L
OK peeps, once again the LAu needs your help.
I've just attended a pre-audit meeting.
They have four quality procedures and it was suggested that one of the procedures should not be audited because it was written in anticipation of something that is planned to happen and it hasn't happened yet.
I say the procedure should never have been published if this activity hadn't even happened, how do they know that the procedure is correct if they have never done it?
I say the procedure should have been documented as the activity happens (if it ever does). Alternatively, if the procedure had to be documented before the activity occurs then surely the procedure should be tested against the activity prior to publication.
A debate ensued as to whether an n/c should be raised against the procedure. Surely yes, b/c the activity hasn't even happened so there is no evidence that they are acting in accordance with the QP. I can't endorse compliance if they haven't even done the activity yet can I?
OK, boys and gals, I leave this one up to you!
Lau.
Lau.
