I have found several posts, but none addressed alterations needed for use of the form. Let me explain, please.
If a form is drafted, given a form number, and released through the D&D system, can it be altered? Here is a simple example to divine the need.
A form is created for HR for New Employees. On the form, one area has seventeen lines in a table to indicate what software the employee will need for their duties. Seventeen lines were picked because they never thought anybody would need that made. The form has been used for years and has been okay. A new employee is hired in a new role, and that employee needs eighteen different software.
Here is the question. Can the form be altered to insert an extra line for the eighteenth software?
Or would the form need to be revised, sent for approval, and up-rev'ed to the next version?
The next version of the question will be can a new column be added to the table? Keep in mind, these changes are needed to accommodate the intended use of the form.
I would appreciate suggestions.
Thank you to the community
