For the ISO 9001:2015 implementation is it doable to implement (run awareness and start documenting) in parts or should implementation start at the end of document completion?
There is a couple of different views within the organization I work with so I would appreciate the help.
Seini1, further to Jen's good comments, I suggest you see it this way:
Your company already has a QMS in place, else it wouldn't be in business. Your company's QMS is not compliant with the standard, and it is not documented, and it doesn't work as you'd like. But it exists. In this perspective, there is no question of implementation. What you're doing is documenting and improving, and at some point in this quest, your system will be compliant with the standard.
The funny thing is that as part of this quest, you'll create a continuous improvement process. With this process, if it works, there is never an "end of document completion". A compliant QMS is always improving, and most such improvements will be documented. So, yes, implement improvements as soon as practical. Once you close all your gaps with a compliant system in all your processes, you'll get a certificate, and you'll be well on your way to Quality.
