Measuring Solid Thread Ring Gages
  • Thread starter Thread starter Calibration Kid
  • Start date Start date
It looks like the CONSTANT in your formula is the same as what I found in the table from Threadcheck, just formatted differently. I assume that you take your constant and subtract it from your "over wires" measurement to get the pitch diameter.
CONSTANT = [1.93335 X (1/PITCH)] - [2.9939 X BALL/WIRE SIZE]
The formula I got from the Threadcheck table, for Acme Screws, is:
E = M -[ 4.9939 G - 1.933357]
n
Where E is the Pitch Diameter, M is your "over wires" measurement, G is the wire / ball diameter, and n is threads per inch. Multiplying the minus sign through the brackets you get:
(1.933357 / n) - (4.9939 * G)
which matches your "Constant" formula except for the 4.9939 factor instead of your 2.9939.
I see.
I have the formula entered into an excell spreadsheet.
=SUM((1.93335*(1/E5))-(2.9939*E6))
E5 being the Pitch(3.5) and E6 being the Ball Size(0.12908")
When I change the 2.9939 to 4.9939 it makes my constant negative(-0.09223) and throws my pitch diameter way too high :(
I will have to ask them where they got this formula. They may not respond to me though, I have already asked them for so much help.
The formula from P&W for the Labmaster software computes pitch diameter like this:
PD = M - P(cos a) + B
Where PD is the Pitch Diameter
M is the measurement using the ball probe
P is the Pitch (1/TPI)
a is the half angle of the thread [29?/2 = 14.5? for Acne threads]
B is the ball size
Manufacturers PD=5.18566"
Using my old formula, PD=5.18046"
Using the formula you found, PD=5.19885"
5.34639-0.285714(cos(14.5))+0.12908
Does that look like I did it right?^^
Are you using a Labmaster Universal with a T-Probe? We have one here, but since we do solid thread rings on our OPAL 600 ULM, I haven't bothered to look into the process on our Labmaster yet. I can check it out if you are still having trouble and let you know what I find on mine.
Solid thread rings are checked against a hi-lo setting plug. It's a very simple pass/fail calibration- but they are expensive set plugs.
I don't think you can use the general 3 wire calculation for this process because you are not using wires.
Yes, ULM with T probe that has different ball probes that can be interchanged.
And yea still have not resolved the issue.
Exactly, they are expensive. We have a lot of customers with solid thread rings for really random sizes.
Guessing you must be using a different ball size then what is in the book-
I have a newer Universal- and maybe the ball sizes have changed- I have 6 sets.
A: 0.011811
B: 0.019685
C: 0.031250
D: 0.046880
E: 0.06250
F: 0.093750
None of these are suited to an 3.5 Acme, so Pratt & Whitney must make some larger ones that are not in the book?
Anyhoo- I am not comfortable with the fact that Pratt & Whitney's formula is a straight basic formula. Acme wire constants are not a simple constant calculation like 60? threads- you need to know that size of the thread in order to calculate the constant- so I imagine that it would be the same concept in this case.
Using a wire diameter formula strikes me as incorrect as well because the geometry is different, and then the whole 2 ball, 3 wire thing makes me wonder as well.
You mentioned it before- is it all internal threads you are having a problem with- or just acmes?
Yea, it is not a Pratt & Whitney probe. The previous owner had a custom probe made. We have a whole set of different sized ball probes that you can screw into the probe body.
And yes I have had the same thoughts. I just don't know where to find the correct answer. I have searched and searched.
The only internal threads I have had to check so far are ACME unfortunately, so I don't know if all internal threads are giving me problems.
