ISO 10993-1: External Communicating Device biocompatibility test requirements
snakepitt
Our medical device has two basic components: A disposable catheter-type device that goes into the blood stream for treatment, and a separate disposable control module held and manipulated by the physician.
We are trying to determine the biocompatibility test requirements, if any, for the control module. I have access to the device categorization test matrix table from ISO 10993-1, and it seems that the best fit might be "external communicating device, blood path indirect". I suspect that these are defined in ISO 10993-1 but unfortunately I do not have ready access to the standard (working on it), and internet searches for explanation have come up empty.
Is someone able to elaborate on possible examples of an external communicating device and blood path indirect, or point me in the right direction?
Ronen E
Problem Solver
Moderator
Normally, IV sets fall under that category.
it's a bit difficult to be specific without knowing that control module and the nature of it's contact with the patient. If it stays outside the body but contacts in vivo body fluids either directly or indirectly (e.g. via saline), I'd venture to say that you picked the right category. If you contact me in a PM and provide details or direct me to a website, I might be able to verify that.
If you contact NAMSA (or similar) they will be able to help you with both classification and actual testing.
Cheers,
Ronen.
snakepitt
Hi Ronen,
Thanks very much for the reply. I thought I responded to you a couple weeks ago with additional information, but in looking at the thread just now I do not see it. Anyway, I will try again.
To elaborate on our device: The catheter-type device is a platinum coil attached to the distal end of a 2 meter long pusher, and housed within a retractable introducer sheath. The coil and distal portion of the pusher are inserted into an artery and advanced to an aneurysm to be treated. The pusher does not contain a fluid channel. The pusher is like a guide wire in that regard. When the coil is in position, the proximal end of the pusher is then connected to the control module. The control module is not intended to contact the patient directly or indirectly.
Pushing a button on the control module produces a small electrical current (isolated from the patient) which causes the coil to detach from the pusher, and stay within the aneurysm. The pusher is then removed.
Attached is a Use guide from a company called Terumo, which produces a product along the lines to the one we are developing. The green “detach controller” in the Use guide is what I am referring to as control module.
A colleague pointed me to a nice pamphlet produced by a company Pacific Biolabs, which contains a device category and example table, I believe excerpted from ISO 10993 (page 13 of the PDF file).
After reviewing this table, I am of the opinion that our coil is an Implant, pusher is an External Communicating Device, Circulating Blood; and that the control module does not fit into any of these categories. I think such a device is called Non-Contact. If correct, would that mean no biocompatibility testing required?
I will appreciate your further analysis and feedback.
Thanks,
Jeffrey
Ronen E
Problem Solver
Moderator
Thanks for the additional information.
I mostly agree with your analysis, though I think it won't be unreasonable to expect the outer shell of the control module to occasionally briefly contact the patient's skin (going by Terumo's brochure which you attached). Under this scenario it would be a Skin, Limited Duration Contact device, per ISO 10993-1.
The pamphlet which you referred to, showing the device categories and examples, was not attached to your post. I assume it is that one. The contents in p. 13 of the PDF (p. 12 of the document) are taken directly from ISO 10993-1.
Cheers,
Ronen.
snakepitt
Thanks again Ronen for your feedback. Yes, the pamphlet you attached is the one to which I was referring. To your point about possible occasional skin contact, the patient is fully covered under sterile drapes, so likelihood is minimal. However, to be conservative it might be prudent to treat the controller as you suggest.
Take care,
Jeffrey
:thanx:
S Knee Implant (Femoral -Cobalt chrome)-Sub chronic toxicity test (ISO 10993-11)choice of root Medical Device and FDA Regulations and Standards News 2
R ISO 10993-18 Medical Device and FDA Regulations and Standards News 1
M ISO 10993-17 - Ancillary Medicinal substance leachables Medical Device and FDA Regulations and Standards News 1
M Medical Devices - Ancillary - ISO 10993-17 Medical Device and FDA Regulations and Standards News 6
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
L Biological Assessment (ISO 10993-1) Other Medical Device Related Standards 1
L Process changes and biocompatibility (ISO 10993-1) Other Medical Device Related Standards 1
S ECG Cable Banana to Snap or Tab electrode Adapters -- ISO 10993 Requirement Other Medical Device Related Standards 0
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 7
A ISO 10993-7:2008/ Amd.1:2019 - Classification of special populations Other Medical Device Related Standards 3
P European versions of standards - ISO 10993-1 and ISO 11607-1 EU Medical Device Regulations 6
S ISO 10993 Biocompatibility Evaluation - Electronic thermometer Other Medical Device Related Standards 3
P ISO 10993-1:2018 - When will the European equivalent become a Harmonized Standard? Other Medical Device Related Standards 13
I ISO 10993 Biocompatibility Requirements - manufacturing process chemicals Other Medical Device Related Standards 8
N Technical File Reviewer has requested more testing to ISO 10993 Other Medical Device Related Standards 10
T ISO 10993-7 - Ethylene oxide sterilization residues Other Medical Device Related Standards 1
planB ISO 10993-1:2018 has just been published Other Medical Device Related Standards 2
M Does ISO 10993 Apply to Packaging? (e.g. Travel Case) Other Medical Device Related Standards 4
K ISO 10993 Requirements For 510k - Substantial Equivalence Other US Medical Device Regulations 11
T Using Risk Management in ISO 10993 - Medical Device Accessory 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P ISO 10993 - Sterile (Irradiation) Polypropylene Syringe Question Other Medical Device Related Standards 6
D Actual Definition of Non-Contact for ISO 10993 Other Medical Device Related Standards 1
R Biocompatibility - ISO 10993 and SVHC Requirements Other Medical Device Related Standards 4
S Selecting materials for implants to comply with ISO 10993 biocompatibility Other Medical Device Related Standards 4
T Plastic of an infusion pump enclosure and ISO 10993 ISO 13485:2016 - Medical Device Quality Management Systems 2
E Upcoming changes for ISO 10993 and IEC 60601 in South Korea Other Medical Device Regulations World-Wide 2
M FDA issues draft guidance to replace G95-1 (Application of ISO 10993) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
B Verify GB/T 16886 is the same as ISO 10993 US Food and Drug Administration (FDA) 5
B New ISO 10993-12 - Consistency of Extraction Conditions through different Assays Other ISO and International Standards and European Regulations 1
S Suppliers of ISO 10993 compliant Material for Skin Contact Other ISO and International Standards and European Regulations 3
M ISO 10993 - Repeat tests necessary if colour changes slightly? Other Medical Device Related Standards 11
M Pre-Selecting Materials for ISO 10993-1 Biocompatibility Compliance Other ISO and International Standards and European Regulations 5
F ISO 10993-10 - Removed from List of Harmonized Standards Other Medical Device Related Standards 4
S ISO 10993 Cytotox Testing - Direct Contact rather than Extractables Other Medical Device Related Standards 4
E Meeting ISO 10993-1 2009 Material Risk Assessment Requirements Other Medical Device Related Standards 13
M ISO 10993 Labs which can test Cytotoxicity, Sensitizaton and Irritation Other Medical Device Related Standards 10
M ISO 10993 for Fabric based Electrode - Finding already FDA Approved Materials Other Medical Device Related Standards 11
J Biological Evaluation requirements per ISO 10993 - Medical Device Testing ISO 13485:2016 - Medical Device Quality Management Systems 2
A Claiming Biocompatibility without ISO 10993-1 Other Medical Device Related Standards 19
J ISO 10993 (Biological Compatibility) Approved Materials US Food and Drug Administration (FDA) 23
T ISO 10993-10: 2002 vs 2010 version - What are the Major Changes? ISO 13485:2016 - Medical Device Quality Management Systems 2
W ISO 10993 (Biological Evaluation of Medical Devices) for Suppliers Other ISO and International Standards and European Regulations 8
I EO (Ethylene Oxide) Residuals - EN ISO 10993-7:2008 EU Medical Device Regulations 5
D Does anyone know of a biocompatible ABS tested & certified to ISO 10993-1 Other Medical Device Related Standards 5
W ISO 10993 - Replacing Sensitization Test with Systemic Toxicity Test? Other Medical Device Related Standards 4
I ISO 10993-10:2010 Guidance Document for Irritation and Sensitization Test - Changes ISO 13485:2016 - Medical Device Quality Management Systems 3
M EO (Ethylene Oxide) and ECH (Ethylene Chlorohydrin) Residual as per ISO 10993-7:2008 ISO 13485:2016 - Medical Device Quality Management Systems 15
I ISO 10993-1:2009 Sensitization (Initial Evaluation Test) vs. USP Other Medical Device Related Standards 3
B What ISO 10993 considers Non-Invasive vs. Invasive MDD 93/42/EEC EU Medical Device Regulations 3
C Differences between the biocompatibility standards ISO 7405 and ISO 10993 Other Medical Device Related Standards 2
