Quality_Goblin
Hi All,
We are currently reformatting our QMS and I have a couple questions on if/when it would be necessary to change the revision number on documents. Since we are in the process of reformatting and renumbering the system of controlled documents, we have SOPs and WIs that are using both old and new numbering systems:
1) When you change the document number to the new system and new template, and it is at Rev 5. Would you start from Rev 1 with the new document number, or would you continue and go to Rev 6? My thought is that you would start at Rev 1 since the QMS has a new numbering system, but I just wanted to see what others have done.
2) In a new document, when you have referenced (now obsolete) document #s based on the previous QMS format and you need to update the reference document # to match the current QMS system, does this require a revision change on the new document? In our current Document Control SOP things like typos and formatting don't require revision changes. But what about when a reference document number has changed?
Thanks!
Thanks!
