Tolerance definition based on expected Cp/cpk
Hello all,
I have a question. We are in technical review prior the offer, our customer is requesting a min Cp/Cpk of 2 on some characteristics.
Just as pure example, assuming that the dimension is 40 +/-0,3, that the Cp/Cpk in serial production has to be >2, how can I calculate in advance which should be UCL/LCL I have to keep in serial life or how should much I should close the tollerance range during setting my process in order to achieve the Cp/Cpk?
Many thanks for your help!!!
This is a misunderstanding of process capability. The process is what it is and creates its own control limits. You can reduce variation in three ways: 1) eliminate special causes; 2) reduce common cause variation by changing the process design, or 3) reduce common cause variation by using Taguchi parameter design methods. You cannot reduce variation by tightening the specifications unless you setup 100% automated inspection and sorted out everything, which would truncate the distribution and prevent you from calculating Cp/Cpk, which assume normality.
Hi Miner, yes I know you are totally right. Maybe I miss something in my description.
It's a plastic part, injection moulding process. Let's Imagine for a while that the only variability of the process Is the the mold. If i use the whole tolleranze range maybe I have cp/cpk 1.33 but if i want cp/cpk 2 or higher then i Need to reduce the portion of tollerance. How much i tight the tollerance Is equal to the effort to center the dimension. I know it's pure thoery but There Is a calculation whoch could support?
So you definitely have cavity to cavity variation, possibly mold to mold variation if you have more than one mold. If you run this mold on more than one injection press, you would have press to press variation. You will have variation from lot to lot of plastic resin, variation from the amount of regrind used, variation in moisture content of the resin, variation from the process parameters, etc., so the mold is not the only source of variation. Tightening the tolerance has no impact on these sources of variation. The process variation stays the same.
optomist1
A Sea of Statistics
...put another way if the "common cause variation is unacceptable", (special cause variation has been addressed/eliminated), the process should be looked at in detail....re-designed
I know all the variances you mentioned. I am talking from a purely hipothetical situation (totally out of real world), where i can only work in reducing the tollerance, Is there any way to calculate how much i have to reduce It?
In order to increase Cpk, you would need to expand the tolerance, not reduce it.
right, but in this case you should change customer design. To go in this direction we want to say like this:
1) you ask 40 +/-0,3 with cp/cpk 2, this means that we must tune our mould to 40 +/- xx (xx value is what I want to calculate which is less the +/-0,3 required in the dwg) and this has a huge developement cost
2) then considering the huge effert (anc cost) in centering the new tolelrance and taking into condideration that injetion process has several variants, proposal might be to increase orginal tollerances in dwg (i.e. 40 +/-0,5) or reduce cp/cpk to 1,33
Mikey324
Do you mean, for example, you are currently using up 80% of the tolerance and would like to know if improving to using only 5% of the tolerance would give you > 2?
V MSA - Which edition constants are these? What is definition of Tolerance? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
T Definition Tolerance Stackup - Clear Definition Needed Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
M Definition Out of Tolerance Condition - Definition of *Significant* Out of Tolerance Condition Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
T Simulate Tolerance Range with Real Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Tolerance and MPEs for Re-calibration Manufacturing and Related Processes 0
S GD&T Bonus Tolerance OOS Capability, Accuracy and Stability - Processes, Machines, etc. 2
WEAVER Can you determine exact date an instrument went out of tolerance? General Measurement Device and Calibration Topics 10
K COPLANARITY: Composite profile tolerance on multiple surfaces- what does" lower dimensional reference frame tolerance" control? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
I Profile tolerance with a positional tolerance to a hole ? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A % STUDY VARIATION VS. % TOLERANCE Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 31
A +0/-.001 Tolerance question - Feature size is 1.249 +0/-.001 - Actually measures 1.2493 (.0003 OHL Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
L Validation without Tolerance Qualification and Validation (including 21 CFR Part 11) 0
A Need to calculate tolerance Intervals with a set of non-normal data and 3-Parameter Weibull distribution Using Minitab Software 0
Q Acceptable Tolerance - how to derive? Measurement Uncertainty (MU) 16
D Tolerance symbol Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
D Calibration tolerance question using Pipettes Medical Device and FDA Regulations and Standards News 3
G 0.00005" tolerance on micrometer with 0.0005" resolution? General Measurement Device and Calibration Topics 4
J Mechanical inspection techniques of close tolerance parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Proud Liberal Small radius with tight tolerance on a torus General Measurement Device and Calibration Topics 4
L GRR for a tolerance that has changed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
T How to justify this High %Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Tolerance limits for micro balance General Measurement Device and Calibration Topics 1
Q % Study variation low, % tolerance high - GR&R Interpretation help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
Ronen E Tolerance intervals (?) question - Flow Rate Probability Range Statistical Analysis Tools, Techniques and SPC 6
D Tolerance when verifying an analytical balance General Measurement Device and Calibration Topics 3
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
T GRR based on part tolerance or process variation. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Excel OOT (Out of Tolerance) Formula Excel .xls Spreadsheet Templates and Tools 3
S Question about a basic additive variance/tolerance example Quality Tools, Improvement and Analysis 2
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
B Gage R&R Acceptable (10-30%), deduct Total Variation from Tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
F Position tolerance check gage manufacturing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
M GD&T tolerance or band? Using a symbol like parallelism // Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Gage R&R without tolerance Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
V Using K-Factor(Tolerance Interval) Analysis for Design Verification Statistical Analysis Tools, Techniques and SPC 3
