Tagin
Objective evidence: it was noted during the audit that no supplier evaluation records were available for the following indirect material suppliers: (2 MRO suppliers were listed as evidence)
Assuming MRO = Maintenance, Repair and Operations...it leads to another question...
Did your company determine that no records needed to be kept for those suppliers, and did you determine that no monitoring or reevaluation was needed for those suppliers?
It isn't that you didn't do it, it's that you didn't determine and apply the criteria...or at least you didn't show that to the auditor...
That's what I was saying above...we determined and applied the criteria of "as long as stuff matches the packing list for these guys".
Often MRO suppliers perform services on aerospace parts (the O is often short for Overhaul). If for example you sent a product to a MRO supplier who performed maintenance on, or repaired it, and then you sent it to your customer, that MRO supplier should be controlled.
...but did you "determine and apply the criteria " for that vendor?
Did you show that to the auditor?
Yes, it's totally picky...and unreasonable...
But you can fight it forever, or write a simple note in your AVL and make the whole thing go away and get back to real work.
