Modifying an old printed record? ISO 9001
Q
QAMTY
Hi all
Recently we ran an audit and a NC was raised because in two paper printed records several fields were not filled up and some others were not so legible.
Due to that NC, a CA was registered in the System.
but one plan was to correct such records.
But I started to doubt about that, because I think a record is a snapshot of certain time and if such records are modified, then the records really are not reliable.
What is your opinion ?
Other point, is about an electronic record, how can we be sure about the reliability, because is changing dinamically (database, not a pdf file), and is not possible to go backwards and show the record at certian date/time.
Your insights are welcomed.
Marc
Fully vaccinated are you?
A record is a snapshot of a specific instance.
1. Two records out of how many total records? While noted, it doesn't sound like a recurring and/or wide spread problem.
Changing a record is definitely not advisable - In my opinion it is never allowed with the possible exception of a single line mark through an inaccurate entry, and initial, date and reason. In some industries, it is illegal to alter a record. In fact, some countries have banned or restricted the sale of correction fluid (aka "white-out") to prevent changes to records.
Wikipedia reference-linkCorrection_fluid
If it is an old record and currently you use electronic records it could be argued that the nonconformance is not valid because your record keeping system/method has changed. In addition, has there been a previous finding of incomplete records and/or incorrectly completed or illegible records which you have done a corrective action for?
When an auditor finds an old record, beware. How far back in time is the auditor going? Add in that if your system has changed, which it sounds like it has, you can not do a non-conformance on a system which is no longer in use.
2. Records do not change, electronic or paper. If a database is changing records you have a serious problem.
Document vs. Report vs. Record - What are the differences?
Form vs. Record - What is the Difference between a Form and a Record
AMIT BALLAL
Correcting the record won't be a good idea. And it is old, therefore is also not relevant. Instead of this action, you can check what information was missed, whether it had any impact on customer / product / service. This can be the temporary action for closure of nonconformity.
:2cents:
Mike S.
Happy to be Alive
CORRECTING a record is perfectly fine.
CHANGING a record can get you in trouble, even jail time, depending on what it is.
You should have a procedure for CORRECTING errors in records. Ours basically involves lining through the original entry so it is still visible as to what it originally read, and correcting it beside that, and signing and dating the correction. Depending, you may also wanna attach an in-depth explanation.
That would be my approach as well. Our paper based records are few and far between, but that makes no difference.
P
PaulJSmith
Lining through as Mike suggested is an acceptable practice, even in the tightly controlled world of the aerospace industry.
Another practice we occasionally engaged in while I was in that industry is to "recreate" the questionable document as a new, legible copy, mark it as such and explain the reason for it's existence, and attach the original to it. You gain a complete or legible document, yet still retain the unaltered original as well.
Marc
Lining through as Mike suggested is an acceptable practice, even in the tightly controlled world of the aerospace industry....
Yeah - I mentioned that as well in my post. But on OLD records my opinion is it would be more questionable. And, as I said, it really needs an initial (at the least vs. a signature), a date and preferably a reason stated somewhere if not on the document.
EDIT: Ninja'd by Mike, too.
Ajit Basrur
I would approach slightly differently. Since the CAPA is already initiated, and as part of "Correction",
review if the missing data on the record impacts the product or the disposition of the product. If it does, this would roll into a bigger Impact Analysis. If the missing data has no impact on the product and is a low risk, try to collect all the supporting data to fill the missing gaps. Also check if there were any additional records that could be impacted.
Correction to old records is acceptable but all corrections should refer the CAPA number and all people involved may have to re-sign. Also look out if customer has to be informed.
QAMTY, could you let us know what these two records were ?
P
PaulJSmith
Yeah, on older records, it's probably best just left alone, especially if, as also alluded to above, it's from an older system that is no longer in use. If that's the case, it kind of smacks of an unnecessary NC.
If the decision is made to correct, then I am a strong proponent of the single line though / initials / date method. A traceable quality stamp and date would be even better. It was a rare occasion when we would recreate a document, but it did happen.
Marc
Yeah - I think we all pretty much agree. I'm just a bit of a stickler on recording the reason for the "change" somewhere (even in today's electronic world). Sticks with me from my DoD paper days. No pencils, black ink only entries, single line-through, no white-out, a traceable responsibility (had to be a person, not a department or position), a date and the reason for the change.
A MDR article 54(2) "modifying" EU Medical Device Regulations 1
kedarg6500 Selection of proper modifying agent for Aluminium Silicon Alloy Manufacturing and Related Processes 2
P Is a new 510k needed if modifying to add bluetooth for data transmission? Other US Medical Device Regulations 13
J Modifying the Quality Manual - How Might This Affect our Audit? Quality Management System (QMS) Manuals 1
F Philippines: Old Certificate of exemption for Class B device and new LTO. How to proceed? Other Medical Device Regulations World-Wide 0
B "Old" devices - MDCG 2021-25 EU Medical Device Regulations 3
R How to keep old versions of work instructions from being used at point of use? ISO 13485:2016 - Medical Device Quality Management Systems 20
J Old procedure review and training requirements Document Control Systems, Procedures, Forms and Templates 9
G Significant changes on MDD devices/Old Devices after MDR transitional period EU Medical Device Regulations 2
J Superseded Specs and old drawings Various Other Specifications, Standards, and related Requirements 19
M How to answer ISO9001:2015 audit finding of old revisions of documents being used? Document Control Systems, Procedures, Forms and Templates 8
R Old computers available Buy, Sell or Trade - NO Commercial Advertisements 2
M Why are EU harmonized particular standards so old & out-of-date? IEC 60601 - Medical Electrical Equipment Safety Standards Series 11
Q New QMS...Old Projects ISO 13485:2016 - Medical Device Quality Management Systems 5
M Old Master Schedules - How Long to Keep? Document Control Systems, Procedures, Forms and Templates 4
G Adopting old product - compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 12
I Old Time Scatter diagrams for defect type and location- software Quality Tools, Improvement and Analysis 7
C Refreshing an old and boring topic - Job descriptions and Roles vs Process Documentation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
Q Old products new class - Dental Devices - Choosing tests EU Medical Device Regulations 2
K Old medical devices -> 7.3.7. Design and development validation ISO 13485:2016 - Medical Device Quality Management Systems 1
M Interesting Discussion Curious old drawings about electrical shock and safety IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Marc Interesting Discussion The periodic table is 150 years old - March 2019 Coffee Break and Water Cooler Discussions 3
Marc Old Registered Visitors "Pruned" from the Database - 20180916 Forum News and General Information 0
Marc 200-year-old museum in Rio de Janeiro Destroyed by Fire - 2 SEPT 2018 World News 2
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
Marc Adventures in Design Quality Assurance - Two-week-old Pixel 2 XL displays World News 0
A Training Program Help - Old docs, new docs, so many docs... ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Canada License Amendment - Old Product to New Product Canada Medical Device Regulations 2
B Old GD&T Symbol "~" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
L Sources for Searching Old Electronic Parts Specs (Counterfeit Inspection) Quality Manager and Management Related Issues 3
G Customer wants PPAP on Old Parts to New Standards APQP and PPAP 8
A Technical File Maintenance - Old generation product EU Medical Device Regulations 4
A PUWER (Provision and Use of Work Equipment Regulations) and old machines (UK rules) Occupational Health & Safety Management Standards 4
E I'm looking for old publications of European Quality in pdf Book, Video, Blog and Web Site Reviews and Recommendations 2
J How to Retrofit an old, manual CMM Calibration and Metrology Software and Hardware 5
C Upgrading an old Supermicrometer General Measurement Device and Calibration Topics 3
S Old Medical Device Software Submission Guidance from 1998 Other US Medical Device Regulations 8
G Not quite old news: Statement of Applicability IEC 27001 - Information Security Management Systems (ISMS) 3
R IMDS time frame submission for a very old product APQP and PPAP 1
M Old software and EN 62304 - ECG software for the display of ECG IEC 62304 - Medical Device Software Life Cycle Processes 2
W Where to find the Daimler DBL 6992 10 new (old) standard Customer and Company Specific Requirements 1
P Performance Qualification of old Rapid Mixer Granulator Qualification and Validation (including 21 CFR Part 11) 2
Q IQ Requirements for Old (10 yrs) Commissioned Equipment Qualification and Validation (including 21 CFR Part 11) 2
R Covegratulations to The Cove: 18 years old! Covegratulations 3
N FDA Aspects - No Improvements to 12 Year Old Software ISO 13485:2016 - Medical Device Quality Management Systems 4
T Software that will overlay Old Revision and New Revision Print and Compare Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
M Old MSDS Sheets vs new HCS Standard - Format Requirements Manufacturing and Related Processes 18
H Digging Up Bones - Inspector Retrieving Very Old Inspection Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
V Old 510(k) with no Indication Statement 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
K Retrospective DHF for an old non-registered device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
