Applicability of AS9100 to Aircraft Ground Support Equipment
Chriso
We make ground support equipment for the aircraft industry.
Is there a case that can be made to one of our customers that is requesting AS9100 to be implemented (at least until we are ready to upgrade to AS9100 from ISO 9001:2000) that since our products are "ground support" AS9100 does not truly apply?
Any and all help with this problem is appreciated. :confused:
Re: Applicability of AS9100 to Ground Support Equipment...
I do not believe that the AS9100 standard states that the organization’s products must be airborne in order for the standard to be applicable to their operation. If AS9100 compliance is a customer requirement then it is a valid requirement regardless of the type of product or service you are providing or its end use. Of course, you can always take exception to the requirement but you may lose out to one of your competitors who is willing to comply.
Although I do not know what type of “ground support equipment” you provide, my feeling is that some of that "stuff" is pretty important and can have an (adverse) impact on flight safety.
Sidney Vianna
Post Responsibly
It does NOT make sense for your system to comply with AS9100. The additional requirements of AS9100, compared to ISO 9001 are primarily intended for suppliers of flight hardware. If you try to "artificially" impose AS9100 requirements on to your operation, you might end up with:
  • a bunch of (AS9100 adders) N/A's in your system
  • additional costs with no benefit to compensate
  • an overly strict system that is not perceived by management and workforce as meaningful, thus it will not be sustained.
I hope you can reason with your customer and they are educated enough to understand. The problem typically happens because these mandates come from their procurement function, and buyers are not allowed to waive or provide dispensations. For them, it is easy to say NO. As a recourse, you can always play the renegotiation card. Since they are imposing new requirements onto you, you can go back and state that additional costs will be created and you will have to increase your prices. THAT gets their attention.
Chriso
Re: Applicability of AS9100 to Aircraft Ground Support Equipment...
Thank you Sidney and BadgerMan.
Actually our Registrar for ISO which also does AS certifications does not believe it applies. Although in the "forward" section of AS9100 it seems to imply it is for "use at all levels of the supply chain".
Is there any thing written down somewhere that states AS9100 is not intended for companies that produce "non-flight hardware" as you say Sidney?
:thanx:
I know that it applies in our case, both for airborne hardware and software as well as non-airborne hardware and software such as test sets and such. We build some test sets for our own use as well for use by our OEM customers and our service centers. These items are as critical to flight safety as are our avionics products. Incidentally, this “product” is also impacted by regulatory impositions such as FAA regulations and RTCA document requirements too, similar to the actual airborne product.
That is why I say that it is difficult to make a judgment regarding applicability without knowing more about your product. I am not aware of any language regarding the standard's non-applicability to non-airborne hardware for the reasons I have just noted.
If your registrar believes that it does not apply to your operation, I would use that as justification for exception when responding to your customer's RFP.
al40
I feel your pain, my company is providing support equipment to a major OEM and they called out AS9100, AS9102, and AS9103 requirements in their contract. After many hours of discussion we did convince them that AS9100 was not required, but they would not waver from the AS9102 and AS9103 (Their only buying 20 units), so we were stuck with a take or leave it option.
Best of luck,
Al
Chriso
Thanks Al, would you be able to elaborate on some of the arguments that you used to convince your customer it was not necessary?
:rolleyes:
L
lrsiyer
Chriso,
Kindly think of your business. It may not be required as per AS standards. But you know AS is customer requirement. One of your competitor may be complying and you may lose a customer. More over if you are complied with ISO 9001:2000 only additional requirements need to be focused.
Shankar.
Chriso
Chriso,
Shankar.
Thank you Shankar. I agree with you. The problem is we are currently not ready to focus on implementing the 80-100 additional requirments of AS at this time. Still hoping to find a good arguement on how we could keep the business but only maintain ISO 9001:2000 for the time being.:confused:
al40
:rolleyes:
Chriso,
Sorry it took me so long to get back to you. I'm not sure of your situation, but we just pulled the OEM's own quality requirements that stated that theses units were only going to be used as engineering units and since they were not planning on buying anything further that it was not cost efficent for us to implement AS9100, we are however AS9100 compliant and ISO 9001 certified.
So after lots of emails, I invited their quality folks up to our facility for a sit down to dicuss the quality requirements after reviewing everything with them they agreed that it didn't make any sense to flow these types of requirements down for test units since no further production units would be ordered by them.
Regards,
al40
Y Counterfeit Parts - AS9100 D Cl. 8.1.4 - Can I claim no applicability? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 10
M ISO 9001 and AS 9100 Registrations - AS9100 applicability to a software company AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
B AS9100 Section Applicability for a Design Center's Technical Publications Design and Development of Products and Processes 2
A Applicability of AS9100 Standards to Non Aerospace Products AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
B AS9100 Certification - Applicability to an FAA Certified Repair Service Station Federal Aviation Administration (FAA) Standards and Requirements 25
DuncanGibbons Understanding the applicability of Design of Experiments to the IQ OQ PQ qualification approach Reliability Analysis - Predictions, Testing and Standards 0
A Software as Medical Device (SaMD) definition and its applicability Other Medical Device and Orthopedic Related Topics 4
N EU MDR - Applicability Article 22 Systems and Procedure Packs CE Marking (Conformité Européene) / CB Scheme 4
R Applicability of new non-harmonized standards (MDD/MDR) EU Medical Device Regulations 8
A MDR Article 22 applicability - Legal manufacturer EU Medical Device Regulations 6
K Diagnostic X-ray devices - Applicability of Biocompatibility Testing per ISO 10993-1 Manufacturing and Related Processes 5
V Applicability of IEC 62366-1 usability to resorbable bone substitutes IEC 62366 - Medical Device Usability Engineering 9
E Commission Regulation (EU) No. 207/2012 E-IFU Applicability EU Medical Device Regulations 3
M ROHS : Applicability for AIMDs RoHS, REACH, ELV, IMDS and Restricted Substances 2
L Dying a slow SCOPE death - NEW ISO APG Paper on Scope and Applicability May 2020. AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
M Applicability of Means of Protection, working voltage in an Automated External Defibrillator IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
M Applicability of IEC 60950-1 Table K2 - Minimum clearances between circuits Various Other Specifications, Standards, and related Requirements 0
R Applicability of ISO 14708-3 RF Transmitter and Implantable RF Receiver Other Medical Device Related Standards 1
R Applicability of ISO 14708-3 - RF transmitter and implantable RF receiver Other Medical Device and Orthopedic Related Topics 1
M Oxygen enriched environment applicability - Operating table used in general surgeries in hospital IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
E CB scheme applicability for battery powered medical devices CE Marking (Conformité Européene) / CB Scheme 0
I IATF 16949 - 8.4.2.3 - Applicability to Shipping Suppliers IATF 16949 - Automotive Quality Systems Standard 11
S CQI-12 - Applicability to Raw Materials Customer and Company Specific Requirements 1
C Applicability of ISO 9001:2015 Section 8.5 - Engineering company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Applicability of EN 13795 for Incise Drape EU Medical Device Regulations 0
S Applicability of the standard IEC 60601-2-18 to an arthroscopy pump IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Q Partial non applicability of ISO 9001 Cl. 7.1.5 (not having services)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M User Interface of Unknown Provenance (UOUP) applicability IEC 62366 - Medical Device Usability Engineering 7
E Applicability of Low Voltage Directive (LVD) for 12V equipment CE Marking (Conformité Européene) / CB Scheme 4
M IEC 62304 Applicability - GUI Control Software IEC 62304 - Medical Device Software Life Cycle Processes 3
D Clarification of Applicability of TS 16949 Requirements to a Non-Automotive Business IATF 16949 - Automotive Quality Systems Standard 13
Richard Regalado Sharing a Statement of Applicability (SOA) for ISO/IEC 27001:2013 IEC 27001 - Information Security Management Systems (ISMS) 2
G Not quite old news: Statement of Applicability IEC 27001 - Information Security Management Systems (ISMS) 3
G Question on Statement of Applicability (SOA) IEC 27001 - Information Security Management Systems (ISMS) 2
L TS 16949 applicability for Supplier's Supplier IATF 16949 - Automotive Quality Systems Standard 8
R ISO 22000:2005 Clause 7.10.4 Withdrawal - Applicability and documentation required? Food Safety - ISO 22000, HACCP (21 CFR 120) 3
A Applicability of electrical safety standards to a dedicated PC IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
A Help me understand the applicability of 21 CFR Part 820.198 (Customer Complaints) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Y New Draft FDA Guidance for Applicability of GLP in Medical Device Submission Other US Medical Device Regulations 2
G TS 16949 applicability for Bulk Material Product IATF 16949 - Automotive Quality Systems Standard 25
Q Two AS9102 Applicability and Interpretation Questions AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
R HIPAA (Health Insurance Portability and Accountability Act) applicability Other US Medical Device Regulations 3
E Applicability of Defibrillator Energy Test to Implantable Devices IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
S OEM Supplier of Accessories Registration and 21 CFR 820 QSR Controls Applicability 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
P 7.1, 7.3 and APQP Requirements Applicability in Transfer Case IATF 16949 - Automotive Quality Systems Standard 1
A EN 60601-2-51 applicability to an ECG Event Recorder IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
K Applicability of ISO/TS 16949:2009 to Automotive Parts Manufacturers IATF 16949 - Automotive Quality Systems Standard 13
A AS9100C Clause 7.5 Applicability for Design House AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 6
Richard Regalado Definition SOA - Statement of Applicability Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 0
X Foreign Manufacturer Accreditation Certificate Applicability Japan Medical Device Regulations 8
