Thank you very much for your professional insight. Its so good to know you're there . . .
Hearing from so many perspectives helped bring up other points to be considered.
Unfortunately, the automatically generated email does not have an acknowledge of receipt - that would have been sleek. And being up for reevaluation, we will certainly be complying by addressing this observation.
To comply with the requirement noted in the observation, and considering that there should be a record of all training I think I'll utilize a feature of Adobe . . .
Evaluation of each revision:
First, the Document Owner would have to evaluate if rereading/retraining is necessary with each revision of the document. (Sharepoint allows the Document Owner to make a comment beside each revision of a document - the comment could be 'no training necessary prior to annual review' or 'retraining required and implemented' or something similar.
Request of and Evidence of Rereading/Retraining:
When rereading/retraining is necessary the Document Owner would send a copy of the document (showing the changes marked) which contains the current revision/date, in PDF form. The recipients will be required to Sign/Certify the PDF electronically. Once all necessary sigs are obtained, the PDF signed by all can be saved to a folder on the Sharepoint site titled QMS Training Records.
Evaluation of effectiveness of training:
The QA Manager will have to design a few pertinent questions, and distribute the questions to all that signed the document. Once the responses are received, the QA Manager can add an evaluation on the bottom of the signed document.
Any way I look at it, I think it's conveluted. I know I tend to overthink the requirements, but I know the auditor is going to look for records of training, and for evidence that the training was effective - so this is as simple as it gets, right?
Trial Run:
I'll begin by updating our Documents and Records Control document. I'll note that 'all Document Owners require retraining to the current version' in the comments field - and I'll post a PDF copy of the marked document in the QMS Training Folder. Using the program, I'll specify who should be alerted, and the intended recipients will automatically receive a link via email to where the PDF is stored. The title of the email they will receive will be 'Your Signature of Understanding Changes to a QMS Document is Required by 1/11/2011'. Once all sigs are obtained, I'll send a form with a few questions and request that they return via email. When this is done I'll update the signed PDF with a written evaluation of effectiveness. Phew!
The only upside - we don't anticipate substantial changes to documents very often!
