akzmn
Hi… I am working on an unconventional method to measure electrical resistivity of a material over time… There are three controllable variables (frequency, voltage, wave form) and I have chosen 3 levels for each (for example voltage could be 2V,5V, or 8V)…You can see an example of measurements (repeated 3 times under same test conditions) during 48 hours (attached pic)… I want to use Taguchi method to find the test conditions which leads to the minimum variations in resistivity readings (the resistivity value itself is not that important as the device will be calibrated, but I need to reach the highest repeatability) ….So now the question is: what should I choose as response variable (since readings are continuous)? I need a measure to show the variations over 48-hour time so I cannot use the resistivity in a single time point…thanks in advance!
