the skills or the temper of his or her) has a big influence on the result.
I have 3 op., 3 device, 5 trials and 15 samples. The samples, as you can see in the attached file, are quite different, so i think i cannot make classes for them.
P.S.: The data is ready for STATISTICA, so sorry for the format.
What is your oppinion?
Thanks in advance!
Ninja
Looking for Reality
Wow...thats a lot of data. We usually see people asking "Do we really need to measure that many times?"
You have the opposite: "How many ways can I slice up the huge data set?"
I ran a quick subset 3x3x10 using the first three operators, first device, first ten measurements, Tolerance of 0.5 (from your posts above) and got:
EV% = 9.2 equipment is near the edge (gage 1)
AV% = 19.3 appraisers using this device vary a lot from user to user
%R&R = 21.4. Below 10 is most desireable.
PV% = 1362.7 -- a meaningless number since you are using known different parts.
You can slice your data set into multiple checks to test various hypotheses:
- Are all the devices equivalent? (slice out a 3x3x10 using 3 people, 3 devices, 10 measures and look at EV%)
- Are all the operators "equal" on a given device? (other than Device 1:cool:)
- Are operators more equivalent on one device than another? (run 3x3x10 on each gage and compare results)
- I didn't look at same-part stats, but among the 15 parts, are two or three of them near identical? If so, especially if you have more than one "group of similars", is one device more repeatable for one range and another device more repeatable for another range?
In the end, you may find a segment by segment statistical analysis more useful than a GRR...unless you specifically need the GRR for some other reason.
HTH
F
findthebird
Very big thanx!
I will do, as you recommended, but before that, while I read your post, 1 more thing came up to my mind: Operator 1, 2 and 3 are the same with the 3 device. Is there any sense to look from an other perspect of view? Let's say, the devices are the operators and they are "using" the handler. Can I get something different from it? (Now, when i'm translating my thoughts, i think, it would do the same, but I'm asking it anyway...)
Ninja
Looking for Reality
I agree, there are a few different ways to mine your data to look at the data set from different angles.
- Do the three devices give the same result for one user?
- Do the users get the same result from one device? (answer is "NO" for device 1, what about the other devices?)
- Do the answers to the above two questions change with different ranges of diopter?
Look at all of the angles related to what you are trying to achieve and see if you can draw a pattern or a trend out of the results that helps to direct your path forward.
F
findthebird
Sorry, i was occupied with other subject, but thank for your answer!
Now i am confused. I didn't get the same data. For me, with the G1, first 10 measurements with 3 operators, 5 trials, 0.5 tolerance applying Range method:
EV%: 28 %
AV%: 44 %
%R&R: 52 %
PV%: 3507 %
And with ANOVA:
EV%: 32 %
AV%: 40 %
OxP%: 45 %
%R&R: 68 %
PV%: 3210 %
These are the % of the tolerance.
(I use STATISTICA)
And there are big differences between yours and mine. Did i misinterpreted sg?
F
findthebird
OK, i'm thinking constantly:)
If I round the data, I got from the machine, for making a decision for the nominal value, shouldn't I round the measurement data also for the MSA?
So maybe the task is a little bit easier, if i round to quarters, because the nominal values are in half step classification? And the tolerance will be +-0.25?
Thanks in advence!
F
findthebird
I think I get it. Not specific GR&R what I need in this case, but 3-W ANOVA, wher I should decide, if the gages and the operators are giving the same results.
Am I right?
Sorry, i just started...
B How to perform a MSA - GRR (Gage R&R) A&R/ANOVA Vs GUM/VDA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S GRR (Gage Repeatability and Reproducibility) for Material Strength Tester Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
P New Part - How to choose what needs GRR (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
K The basics of GRR (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Type 1 GRR (Gage R&R) on a One Sided Specification Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
I Minitab ANOVA Gage R&R Error (vs. EXCEL ANOVA GRR Calculation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R MSA - GRR (Gage R&R) Requirement for CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
Rameshwar25 What is the significance of Spread in Calculating GRR (Gage R&R)? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Rameshwar25 GRR (Gage R&R) Nested Anova Method Example Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 40
T When is GRR (Gage R&R) required? AIAG MSA Manual Version 4 Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
H GRR (Gage R&R) Study for Digital Temperature Gauge Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
L %GRR/TV or /TW for GRR of One Sided Specification - Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
S Gage R&R (GRR) Study - Please comment on the results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
J Attribute GRR (Gage R&R) - How to get Kappa Software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S p-Value(s) for Anova (Crossed) GRR (Gage R&R) Studies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D GRR (Gage R&R) procedure for Mitutoyo Digital Micrometer wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T % Gage R&R Calculation - 100x(GRR/ (Spec/6)) or 100x(GRR/TV) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 20
O The Basis of %GRR (% Gage R&R) and other Statistics - Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 21
A Effect of %GRR (% Gage R&R) on Cpk Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
F GRR (Gage R&R aka GR&R) on Laser Gages for Plastic Extrusion Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B Sampling in GRR - Why do we need 10 samples to do a Gage R&R? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Gage R&R study definition - Results for GRR is .0005 - What does this number tell me? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
B How to get a sample that covers Process Variation for GRR (Gage R&R) study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
P Can anyone suggest a GRR procedure for a Multi step plug gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Best Gage R&R (GR&R - GRR) Method for Product Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
O Gage R&R Related Terms - EV, %EV, AV, %AV, GRR, %GRR, PV, %PV, TV, and P/T Ratio Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
O GRR (Gage R&R) Method for Camera Vision Inspection System Hardware and Software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
A Cg, Cgk and GRR of a CMM Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K %GRR was between 10-30% so we have to have a "backup plan" per auditor IATF 16949 - Automotive Quality Systems Standard 15
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Minitab 18: How to automate GRR Summary Table save Reliability Analysis - Predictions, Testing and Standards 1
J Question on very low NDC number with tolerable GRR ratio's Capability, Accuracy and Stability - Processes, Machines, etc. 7
C Evaluating GRR Scores %Tol vs %TV Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
S GRR on ID with set of pin gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Q What does % study variation of 20% mean in GRR? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
C %GRR <10% not possible. How to get approval by auditor? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
V GRR Study on a Finished Product - Batch Manufacturing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S Script of R software to conduct Nested GRR for Destructive Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
A Hypothesis test for Bias, not for GRR. WHY ?? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Calculating part variation from historic data for GRR study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
A Need MSA %GRR Interpretation Advice Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M GRR approach for off line Measuring Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
P Does anyone have the GRR Formula? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
5 Reasonable GRR result for a 0-1" micrometer with a total tolerance of .002" Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
T MSA - Should I compare my GRR to tolerance or to my sample? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 16
D What the impact is of a high %GRR/TV Capability, Accuracy and Stability - Processes, Machines, etc. 6
V Sample Range for a valid GRR using ANOVA in Minitab Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
R New to MSA - I was told to use ANOVA for the GRR's Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
