U
UlikSulit
Good day! I am finally happy that my search lead me to this forum. I really appreciate it. I have a question for a device that soon will undergo to a 60601-1 inspection and I hope someone can help me.
It is class II with type B applied parts, PSU with 2 MOPP, secondary circuits at 12Vdc, metallic enclosure and there is an usb connector for data transferring to the customers computer.
There are two independent PCB inside the device, one that contains the above mentioned PSU that powers a plate applied to the patient, the other PCB is indipendent and contains an USB hub board that will be powered directly from a computer , the frame of the usb connector is also contacting the frame of the enclosure which is metallic and not earthed. My question is what kind of insulation should the usb provide considering it will be just for operator use? The measurements of touch currents with mains applied on the usb will cause this test to fail since the enclosure of the device cotact the external frame of the usb connector, Can we skip this test providing appropriate instructions? Thank you for your effort and many regards!
