True Position of slot Boundary with MMC
N
newbie23
Hi Folks,
Please help. There're 3 slots ( .190+.002 -0 width and .375+/-.005 in length) 120 degrees apart with .001 MMC call out (detail B)
How do I apply the MMC for Positon Tolerance? Thanks.
Michael_M
The call out is to -A- and -B-. -B- is the 11.00 bolt circle so your position must be taken from that feature. How you add MMC is based on the .375 tolerance. If the .375 width dimension; for example .375 +/-.005 then you subtract what your actual dimension is from .370 and add this to the .001.
For example, the three slots are .374, .3745, and .375. For the first slot, you get .004 bonus (.374-.370=.004) making your true position .005 (.004 + .001 = .005) to the center of the slot. As indicated above, you will need to do the math for each slot as each can give you different bonuses.
Your true position only takes into account the 11.000 basic. The 30 degree basic dimension defines all other positions since the tolerance block of the slot does not account for a 3rd position (i.e. -C-).
Paul F. Jackson
is the OD. [C] is the three slots and the position callout is associated with the slot-width only so the slot length is not controlled by the position note. [C] is a pattern of three slots that stop rotation for the coordinate system [A|B|C]. If you are checking the callout without hard gaging you would need to find the best rotation that fits all three slots simultaneously first without MMC then adjust the rotation to minimize the position error with respect to each slot's size. Typically the slot closest to the fitted 120 degree spacing center lines in the CW and CCW directions will provide the best fit but MMC allowances will frustrate that strategy.
If you do use an attribute gage diameter must be referenced RFS.
Paul
N How to Calculate a True Position on a Square Slot - GD&T Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
was named killer AS9100 FAIR - True Position hole out by .0011" on 50 parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B True Position Measurement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
P True Position vs X and Y Dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
Q How to perform Process Capability for true position Statistical Analysis Tools, Techniques and SPC 11
M True Position / GD&T - I'm staring at this drawing and I'm lost Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Measuring the True Position of a Cylinder's Pierce Point Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
M True Position and MMC (Dilemma Between Engineers) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Tab to circle True Position? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S GD&T Callout for Diametrical True Position Manufacturing and Related Processes 6
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Surface Profile and True Position Question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
D True Position with 1 hole (Datum B) at the Radius Part Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
L GD&T Bonus Tolerance - Checking True Position of a Pierced Hole Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
C Using a Pin Gage to check True Position of Inline Holes, Design, Tolerance. Etc Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Checking True Position with Pin Gage Measurement Uncertainty (MU) 3
F How could this Hole Diameter and True Position problem have been Detected & Prevented Nonconformance and Corrective Action 27
J Multiplane True Position Calculations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Y Using PC-DMIS to measure True Position of the teeth of a Spline Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
L Calculation of True Position of Slots (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J How to measure the True Position on an Optical Comparator Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Using True Position to Control Symmetry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
K True Position Checking such as Bolt Hole Position w.r.t Center Bore on Wheels Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
M GD&T - True Position Callouts for Sections of Studs Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J GDT True Position Secondary Callout Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
J True Position with only 1 Datum - Referenced datum is the plane the hole is on Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
M True Position of a Hole Capabilty - Appropriate parameters to use Capability, Accuracy and Stability - Processes, Machines, etc. 5
K Understanding True position - Drawing Feature Control Frames - ANSI Y14.5 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
CycleMike Positional callouts on this print - GD&T true position question Inspection, Prints (Drawings), Testing, Sampling and Related Topics 15
J True Position of slots that have angles as basic dimensions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Q GD&T True Position interpretation - True Position FCF on a B/P Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
B Calibration of Home Made Gages - Simple go/no-go gages to true position gages General Measurement Device and Calibration Topics 8
C True Position Question - What does this print callout mean? IATF 16949 - Automotive Quality Systems Standard 12
Q GD&T True Position structure Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
H History of True position formula Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
B True Position without tertiary datum? Establishing a proper rotation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
E Capability study on true position callout. What would be the upper and lower spec? Statistical Analysis Tools, Techniques and SPC 7
A Bidirectional True Position Tolerance Call-Out for Holes for Process Capability Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
S Ppk/Cpk for geometrical true position of hole with MMC Capability, Accuracy and Stability - Processes, Machines, etc. 17
G GD&T Help (Y14.5M-1994) - True position callout box on two dowel holes Various Other Specifications, Standards, and related Requirements 16
J GD&T - True Position - "Boundary" under the feature control frame General Measurement Device and Calibration Topics 10
D Procedure for Fixture Gages that check True Position of holes General Measurement Device and Calibration Topics 4
M How to calculate a True Position toleranced at MMC - Capability of True Position Statistical Analysis Tools, Techniques and SPC 12
D Cpk for one sided dimension - GD&T true position Capability, Accuracy and Stability - Processes, Machines, etc. 15
F Calibration certificate content - Average Value and True Value ISO 17025 related Discussions 6
A True purpose of doing EST (Electrical Safety Test) on medical device Other Medical Device Related Standards 3
M Proper Gauging - GD&T - Attribute gage to check true positioning on the shop floor Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
Marc The Strange & Curious Tale of the Last True Hermit Coffee Break and Water Cooler Discussions 0
