Its not....
If the the "height" of the cake is Z and you have X and Y
0,0,0 is the middle bottom of the cake then you cut across the dia crossing 0,0,0 then again at 90 degrees to that.... this gives you 4 bits.... then, say the cake is 50mm high (Z) then half rotate the knife 90 deg to the original cuts and pass through X0 Y0 Z25 this doubles the number of bits you have to 8
Thats what I was trying to say!
