Documentation Control Software for small companies on a Budget
Don_Pisto
Hello All,
I am at ground-zero and looking for some type of automated Documentation Control with Configuration Management but I don't have a huge budget for this (yet).
This would be for initially 4 users and later up to 10.
These are the features looking for:
1. Centralized Design file control with "check-in" and "check-out" features for various CAD file formats.
2. Engineering Change Orders
3. Centralized control of work flows, procedures, and records
4. Security (very important)
Prefer to keep things simple. If possible, also prefer to avoid having to add a physical server but if I must add one, I will.
Don't laugh, but my budget would be from something open-source, to a monthly modest fee of $50-$200 per month, or up to $2,500 per year. Is there something reasonably good out there for the little companies? If I left out any other information needed, please let me know and I'll add.
K
kgott
Every company is one a budget. There have been a number of equiries about doc control software on this forum since I have been here. I would suggest that you search using 'document control software;' and see if some suitable recommendations come up.
From talking around to people about doc control software over time, it seems that no software is perfect.
Perhaps you might also like to search for business freeware or shareware for something that might be appropriate for your needs.
Wes Bucey
Prophet of Profit
Hello All,
First, I believe you should be able to find workable software for the sum you mention, depending on the number of documents and the frequency of revisions.
Second, Kgott is correct, this is a topic that appears frequently here in the Cove and elsewhere. :applause::applause:https://elsmar.com/Forums/showpost.php?p=514018&postcount=8 I wrote earlier this year
I have written about electronic document management a number of times in the past nine years. Most recently just last month. Here's a "brief" summary:
(pay particular attention to comments in bold red font):
Document management (both manual and electronic) has been a particular specialty of mine for for 40+ years. I try to keep abreast, but I can practically guarantee that any brand name recommendation I might give today might be obsoleted by a competitor's new development tomorrow, so I never publish a brand name recommendation.
I do, however, provide a set of guidelines which might help folks looking to adopt an electronic system. I first wrote this ten years ago. One small addition a year or so ago has made it [almost] current for today's use:
Make sure you know and understand the difference between "document sharing" and "document management."
Here's a brief summary to start you off:
Document Management Software
Background:
An organization wants to improve efficiency of document management by ?grafting? a program over current legacy files and all newly-created files which will provide the following minimum benefits:
a) Ease of Search & Retrieval (on different fields/characteristics)
b) Ensure only the most recent revision is available on standard Search menu
c) Automate the procedure of notifying pertinent parties a document is ready for redlining
d) Maintain an audit trail for the status of documents (released or waiting for checking/approval [and by whom])
e) Allow ?full preview? of documents without opening native programs ? i.e. AutoCAD documents can be viewed without latest revision of AutoCAD being resident on user?s computer.
f) Permit ?group printing? of documents, regardless of native file format.
g) Maintain up to 30 security levels on any document, determining whether user has authority to create, modify, redline, view, print, copy, etc.
How do they work?
The primary feature of Document Control Software is a relational database which manipulates very small files called ?metatags?, which relate to certain attributes of documents. Basic attributes are file name, revision level, author, topic, key words, type of file format, etc. which are used for field headings in the database.
By querying the database, a user retrieves a ?menu? of documents which meet the search criteria. Self-contained viewing software permits a user to view and print documents, regardless of the native file format. The views can be scrolled, zoomed, and cropped (i.e. user can print an enlarged detail of a document.)
Users who have redline authority can markup documents without invoking the native file program (the redlines are saved as ?overlays? in separate files without changing the original document.)
Users who have checking/approval/redline authority can be automatically notified via email when a document is ready for their review. The program will track when and whether the review is completed and maintain an audit trail for ?real time? status reports on any or all documents in the review process.
By keying on the attribute ?Revision level?, the program can ensure only the most recent, authorized revision is available to most users, reserving authority to view ?superseded? documents to special categories of users.
An important consideration in grafting legacy documents into the new system is choosing fields pertinent to the organization. Many documents, like autocad and word documents have features which provide automatic tags (create date, author, department, etc.) [click on "properties" under File in a Word document to get an idea of already available fields.]
The problem is most users write documents which still show "valued customer" as the author because they have never explored the Properties feature.
An expense to consider is going back into each legacy document and adding the meta tags which allow for sorting and retrieval.
I hope this helps - there are many consultants like me who would come in and give your organization background on choosing the best brand for your organization. Caution is "Are they truly independent or do they have bias toward one brand?"
I didn't add in that post that most software programs have web versions, too. In point of fact, the documents "could" be located either on one server or scattered among hundreds or even thousands of hard drives or servers as long as they were connected or accessible via password over a network, a virtual private network, or the internet.
[<SNIP>
Back to today
Google "electronic document management" to see some other thoughts on this topic. I hesitate to recommend ANY product by brand name, because the competitive nature of the business is that one company can be hopelessly obsolete in a month or two and another can have a great breakthrough in the same period. Regulatory laws change quickly - a user's current and projected situation in that regard are important factors. Current quantity of documents and projected number of authors and changes are a major factor. Collaboration with suppliers and customers is another big factor. __________________
I can add that, back in the mid 90s, my organization spent over $200,000 creating an electronic data and document management program from scratch. It was unique and wonderful for its time, but hopelessly obsolete and simplistic today (everything was written in COBOL.) Today, a sharp shopper can get a pretty good program for less than $500 per seat (a computer and its operator which have author rights.) Many programs, especially web-based ones, have no extra charge for folks who can only read or print documents, not implement any changes. This is very handy for allowing customers and suppliers access to see documents pertinent only to them.
Do you have a time table for your implementation? Will you be adopting a large number of legacy documents into the system? How many new documents would you generate from your people in a week? a month? a year? How many changes (revisions) to existing documents in those same time frames? Do you have a budget range for accomplishing this? How sophisticated (computer-savvy) are your folks? Will they need mild training or intensive training? Are you budgeting the time and expense for that training? Do you envision collaboration with folks in different geographic locations (customers? suppliers? consultants?)
If anything, let me caution you that this decision on software is one which should take some intensive research and analysis. Often, trying to save a few dollars on the initial capital expenditure is penny wise and pound foolish because of the extra time and effort required by users to implement or "work around" bare bones systems compared with feature-rich ones.
Don_Pisto
Thank you kgott for the search suggestions. I really didn't even know the proper terms to search by, but now I see a sea of information and now just have to wade through it all.
Thank you Mr. Bucey for the detailed reply with your past suggestions. I will study this carefully. The suggestions for 30 security levels grabbed my attention and your mention of it being possible to find something in my budget range was encouraging.
Thank you sagai for the open source suggestions. I'm a little familiar with subversion but never heard of Mercurial, so more to check out
Don_Pisto
One system that I stumbled onto that appears to be a very good fit is something called Adept by Synergis Software.
I only mention Synergis here because I didn't see anything listed in these forums when I tried searching. Maybe someone here is familiar with them? Their literature reads very strong, but it is probably very expensive because they include some Oracle tool for a universal cad viewer.
sagai
Subversion can sort out the document management hassle by its own basic functionality for a company in a highly regulated industry. I have seen a 200 people organization using it without much of a problem.
Cheers!
Don_Pisto
I found a system that looks to be a good fit for what I'm trying to do and I just wanted to share it since it doesn't seem to be discussed on any past forums when I did a search.
It's called infoRouter
If anyone has any experience with this system, I'd be interested in the feedback.
Sunday
I work for Sunday Business Systems (advertising affordable Document Control software in the banner ad to the left) and I would be curious to have you evaluate our Ground Control software to see if it meets your needs.
K
kgott
Hello All,
I forgot to add in my previous post but there is a free version of Sharepoint which we use. It's a bit limited and it tends to be a clickathon but it will do until we get a bit bigger than we are.
I don't know what system you run it where its all MS, Dunno if it will work on Mac or even its still available.
