Receiving Inspection AQL - Am I allowed to just pick a AQL?
V
venom21
I'm very new to this thread so I hope I'm in the right place....I have a question about receiving inspection AQL's. I'm ISO 9001:2015 certified and I have product coming in from an outside vendor and I would like to use MIL-STD-105E Table II-A the Single Sampling Plans for Normal Inspection (Master Table). The supplier I'm using provided Final Inspection IP's and Control Plans and sent me a sample part that I measured on my CMM and all of my measurements are within a .0001". With this in mind I would like to check each lot regardless of size (lots range from 10 pcs to 100 pcs) at a 6.5 AQL. My question is am I allowed to just pick a AQL? I feel like this has to be explained somewhere I'm not sure where.....
Thanks!
ScottK
Not out of the crisis
Thanks!
Welcome to the Cover venom21.
The AQL in this plan really tells you how many defectives you can have in your sample and still accept the lot.
So the first question is: can you accept defectives? If you cannot then I would suggest you ditch this plan and look at Zero Acceptance Number Sampling Plans - Like Squeglia's.
I'm seeing more and more companies go to this.
If you are just using MIL-STD-105E (which is obsolete, BTW. ANSI/ASQ Z1.4 is the replacement. Pretty much the same though) to determine a sample size then AQL really doesn't matter. What matters is the inspection level.
Statistical Steven
Statistician
If your lot size is between 10 and 100, then sampling plans like Z1.4 might be inappropriate. For an AQL of 6.5, the standard requires a sample size of 3 and acc/rej of 0. Such plans though have a low AQL, have a VERY high RQL (greater than 50%). If the testing you are doing is no destructive, you might as well 100% inspection versus a sampling plan.
To answer you more generic question, unless specified by contract, you select the AQL based on the risk you are willing to accept.
Thanks!
V
venom21
ScottK,
Thank you for the quick response, also I understand that the standard is obsolete but I was under the impression it could still be referenced so thank you for the heads up.
As for your your next question, yes and no if a no, if a critical feature is like a .0001" out of tolerance we can accept but if it's a something critical I would reject and inspect the entire lot.
As for the Zero Acceptance Number Sampling Plans I just started to look at Squeglia's and it looks like it could also work, do you have a link or something that explains how to determine which AQL level to use?
Thanks again
V
venom21
Eredhel,
Not exactly, my understanding of the standard is that I have to make sure that my vendor can supply quality product consistently and that product needs to be verified either by the vendor or by me, which the vendor does. I just want to perform an additional check on the product when its received.
My question is how do I determine the best AQL to inspect parts to? And if i'm not understanding ISO 9001:2015 please let me know.
ScottK
ScottK,
Thanks again
The AQL is generally based on the level of risk you can tolerate and agreement with the supplier that they can be held to that AQL. An AQL of 6.5 is generally pretty loose where I've worked but that's been in drug and device. An AQL of 1.0 or 1.5 is more typical for most characteristics.
Here's an older thread on determining AQL level:
AQL (Acceptable Quality Level) vs. PPM (Parts per Million) - Equivalences?
Eredhel
Quality Manager
You're on the right track, I just wanted to make sure you didn't think there was some sample size specific ISO 9001 requirement because there isn't. Like Scott said it's up to you all to balance the risk and pick something reasonable.
AndyN
Moved On
Thanks!
I've been heavily involved in this decision (or at least, the aftermath of the decision being made). Firstly, since your supplier provides their inspection data etc. can I ask WHY you feel it's necessary to sample?
I Medical Device Receiving Inspection AQL AQL - Acceptable Quality Level 5
L Is AQL necessary for ISO 9001 receiving inspection? AQL - Acceptable Quality Level 24
L Incoming (Receiving) Inspection - Is it really necessary that we follow the AQL? AQL - Acceptable Quality Level 7
M Receiving Inspection Plan of COTS and SCH Help Various Other Specifications, Standards, and related Requirements 6
W Proper gage to use for receiving inspection General Measurement Device and Calibration Topics 9
R AS9100 - 8.4.2 - Receiving Inspection Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
Skooma Receiving Inspection - Boss trying to save money AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
I Receiving Inspection Requirement in IATF IATF 16949 - Automotive Quality Systems Standard 3
D Incoming (Receiving) Inspection - General form for incoming part inspection Document Control Systems, Procedures, Forms and Templates 17
J Receiving Inspection for Metal Strips & Wires Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Objectives for Receiving Inspection (Resources) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Hardware Receiving Inspection AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
N Receiving Inspection - Who should receive raw material Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
kedarg6500 Use of safety glasses at receiving inspection Occupational Health & Safety Management Standards 7
L How do you specify your receiving inspection parameters? Misc. Quality Assurance and Business Systems Related Topics 2
D Receiving Inspection Training Materials Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S So Annoyed with Receiving Inspection! Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
R Minimum Essential Receiving Inspection (M.E.R.I.) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
M Definition Receiving Inspection of Parts, finished products, service parts etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
kedarg6500 Receiving Inspection Documentation Best Practices Supplier Quality Assurance and other Supplier Issues 2
L Must we do Receiving Inspection for everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
M Does 21 CFR 820.80 (b) require a Supplier to have Receiving Inspection? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
M Calculating Adequate Receiving Inspection Sample Size Statistical Analysis Tools, Techniques and SPC 2
L How to define R & D Receiving (Incoming) Inspection Plan Design and Development of Products and Processes 18
M Receiving Inspection of Customer Owner Property IATF 16949 - Automotive Quality Systems Standard 5
M Partial Incoming (Receiving) Inspection Delivery Inspection. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
alonFAI Establishing a Receiving Inspection Procedure Document Control Systems, Procedures, Forms and Templates 5
S Ensuring Print Dimensions are in Control Plans, WI's and Receiving Inspection Document Control Systems, Procedures, Forms and Templates 3
S How to calculate Supplier PPM at Receiving Inspection Document Control Systems, Procedures, Forms and Templates 2
C Supplier Management and Receiving Inspection Improvement Statistical Analysis Tools, Techniques and SPC 20
Q Receiving Inspection - Quantity Received different from Pack List & C of C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C Receiving Raw Materials, Inspection, Release Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
G Reduced Receiving Inspection - Now What Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
M Incoming (Receiving) Inspection Procedure - Please Review Supplier Quality Assurance and other Supplier Issues 7
paul van oppen Random Sampling at Receiving Inspection: A Practical Implementation needed Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
M How to Eliminate Receiving Inspection Supplier Quality Assurance and other Supplier Issues 10
A Receiving Inspection - One drum leaks - Should entire lot be rejected? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
V Measurement Reports for Receiving Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
K Incoming (Receiving) Inspection for Commodity Items used in Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 11
S Inspection Forms - Receiving Inspection on Buses that will get Refurbished Document Control Systems, Procedures, Forms and Templates 7
C Medical Device On The Floor Receiving (Incoming) Quality Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Receiving inspection and Internal Audit schedule ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T How do I Reduce Frequency of Receiving Inspection Testing for Quality Control Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P How you do Receiving Inspection for Chemicals? Supplier Quality Assurance and other Supplier Issues 9
E Measuring Receiving Inspection Process Effectiveness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
T Is 'Supplier Part Batch' a Root Cause - No Receiving Inspection Problem Solving, Root Cause Fault and Failure Analysis 11
U What Legal Documentation is required for Receiving Inspection of Parts Federal Aviation Administration (FAA) Standards and Requirements 1
T Should the pFMEA start with Receiving Inspection? FMEA and Control Plans 18
S How to maintain 0 Rejections for Quality Receiving Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
T Is Material Certification Required for Incoming Material (Receiving) Inspection? Supplier Quality Assurance and other Supplier Issues 10
