What is an uncontrolled copy of a controlled document?
Andy Bassett
I see in many companies documents with 'uncontrolled copy' stamped on it.
Which part of the ISO Standard is driving this? Is it not possible to circulate copies of documents as and when required, and simply state in your Documentation Guidelines that all documents have to be presumed to be uncontrolled and that if they want an original they have to go to the either the EDP server if it is a EDP file, or to the Drawing Cupboard if it is for example a hardcopy.
The alternative seems to be to stamp on the offending document 'Uncontrolled Copy', and the result is that theoretically nobody could or should work from such documents.
Regards
Andy Bassett
Andy B
Marc
The stamp idea is a real 'oldie'. Basically you should identify what is controlled and everything else is 'for reference only'. You don't need to stamp it or such perISO 9001.
So - document control drives it in some companies with old ideas - my opinion. It is important that everyone know what is controlled and why.
This all comes down to people making decisions. For example, most engineering functions have documents of external origin as an issue because significant decisions are based on things like customer prints. Companies which use stamps (or labels, etc.) use them to identify documents upon which 'significant' decisions must not be made. In my implementations I encourage companies to ensure the theory / reasoning is understood (at all levels!) so they don't need stamps or labels. The last client I had which used stamps in this way was back in 1996.
Derek
Depending on the size of the organisation will depend on the best method of controlling documents. For smaller organisations I have seen the controlled copy only stamped and or signed. The uncontrolled copy is not stamped. In larger organisations I have used a barcode system where the controlled copy has a barcode label stuck on the front. The controlled documents are registered and the formal distributions also recorded. Therefore the uncontrolled copies either do not have abarcode label or a photocopy of the label. All staff are aware of whats a feral document and may not be the latest & greatest.
"What is a uncontrolled document?"
Level I and II documents submiited to a customer for review.
All documents/drawings/literature that effect the quality of the product during the decision making/verification/validation process are required to be controlled copies.
I see no need for any document/drawing/literature to be stamped,or otherwise identified,as uncontrolled/for reference only. Dispensing of such items causes confusion and endless dicussion about their use.
E
energy
4.5.2 (c) " any obsolete documents retained for legal and or KNOWLEDGE-PRESERVATION purposes are suitably identified" What easier way to identify those documents other than a de-controlled stamp, regardless of what century? This stamp is available at all copiers and is to be used sparingly. As long as you state this practice in your procedure, not to worry. Opinions don't matter.
G
Greg Mack
Dear Andy,
A simple definition of an "Uncontrolled Document":
A document that is not maintained or updated. Uncontrolled documents do not have a traceable distribution. Uncontrolled documents should be current at the time of issue and marked appropriately, at least with the words “uncontrolled”.
I think that should clarify your thoughts on this subject in addition to what the others have mentioned.
I recently reviewed one of my companies suppliers and their approach to controlled/ uncontrolled documents. His system masters were based electronically using Word documents. Anytime a person printed out anything from the system, there would be a disclaimer at the bottom of the page reading "This document will be considered uncontrolled after 24 hours from (time & date stamp)". The document would print out with a time and date stamp based on the time of print out. Therefore, no need to physically stamp anything. Even if a worker has one of these documents which have been buried in his/her toolbox for 6 months, the auditor would see the time & date stamp and disclaimer and see that it is an uncontrolled document. This supplier was registered with no pre assessment audit and passed with no major non-conformances.
Alf Gulford
Just to add a bit to what Bill says: We use the '24 hour' footer with great success, but we also have occasion to use documents with "Controlled" stamped on them for various reasons. Everyone has been trained that it's only controlled if the stamp is Red. If it's black, as in a photo-copy, it's not controlled, regardless of the stamp.
Alf
barb butrym
what is an uncontrolled doccument?
what ever you say it is in your procedure!!!
Typically/traditionally its one that will not be replaced with a new copy when the rev changes.
Al Dyer
Barb,
I would just like to add that there are different requirements in the various standards/specifications.
As an example, if you are automotive and QS or TS, it is required that the business plan shall be a controlled document which is not a requirement of ISO-9k:1994. I'm not sure about ISO-9k:2000.
ASD...
K Document Control Terms: Obsolete, Master Copy, Controlled and Uncontrolled Copy Document Control Systems, Procedures, Forms and Templates 2
W Controlled Document vs. Uncontrolled Copy - Stamp requirements Document Control Systems, Procedures, Forms and Templates 11
A Distribution of Controlled Copy vs. Uncontrolled Copies Document Control Systems, Procedures, Forms and Templates 4
N Definition Controlled Copy vs. Uncontrolled Copy - What are the definitions and differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
Q Uncontrolled Hard Copy (Paper) Document Validity Period Document Control Systems, Procedures, Forms and Templates 12
C Work Instructions; Controlled/Uncontrolled? Document Control Systems, Procedures, Forms and Templates 5
qualprod An uncontrolled record is it a non-conformance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J Employee Contracts : Controlled and Uncontrolled Documents Document Control Systems, Procedures, Forms and Templates 6
R Part Prints - Controlled and Uncontrolled Documents (e.g.: The Production Floor) Document Control Systems, Procedures, Forms and Templates 13
J Uncontrolled Pictures of Packaging Posted on Walls ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Observation - Uncontrolled Document (Cheat Sheet) General Auditing Discussions 14
K Medical Application Classification in Controlled/Uncontrolled by Mobile App State. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
Q Documents uncontrolled when printed, if is not printed is controlled? Document Control Systems, Procedures, Forms and Templates 4
Chennaiite Controlled vs. Uncontrolled Document - Clarification requested IATF 16949 - Automotive Quality Systems Standard 11
T Living Documents which change every day - Control or Uncontrolled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
K Reasons for Issuing Uncontrolled Documents Document Control Systems, Procedures, Forms and Templates 10
V Can we show Photocopied Uncontrolled Copies of Documents to an FDA Auditor? US Food and Drug Administration (FDA) 15
C Equipment Owner's Manual used for Calibration - Is it uncontrolled procedure? Document Control Systems, Procedures, Forms and Templates 15
T Obsolete Uncontrolled Electronic Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
bgot62 Secondary Operations and an uncontrolled document in the warehouse ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Printed Documents are considered Uncontrolled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 34
M Uncontrolled Inspection Report Templates Records and Data - Quality, Legal and Other Evidence 7
W Can Calibration Procedures be uncontrolled? Document Control Systems, Procedures, Forms and Templates 2
F Referenced Documents vs. Uncontrolled Documents - Differences? Document Control Systems, Procedures, Forms and Templates 32
J What is the difference between a controlled document and an uncontrolled document? Document Control Systems, Procedures, Forms and Templates 10
D Controlled Engineering Drawings - Inspections to printed 'Uncontrolled' Prints Document Control Systems, Procedures, Forms and Templates 14
W Quality Manual - Controlled vs. Uncontrolled Document Control Systems, Procedures, Forms and Templates 6
H Difference between Controlled & Uncontrolled Documents Document Control Systems, Procedures, Forms and Templates 13
A Uncontrolled Emergency Evacuation Drawings (Signs) Document Control Systems, Procedures, Forms and Templates 4
C Control of Documents - When?? Uncontrolled forms identified days before the audit Document Control Systems, Procedures, Forms and Templates 19
J Uncontrolled Appendix? Document Control Systems, Procedures, Forms and Templates 13
J Controlling 'Uncontrolled' Documents sent to us by Customers Document Control Systems, Procedures, Forms and Templates 7
J Documentation/Work Instructions - Uncontrolled - Hung up at workstations Document Control Systems, Procedures, Forms and Templates 18
J Argentina Asked for FSC Hard-Copy Edition Only Other Medical Device Regulations World-Wide 0
G Copy of withdrawn ISO 9001:1994 Quality Management Standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A EC declaration of conformity - In the event clients ask for a copy CE Marking (Conformité Européene) / CB Scheme 12
J Where I can get a copy of either the 3rd or 4th edition of UL544? Other Medical Device Regulations World-Wide 7
A MDRS Standards Harmonisation - copy of ISO 15223-1 EU Medical Device Regulations 3
K Does anyone have a copy of a GM 5 Phase Problem solving form Problem Solving, Root Cause Fault and Failure Analysis 1
W Is it required to stamp obsolete hard copy DHR's "obsolete"? ISO 13485:2016 - Medical Device Quality Management Systems 6
V IATF 16949 - Buy PDF copy IATF 16949 - Automotive Quality Systems Standard 11
R Please help me with attached copy of AS 9100D internal audit check sheet AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A Alternative to keeping hard copy records that is 21 CFR part 11 compliant Document Control Systems, Procedures, Forms and Templates 0
S Looking for English Copy of MHLW 169 regulation Japan Medical Device Regulations 5
D Need a copy of IATF 16949 IATF 16949 - Automotive Quality Systems Standard 2
M I am looking for a copy of the ISO 16232 standard Other ISO and International Standards and European Regulations 2
C PDF Copy of IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 1
A Where to find a Draft Copy of IATF 16949:2016? IATF 16949 - Automotive Quality Systems Standard 23
M Where to buy ISO 3951-1 and ISO 3951-2 standard copy Other ISO and International Standards and European Regulations 1
N Can anyone provide me a copy of uncertainty in excel file? Excel .xls Spreadsheet Templates and Tools 4
