Defect Codes
You want examples of defect codes?
Another style is: Motor Defect Codes.pdf
Or...
OR.... Are you referring to analysis aspects?
213.4 Excepted track
4.01 Excepted track segment not identified in appropriate record.
4.02 Excepted track segment located within 30 feet of an adjacent track subject to simultaneous operation at speeds in excess of 1 0 mph.
4.03 Excepted track not inspected in accordance with 213.233(C) and 213.235 as specified for Class 1 track.
4.04 Train speed exceeds 10 mph on excepted track.
4.05 Occupied passenger train operated on excepted track.
4.06 Freight train operated on excepted track with more than five cars required to be placarded in accordance with 49 CFR Part 1 72.
4.07 Train with a car required to be placarded by 49 CFR Part 172 operated over excepted track within 100 feet of a bridge or in a public street or highway.
4.08 Failure to notify FRA of removal of trackage from excepted status.
213.7 Designation of qualified persons to supervise certain renewals and inspect track
7.01 No written record of names of qualified persons to supervise restorations and renewals of track under traffic and/or to inspect track for defects, or to pass trains over broken rails or pull-aparts
7.02 Failure of track owner to provide written authorization to qualified designated individuals.
7.03 Failure to use qualified person to pass trains over broken rails or pull aparts.
7.04 Train speed exceeds 10 m.p.h. over broken rails or pull aparts.
7.05 Failure to promptly notify and dispatch person fully qualified under § 213.7 to the location of the broken rail or pull apart.
213.9 Classes of track; operating speed limits
9.01 Failure to restore other than excepted track to compliance with Class 1 standards within 30 days after a person designated under 213.7(A) has determined that operations may safely continue over defect(s) not meeting Class 1 or excepted track standards.
9.02 Failure of track owner to enforce, over Class 1 defects, the limiting conditions imposed by person designated under 213.7(A).
9.03 Unused
213.11 Restoration or renewal of track under traffic conditions
11.01 Proper qualified supervision not provided at work site during work hours when track is being restored or renewed under traffic conditions.
213.33 Drainage
33.01 Drainage or water-carrying facility not maintained.
33.02 Drainage or water-carrying facility obstructed by debris.
33.03 Drainage or water-carrying facility collapsed.
33.04 Drainage or water-carrying facility obstructed by vegetation.
33.05 Drainage or water-carrying facility obstructed by silting.
33.06 Drainage or water-carrying facility deteriorated to allow sub grade saturation.
33.07 Uncontrolled water undercutting track structure or embankment.
213.37 Vegetation
37.01 Combustible vegetation around track-carrying structures.
37.02 Vegetation obstructs visibility of railroad signs and fixed signals.
37.03 Vegetation obstructs passing of day and night signals by railroad employees.
37.04 Vegetation interferes with railroad employees performing normal trackside duties.
37.05 Vegetation prevents proper functioning of signal and/or communication lines.
37.06 Excessive vegetation at train order office, depot, interlocking plant, a car man's building, etc., prevents employees on duty from visually inspecting moving equipment when their duties so require.
37.07 Excessive vegetation at train meeting points prevents proper inspection by railroad employees of moving equipment.
37.08 Excessive vegetation in toe paths and around switches where employees are performing normal trackside duties.
37.09 Vegetation brushing sides of rolling stock.
37.10 Vegetation obstructs visibility of grade crossing warning signs and signals by the traveling public.
213.53 Gage
53.01 Gage dimension exceeds allowable on tangent track.
53.02 Gage dimension is less than allowable on tangent track.
53.03 Gage dimension exceeds allowable on curved track.
53.04 Gage dimension is less than allowable on curved track.
53.05 Gage dimension exceeds allowable for excepted track.
213.55 Alignment
55.01 The alignment of tangent track exceeds the allowable deviation.
55.02 The alignment of curved track exceeds the allowable deviation for a 62-foot chord.
55.03 The alignment of curved track exceeds the allowable deviation for a 31-foot chord.
213.57 Curves; elevation and speed limitations
57.01 Unused
57.02 Operating speed exceeds allowable for 3-inches of unbalance, based on curvature and elevation.
57.03 Operating speed exceeds allowable for 4-inches of unbalance, based on curvature and elevation.
57.04 Operating speed exceeds allowable for a FRA approved unbalance based on curvature and elevation approved for track contiguous to high speed track.
57.05 Unused
57.06 Maximum cross level on curve exceeds allowable.
Sales Locations
213.63 Track surface
63.01 Runoff in any 31-feet of rail at end of raise exceeds allowable.
63.02 Deviation from uniform profile on either rail exceeds allowable.
63.03 Unused
63.04 Unused
63.05 Deviation from zero cross level at any point on tangent exceeds allowable.
63.06 Unused
63.07 Difference in cross level between any two points less than 62-feet apart on tangents exceeds allowable.
63.08 Difference in cross level between any two points less than 62-feet apart on curves between spirals exceeds allowable.
63.09 Difference in cross level between any two points less than 62-feet apart on spirals exceeds allowable.
63.10 Reverse elevation on curve exceeds allowable.
63.11 Variation in cross level on spirals per 31-feet due to physical restriction on spiral length and operating practices exceeds allowable.
63.12 Difference in cross level within 62-feet between a point on a curve that equals or exceeds 6-inches and a point with greater elevation exceed allowable.
63.13 Cross level differences for six or more consecutive pairs of staggered joints exceeds allowable.
213.103 Ballast; general
103.01 Insufficient Ballast
103.02 Fouled Ballast
213.109 Crossties
109.01 Fewer than minimum allowable number of non-defective ties per 39 feet [not used after 09/21/00]
109.02 No effective support ties within the prescribed distance from a joint.
109.03 Crossties not effectively distributed to support a 39-foot segment of track.
109.04 Fewer than minimum allowable number of non defective ties per 39 feet for tangent and curved track less than 2 degrees [effective 09/21/00].
109.05 Fewer than minimum allowable number of non-defective ties per 39 feet for turnouts and curved track over 2 degrees (effective 09/21/00)
`109.06 Track constructed without crossties does not effectively support track structure.
Or...
GRADING CODES:
PR = Poor
FR = Fair
GD = Good
VG = Very Good
FN = Fine
VF = Very Fine
Grades refer to the condition of the dust jacket. The book, unless otherwise indicated, equals or exceeds the condition of the dust jacket. For Picture Cover editions or books without dust jackets the grading refers to the book . The number in ( ) indicates the highest series number listed on the dust jacket flap or rear boards of picture cover editions.
SPECIAL DEFECT, FORMAT & GRADING CODES
AC = Applique Cover (Illustration mounted to the board of the book)
AUTO = Autographed by the Author
B&H = Published by Barse & Hopkins
BK# = Book # handwritten on Book Spine
BCP = Blackened Cover Price
BP= Book Plate Present BURT = Published by A.L. Burt
C&L = Published by Cupples & Leon
CMB = Check Marks on Back Cover
CS = Cover Scrape (Usually from a price tag)
D&M = Published by Dodd, Mead & Company
DJ = Dust Jacket
DONO = Donohue
DS = Dampness Stain
FCC = Front Cover Chipping to Dust Jacket
FCF = Front Cover Fading to Dust Jacket or Picture Cover
FED = Front Endpaper Damage
FEM = Front Endpaper Missing
FFD = Front Dust Jacket Flap Damage
FFM = Front Dust Jacket Flap Missing
FL = Frontispiece Loose
G&D = Published by Grosset & Dunlap
INT = Glossy Internal Illustrations Present
IP = Inscription Present on Front Endpaper
L&S = Published by Lee & Shepard
LBE = Library Bound Edition
LL&S = Published by Lothrop, Lee & Shepard
LRE = Library Rebound Edition
LSC = Lower Dust Jacket Spine Chipping
MSS = Minor Smoke Stain to Dust Jacket and/or Book
MTS = Minor Tape Stain
NP = Former Owner's Name on Front Endpaper
OPS = Original Price Sticker Present
OT = Original Text
PB = Paperbound Edition
PC = Picture Cover Edition
PL = Page(s) Loose
RCC = Rear Cover Chipping to Dust Jacket
R&B = Published by Reilly & Britton
R&L = Published by Reilly & Lee
REM = Rear Endpaper Missing
RFD = Rear Flap Damage
RFM = Rear Dust Jacket Flap Missing
RRT = Reverse of Dust Jacket Reinforced with Tape
SB = Spine of Book Slightly Bent
SCH = Dust Jacket Spine Chipping at Top and Bottom
SDS= Slight Dampness Stain to DJ
SSD = Slight Darkening to DJ Spine
SSF = Slight Spine Fading to Dust Jacket or Picture Cover
SF = Severe Spine Fading to Dust Jacket or Picture Cover
SP# = Book # handwritten on Dust Jacket Spine
SS = Severe Smoke Stain to Dust Jacket or Book
SSP = Slight Dust Jacket Spine Chipping
SSD = Slight Dust Jacket Spine Darkening
TS = Severe Tape Stain or Tape Present on Dust Jacket
USC = Upper Dust Jacket Spine Chipping
WA = Wrap Around Illustrated Dust Jacket
WS = Waterstain to Dust Jacket or Book
[$] = Suggested Selling Price Box on Front Cover
