Hi - I would like to piggyback on this thread. My company is recently been certified to ISO9001:2015 (September 2022). Is there any rules set for a minimum number of years that the company be ISO9001 certified before transitioning to IATF16949. My understanding is that the company has to complete at least 2 cycles of ISO9001 surveillance audit before it can transition to IAT16949. Is that correct? Can you please share any refutable references for this inquiry? Thanks in advance.
There is no such requirement of having ISO9001 CERTIFICATION prior to getting an IATF16949 certification.
If you are certified to IATF16949:2016, it means you are compliant (and certified) to ISO9001:2015 as well, since IATF16949 is not a standalone standard, but contains requirements supplemental to ISO9001.
If your organization is already ISO9001 certified, IATF16949 certification is considered an upgrade, and you'll get some man-days reduction as a result, as per IATF rules (section 5.4.c).
But consider the eligibility criteria for IATF16949 certification first. Your organization is eligible only if it does automotive manufacturing, complies with all requirements of IATF16949 standard (in addition to ISO9001) & CSR, has 12 months' performance data (internal & external) available, and completed 1 cycle of internal audits & MRM.
You can also refer to IATF rules to gain more understanding and contact your Certification body to guide you regarding the certification process.
