Calibration Traceability - Fluke 753 dpc with thermocouple Calibrated by Fluke
N
neoth
Hi all,
I have a fluke 753 dpc and i decide to send in to fluke for calibration.
But from the sample cert they send me, fluke only calibrate thermocouple type k measure and source.
My question here is if i use type T for measure and source, and when i issue accredited cert to my customer, is my cert still traceable to fluke cert? Is it still consider iso 17025?
Thanks.
Ninja
Looking for Reality
Re: traceability question
If Fluke will not use a Type T for calibration if you request it, perhaps you would be better off sending it somewhere else...
Something to consider...
BradM
Basically what they are doing is verifying the accuracy of the meter for thermocouples using one curve. There are multiple different curves in the meter (K, J, T, N, S, etc.) So if the millivolt and cold junction compensator is verified to be accurate, then it's just an electronic curve thing to switch from T/C to T/C.
What you should do is contact Fluke and ask if they can check your meter with Type T instead of K.
I am intrigued regarding your issuing an accreditation certificate to your customer. Are you using the Fluke meter to calibrate something for your customer? The Fluke 753 is a process meter; and I wouldn't consider it suitable for calibrating much; especially temperature.
N
neoth
Hi Brad,
Yes i am using this fluke 753 to calibrate my customer type T temperature indicator using simulation method.
I tried I to contact fluke to use type T but they told me it is a standard procedure and they cant change it.
So can my issued cert be traceable to fluke cert if i am using T?
G
Gkokal
Hi Neoth,
The thermocouple functions on process calibrators work on a voltage generated from the two different kinds of metals used in the thermocouple production. If the type k thermocouple measure function passes calibration on the cert, then type T will work just fine. Same for source. It is a voltage signal being tested, not actual temperature.
The thermocouple itself is a different standard, so watch yourself if you are measuring actual temperature.
A Fluke Digital MultiMeter Calibration Traceability and Certificate General Measurement Device and Calibration Topics 11
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Validation of Calibration Methods and Traceability - ISO 17025 ISO 17025 related Discussions 3
T In house Calibration? Measurement equipment traceability requirements - ISO9001 General Measurement Device and Calibration Topics 12
Raffy ISO 13485 NIST Traceability requirements for calibration of test equipment ISO 13485:2016 - Medical Device Quality Management Systems 3
A Is NIST traceability required if a Refractometer calibration is done in-house? Calibration Frequency (Interval) 6
P Importance of Calibration Traceability to the SI General Measurement Device and Calibration Topics 1
R Torque Tester Calibration Traceability and Certificate question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Pipette Calibration & ISO 8655 - No NIST Standard(s) Traceability ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
W Calibration Register - Traceability - Data Transfer to a New System General Measurement Device and Calibration Topics 7
D Calibration Traceability meet AS9100C Requirement? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Traceability for Mercury Argon Calibration Source to Calibrate a Spectrometer? General Measurement Device and Calibration Topics 5
T Class "F" Weight "Certificate of Traceability" Requirements - Calibration General Measurement Device and Calibration Topics 7
D Equipment calibration standard traceability - The basis used for calibration General Measurement Device and Calibration Topics 5
R Outside Calibration - Accredited, certified - Is NIST traceability guaranteed? General Measurement Device and Calibration Topics 8
A Calibration traceability - Profile projector General Measurement Device and Calibration Topics 3
Marc Calibration is the process of establishing a KNOWN RELATIONSHIP - Traceability General Measurement Device and Calibration Topics 0
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
W Next Calibration Due Date Calibration Frequency (Interval) 5
A OEM On-Site Calibration issues during Covid19 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Calibration Certificate Result issued by an accredited external laboratory General Measurement Device and Calibration Topics 9
G Calibration of "Master Parts" Used as Gauges Calibration Frequency (Interval) 5
R Calibration lab environmental monitoring General Measurement Device and Calibration Topics 4
G Calibration of Rotronic probe but not digital readout? General Measurement Device and Calibration Topics 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
T Temperature Requirements For In House Calibration - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
Crimpshrine13 Calibration of pH Meter Probe Calibration and Metrology Software and Hardware 3
F ESD workbench "calibration" Manufacturing and Related Processes 2
F Nist traceable calibration certificates General Measurement Device and Calibration Topics 1
