Hi All, I please had an interesting question about “Expected Service Life” (ESL) per the standard IEC 60601-1. There are several semi-related forum threads about this topic but none of them cover this particular question, so please don’t move/delete this thread. The regulations, guidances, and standards are super clear for devices that are provided sterile, but there’s nothing for reusable medical devices.
Per IEC 60601-1, you need to define an Expected Service Life (ESL). My own device, for example, is a Class 2 reusable device that is not provides sterile and must be reprocessed (cleaning & autoclave sterilization) for intended use in the sterile field of an operating room. The ESL is the starting point and can be a business decision (i.e. device ESL is 5 reprocessing cycles).
If you have a device with an ESL of 5 reprocessing cycles, then sure it would make sense to just pay a laboratory to clean & sterilize the device 5 times, and then do visual/functional testing on it to confirm it will works. But what do you do if your ESL is instead 50 reprocessing cycles (or an even higher number)? It can easily cost tens of thousands of dollars to pay a test lab to run 50 cycles on even 1 device, let alone multiple devices for a statistical sample size for testing.
In an IEC 60601-1 test lab, they only ask for the device to be cleaned & sterilized only 1 time, to do their testing.
But on the other hand, you need to address risks of “ESL” by implementing “risk controls”, which feed into your “Design Inputs”, and each Design Input thus requires a “Design Verification” (either an analysis review or a formal test with acceptance criteria). So now are you actually forced you to run the device for 50 reprocessing cycles?
Am I also forced to write a specific product requirement (“Design Input”) stating that my device must remain functional after 50 reprocessing cycles?
Is this all governed by industry best practices or is there an actual standard/regulation that helps? Do different rules apply if your reusable medical device has a lot of plastic components? (More effects from cleaning & autoclave sterilization).
