Definition Sort vs. Rework - Differences and Definitions
Beth Workman
I am in a discussion with my internal auditor about the difference of a sort vs rework. Our NCR process defines rework as
"Any operation that results in the alteration or modification of a completed nonconforming part, or lot of nonconforming parts, necessary to deem the end product to be compliant with the customer?s specification."
And in many threads I have found a similar definition.
My auditor purports that a sort should be considered rework, however, I argue that it is not. Any nonconforming product is not altered or changed, it becomes scrap.
What are your thoughts?
Thanks!
Re: Sort vs Rework
To me sort is the activity of separating good parts from questionable parts. It is possible that the sort will reveal only good parts. It would not be a good thing to call these rework.
Once the sort is complete, then disposition will have to be made of the questionable parts. One of those dispositions may be rework, as you defined it.
The act of sorting is not rework, in my opinion, because as I mentioned above, it is possible that all the parts will turn out to be conforming.
bi-lo
Re: Sort vs Rework
Rework is very specific to an operation, so I'm not sure if auditor's definition may work for you. And I think rework can occur and be handled from different operation/production stages e.g; pre-packaging, post-packaging. (shrug)
I think the distinction between reworking and sorting is worth preserving in most instances. There are places where any nonstandard operations are classified as "rework," which in those instances means "extra" work.
In your case, because you have a definition in place, and because it usually is important to distinguish between modification and sorting, the definition should speak for itself and the auditor is off base.
TPMB4
From a purely definition point of view they are different but I suppose I can see how some might view sort as a type of re-work.
IMHO you sort to separate one thing from another, you only re-work when a change to the item is made. These are different operations and to my mind are sufficiently distinct to prevent confusion. I guess any organization can define sorting as re-working if they so choose. A system needs definitions and within reason I think they can be defined to suit. Discuss it further with the auditor as it is your system's definition not his. If he can show something defined in the relevant standard to back his view then you can't argue your point but I reckon it is not there.
in your case I would agree with you, but I'm curious: Why does this matter to the auditor? is it merely a semantical disagreement or are there consequences based on whether something is 'rework' or 'sort'.
A different perspective: in some industries, sorting involves opening finished goods packages or kits of materials. The bad stuff is removed and replaced and then the material has to be repackaged. in regulated industries requiring an agency to 'approve and release' material for sale, the reporting paperwork may have to adjusted or amended if already submitted. This is all 'rework' of work previously performed, even it isn't the technical 'manufacturing' work. And the common language used in these industries is that a 'sort' is a form of rework'. It doesn't sound like this is the case for your organization, but it is a valid alternative universe.
I
isoalchemist
Semantics are always fun, but I agree with Bev that "sort is a form of rework".
If you truly pick apart your auditors definition IMHO when you decide to sort you are basing it on some criteria and that could be considered a lot or series of lots. The act of sorting is changing that lot (eliminating the bad) so their definition fits.
Does it really matter how you classify it? it really depends on the industry and the company culture. It is added work and hence expense and needs to be accounted for. How it's done is really up to the company.
P
PaulJSmith
Hi, Beth.
Perhaps you could try this approach:
Ask your Auditor if balancing their checkbook is the same as paying a bill.
Ask your Auditor if looking at their vehicle's fuel gauge is the same as refueling it.
Ask your Auditor if picking out fruit at the grocery store is the same as eating it.
Sorting out how much money you have does not pay the bills.
Sorting out how much gas you have does not fill the tank.
Sorting out which fruit looks best does not feed the hunger.
Any more than ...
Sorting out which product is nonconforming does not make it conform.
Each example is only an accounting (sort) of what you have, which still requires follow-up action (payment, refueling, eating, reworking) to resolve it.
Or ... you could just point to your definition and note the lack of any mention of sorting.
Beth Workman
Thanks to everyone, I'm sure that we will continue a good debate on this when we next meet.
WCHorn
Rubber, Too Glamorous?
There are industries in which sorting is a planned production operation performed because the state of the art of manufacturing does not produce 100% conforming product.
If the production sorting operation is duly completed and deemed to be necessary to repeat because the sampling plan rejected the lot, isn't that re-sorting a rework operation (repeating a production operation)? It seems to fit the ISO 9000 definition of rework in paragraph 3.6.7: "action on a nonconforming product to make it conform to requirements."
No disagreement with auditors or anything like that; I'm just preparing myself for the conversation should it arise. What do you think?
Q Rework vs. Inspection and Sort - What is considered rework? Misc. Quality Assurance and Business Systems Related Topics 19
G When does containment event not require 100% sort? Nonconformance and Corrective Action 5
leftoverture Handling Sort/Return Requests Customer Complaints 8
V Supplier Capability and 100% Sort causing Gage Wear APQP and PPAP 1
V PPAP - Requirements when Cpk is <1.67 - 100% Sort for Defectives APQP and PPAP 8
Marc A sort of Automotive Internet World News 3
C Minitab Column Sorting Issue - Invalid variable(s) to sort Using Minitab Software 9
D What sort of information can I furnish for a Level 2 PPAP? IATF 16949 - Automotive Quality Systems Standard 1
G 100% Sort Verification - Statistical Method for Evaluating Suspect Material Statistical Analysis Tools, Techniques and SPC 19
A How should I implement work instructions when we are sort of a job shop? Document Control Systems, Procedures, Forms and Templates 6
T Product / Service Life Cycle Quality - Whose Responsibility to Sort, etc.? Philosophy, Gurus, Innovation and Evolution 1
J Interview Question: How do you sort problems? Quality Tools, Improvement and Analysis 2
L Verification of 100% Sort QS-9000 - American Automotive Manufacturers Standard 11
D Looking for 100% sort testing equipment for overall length, flatness, and parallelism General Measurement Device and Calibration Topics 1
Marc 5-S - Sort, Straighten, Shine, Standardize, and Self Discipline Quality Tools, Improvement and Analysis 11
N PFMEA for rework, disassembly (automotive). FMEA and Control Plans 5
I Rework 8.7.1.4 IATF 16949 - Automotive Quality Systems Standard 10
C. Tejeda Process validation of rework assembly methods (medical devices) Medical Device and FDA Regulations and Standards News 3
B Rework of a medical device EU regulations EU Medical Device Regulations 5
C 21 CFR 820.90 - Documenting rework and reevaluation in DHR 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
N FPY requested for an industry that does not have rework IATF 16949 - Automotive Quality Systems Standard 4
R Rework on DHR Other Medical Device Related Standards 7
S Operation of possible rework in control plan FMEA and Control Plans 8
Z AS9100 Control of Nonconforming Outputs - Rework Dispositions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
J Rework or Recall 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
T ISO 13485 8.3 - Non-Conforming Materials - on-line rework or part of process? ISO 13485:2016 - Medical Device Quality Management Systems 11
G Rework, Reprocess, or Correction - A simple blurred letter on the legible etching ISO 13485:2016 - Medical Device Quality Management Systems 4
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Generic Rework/Reprocessing Procedure Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
L I need an example rework procedure/instruction for injected plastic parts Document Control Systems, Procedures, Forms and Templates 2
M IATF 16949 Cl. 8.7.1.4 - Risk analysis for decision making about rework IATF 16949 - Automotive Quality Systems Standard 2
T Is Sorting a kind of Rework? IATF 16949 - Automotive Quality Systems Standard 3
M IATF 16949 Clause 8.3 - Rework Records Requirements IATF 16949 - Automotive Quality Systems Standard 1
G Severity in Process FMEA for Rework Process FMEA and Control Plans 1
M What is the value of documenting in-process rework for easily-detectable issues? Quality Manager and Management Related Issues 4
G Rework requirement in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 5
R How to document the Risk Management on Rework activities ? ISO 14971 - Medical Device Risk Management 6
S Regulatory Approval(s) for Rework Dispositions Nonconformance and Corrective Action 2
B Form to use for Rework including Verification of Effectiveness of the Rework Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S How to establish a Sampling Plan from the Rework percentage? AQL - Acceptable Quality Level 6
A Nonconformances and Rework in a Machine Shop Nonconformance and Corrective Action 6
X Help with ISO 13485 Clause 8.3 "Rework" as applicable to Medical Device Servicing ISO 13485:2016 - Medical Device Quality Management Systems 39
D Rework Authorization Form example Manufacturing and Related Processes 5
R Medical Device Circuit Board Component Changes - Is this rework or not? ISO 13485:2016 - Medical Device Quality Management Systems 8
M Rework Devices placed on the market - IEC 60601-1 Requirements 3rd edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
D Lean Management applied to Rework Zones Lean in Manufacturing and Service Industries 8
Q Documenting the Review of Adverse Effects from Rework ISO 13485:2016 - Medical Device Quality Management Systems 4
Q ISO 9001 Clause 8.3 Rework Verification - Re-verification to demonstrate conformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Soldering Training (specific to Rework and Repair of PCBs) - Long Island Training - Internal, External, Online and Distance Learning 5
P Requirements for Approval of Rework Work Instructions ISO 13485:2016 - Medical Device Quality Management Systems 6
