Gman2
Involved - Posts
Ok next item on my dartboard here is Document control.
Brief breakdown: Started here a few months ago, we lost ISO because we dropped it about 4 years ago. Still some old remnants left of the old super bloated system. My job to rebuild and launch by spring.
Here is how document control has been set up from before I started:
There is one HUGE folder on the network with EVERYTHING in it. Period.
Quality related forms, financial forms, vacation requests, fax cover sheets, one time use flyers, you name it. Around 200-250 forms all together. And this is just for FORMS (Ill attack other documents later). It is a locked down controlled folder.
Since I have been here I have created several new forms and am just now starting to modify some existing forms after reviewing them.
Here is the problem. Everyone here is used to going into the existing messy folder and grabbing their forms. All of the new stuff I have created I have place in a separate folder called "controlled forms". The other old directory is called something else. Problem now is when revising these old forms I have been moving them into the new controlled forms folder and some of the more...how to say....ELDER people are flipping their lids because now their form has moved and now they have to look in two places for forms.
My response would obviously be to create shortcut links and keep all of YOUR forms YOU use in a folder on YOUR desktop.
But that would be too easy. or too hard or whatever.
My second thoughts would be to leave EVERYTHING in that old folder including moving my new stuff in there and all of the revised stuff. Then just creating links on MY desktop to everything I am including in the QMS controlled forms system and placing the shortcuts into a folder on my desktop calling it "controlled forms".
Does anyone see a problem with that?
In essence you would have about 250 forms in a master folder, a small portion of them would actually be QMS controlled forms and the rest just garbage and other forms used for non QMS stuff. I would control the changing of ALL forms and everything in the folder would be locked down from change. The only thing is a lot of those forms would be obsolete, BUT if they are not part of the QMS then does it matter?
I would basically show an auditor MY folder on my desktop the linked shortcuts to all of the stuff that we have decided was curtail to the QMS.
The employees could go about their days oblivious to what was actually part of the QMS or not, all that matters to them is that when they pull of their form that is the latest and greatest.
I hope that all made sense. I'm not exactly excited about that option but its the only thing I can think of aside from just saying "YES, YOU WILL HAVE TO POSSIBLY CHECK TWO FOLDERS FOR YOUR FORM" , and then be subject to extreme elderly furry. Which isn't pretty.
G
G
