Re: Which should be documented first? The six mandatory procedures or other processes
Which processes would you advice to document first, the six mandatory procedures or other processes?
Perhaps the sequence doesn't matter at all.
If it helps how you might respond, we are planning to go for ISO 9001 certification next year.
Thank you.
I'm going to tell you from an implementation point of view...
Since the 6 are not usually found in many businesses, and therefore you won't (perhaps) have much experience on how to write them, you probably need some help with those.
For example, since
document and record control are very basic, even
before you start out with anything else, it might pay to get some help to write those and do them first, so that all the other documentation can be reviewed, approved and released/changed to that procedure...
So, before you write anything else, you must have these two basics in place. You can't take corrective action, define and document a process flow, work instruction, etc without document control, at the very minimum! If you have a plan for implementation - defining tasks etc, then you might want to have document control over that too!...
