FRA 2 FDA
I'm with these guys. Make the goal easy retrieval. When you have 63 record files saved in a folder and you need to go back 6 months and find one specific one, how will it be easiest? We do "code" our documents: SYS for SOPs FRM for forms TMP for templates, etc. then each gets a 3 digit #. SYS-001 is Document Control Procedure. The files are titled with the name SYS-001 Document Control Procedure. Easy to find what you're looking for. The "codes" merely help separate categories and the numbers merely help make things searchable, always in the same order, and easy to group together. For records, we do whatever makes sense and makes finding what we need easy. We generate a lot of receiving inspection records, for instance. When I need to find one, I'm probably most interested in which part/material it was. And of course, things are received more than once so we add the date. My receiving inspection records are titled FRM-052 C01-003 11 30. Every one gets a unique title that helps me find what I'm looking for. If I had to search through a year's worth of FTTRFF03, FTTRFF04, FTTRFF05...... I'd quit!
