Operation of possible rework in control plan
Skyrocketing
Hello everyone,
One situation i had on recent IATF audit, worker was screwing the bolt with torque wrench and it hitted alarm on system when he started with operation and in front of auditors he repeated tightening - rework, and we got immediatly major NC because is not prescribed in control plan...
Since for rework you need to have customer approval (in this case risk is minor because it tights bolt with 3 Nm and final customer tight again up to 12 Nm) how i can adress this properly in control plan?
Thank you
Welcome to the Cove. Please explain more about the operation:
  1. Was this a rework operation?
  2. What triggered the alarm, and why?
  3. Why did he keep going after the alarm sounded?
  4. Is this rework a part of normal operations?
Skyrocketing
1. Auditors qualified this as rework, repeatble tightening operation, it could possible damage first steps of the thread
2.Alarm could be triggered if there is a increased dirt in thread (this product is not washed, straightly after machining it goes on assembly), if worker adjusted a little bit under angle a bolt vs thread etc
3. No, operation stopped, hydraulic screwdriver stopped, that he just reset the panel and screwed bolt again
4. Lets say, every 20-30 screwings happens..
Thank you Mr.Wayne!
Skyrocketing
So this our operation is rework and we need just to have described it in tehnological instruction and contril method written in control plan?
Thank you
Thank you Mr.Wayne!
So what you're saying if I understand you correctly, is that this action is a normal part of the process. If that's the case, it seems that the auditor is way off base and you should contest the finding.
Added in Edit: If this is a normal part of the process, it should be added to the control plan. If it's not there, there could be a minor NC involved, but certainly not a major.
Matt's Quality Handle
It sounds like a "normal" part of the process that just hasn't been documented yet. Document it, add it to your Control Plan/Work Instructions. Depending on how your documents are structured, you might be able to describe it in your work instructions, then have your CP reference the WI.
This caused us heartburn during the IATF 2016 transition. We were doing a metal stamping/forming operation, and there was frequently "rework" that was part of the process. Mainly around hammering or filing of burrs. We wrote a general rework work instruction, and listed it in the control plan. Our control plan was used as the basis for our work instructions, so the CP was not on the floor.
If the auditor questioned it, we could point to the CP, which was approved by the customer at PPAP.
Sebastian
In my opinion it wasn't rework.
Rework is post product inspection activity.
Tightening torque is process characteristic, not product.
Alarm was triggered not by failure to achieve torque target value, but minimal number of turns.
So number of turns is additional process characteristic here.
I would expect to find both these characteristics in PFMEA and control plan.
Detection control is torque wrench angle sensor.
Detection effectiveness depends on operators reaction to alarm.
In control plan I would expect in reaction plan column description of activities performed by operator, these which de has done in front of auditor or reference to instruction including guidelines for operator how to behave when alarm goes on.
It might be unscrewing, visual check of thread condition, using air gun to remove dirt and tightening bolt again.
There was no post process inspection, so product can't be found detective and there is no reason for implementing correction.
Rework is method of correction implemented over defective product.
So on auditor's place I would review PFMEA, control plan and work instruction carefully, to find justification for what I have seen.
If not, reaction plan is better
Some may say, that tightening torque could be checked with a calibrated torque wrench, so it has to be treated as product characteristic, but in my opinion it is not proper method to control this characteristic.
L Principles of operation vs Mode of action EU Medical Device Regulations 6
C Inspection Operation in PFMEA FMEA and Control Plans 13
A AS9100D - Clause 8.1 Operation - Coating service company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G Need resources / tutorials about OPS (Operation) for ISO IT (Information Technology) Service Management 8
F MEDDEV 2.7/1 rev 4 and MDR - Definition of Description of Principles of operation EU Medical Device Regulations 4
J ISO 9001:2015 Small Operation Management Review General Auditing Discussions 6
B Machine process sheet requirements for pill bottling operation Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
G Infrastructure and Environment for the operation of processes (ISO 9001 7.1.3 & 7.1.4) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T Hot dogs and process operation and control effectiveness? 4.1.3 a) ISO 13485:2016 - Medical Device Quality Management Systems 2
S SOP Training/Competence in 24/7 Operation contractor company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
E High level structure - Planning and operation control Occupational Health & Safety Management Standards 2
T Should Testing be a separate operation in the Control Plan? FMEA and Control Plans 5
M Work Instruction Content or Sequence Changes and Operation Numbering Document Control Systems, Procedures, Forms and Templates 3
K Is an assembly service, part sequencing, and kitting operation Qualified for TS 16949 IATF 16949 - Automotive Quality Systems Standard 1
L ISO 9001 Operation Process Control Requirements ("Carta de Control de Proceso") ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Mining Operation Sand Plant - Required Standards and Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M What should be in an SOP for a Machine Operation - LAF Bench in our Clean Room ISO 13485:2016 - Medical Device Quality Management Systems 3
T What tools are there to monitor a Manufacturing Process or Operation? Quality Tools, Improvement and Analysis 2
C Design of Experiments to Reduce Variation in a Lathe Operation Quality Assurance and Compliance Software Tools and Solutions 9
S Revision Requirements - Completed Operation on a Job Traveler Document Control Systems, Procedures, Forms and Templates 4
K Machine Press Tooling Operation Inspection Samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M FSMA Regulations and Santa's Import Operation Funny Stuff - Jokes and Humour 4
M Incorporating Safety Requirements into Standard Operation Procedure Document Control Systems, Procedures, Forms and Templates 4
E TS 16949 Clause 7.1.1 Process Planning-Operation Sheet Example wanted Document Control Systems, Procedures, Forms and Templates 5
M QCOS (Quality Control Operation Sheet) - Process inspired from GM India? FMEA and Control Plans 3
K Equipment Lifetime: Put in operation manual or a individual document/declaration Quality Manager and Management Related Issues 1
K Malware affecting my computer operation After Work and Weekend Discussion Topics 19
V Should the Line Clearance include Machine Setup for current Operation? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
J QA Organizational Reporting Structure for a sample Food Operation Food Safety - ISO 22000, HACCP (21 CFR 120) 4
V MOST (Maynard Operation Sequence Technique) Technique - Information/Help wanted Manufacturing and Related Processes 2
I Validation of a MOST (Maynard Operation Sequence Technique) Time Study Human Factors and Ergonomics in Engineering 2
D Severity or Occurrence? Performing an FMEA on Motorcycle Operation FMEA and Control Plans 9
T Big problems with Inspection - Manual Operation - Needs experts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 27
M Trepanning Operation for making inner and outer races of bearings Manufacturing and Related Processes 1
C GMP Standard Operation Procedure - Differences between ISO 13485 and 21 CFR 810 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
F Sales and Operation Planning (S&OP) information needed Manufacturing and Related Processes 2
C Packaging & Labeling Standard Operation Procedure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
D Family Mold in Mass Production? Lean Operation Manufacturing and Related Processes 7
S DFMEA (Design FMEA) for a New Line Operation of the Underground Operation FMEA and Control Plans 10
A Operation Control for Reducing Electricity Consumption Miscellaneous Environmental Standards and EMS Related Discussions 18
J ISO 9001 requirement for Sequencing Operation Service Industry Specific Topics 17
M Shop Travelers and Operation Sheets AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
H How the 50 Second Rule for an Operation was Derived Lean in Manufacturing and Service Industries 4
M No Tolerances given by Customer - Shirring (sewing operation) IATF 16949 - Automotive Quality Systems Standard 5
AnaMariaVR2 Regulatory References for the Operation, Maintenance and Calibration of GLP equipment US Food and Drug Administration (FDA) 6
J Aviation Safety Standards applicable to operation and maintenance Federal Aviation Administration (FAA) Standards and Requirements 2
G Progression Stamping Operation (Galvanised Steel) FMEA example wanted Manufacturing and Related Processes 7
M Refurbishment Operation - Nonconforming Operating Procedure help wanted! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C MOST (Maynard Operation Sequence Technique) study for assembly of cockpit Lean in Manufacturing and Service Industries 6
A Inspection Check and Validation of work from the previous operation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
