Where is the Requirement that says employees have to follow work instructions?
Q
qualitytrec
#11
if management defines the responsibility does it not mean, rather than imply, that the employee is required to do it?
Mark
V
vanputten
#12
Hello All:
"Iif management defines the responsibility does it not mean, rather than imply, that the employee is required to do it?" I don't know. I guess but it wouldbe hard to audit this since it is an assumed requirement. I think defining something and requiring it be followed are very different.
Processes can be defined and understood without anything being written on paper. My wife and I have a process of walking the dog. I do it in the morning. She does it in the evening. Nothing written but a well understood and defined process. This can be corroborated via independent interviews.
Just becasue something has been defined doesn't mean there is a requriement to follow it either.
I think the best answer so far is the requirements of section 4.1 especially 4.1 f).
Thank you to all that helped me better analyze TS 16949.
Sincerley, Dirk van Putten
N
newlingd
#13
I would issue the NC against 7.5.1 "The organization shall plan and carry out production and service provision under controlled conditions"
Regards
David
Cari Spears
#14
Regards
David
Me too - "controlled conditions" and "planned arrangements".
Randy
#15
I'm sorry, but this doesn't look like an issue about a clause or sub-clause or any of that tripe...In fact it's one of the best "DUH" questions I've seen in a bit.
Here is the requirement "As long as you want the money I pay you, do as I ask!" Some follow on language could be "I will not ask you to violate any laws, personal ethics, moral obligations or commit any other act contrary to proper business and civily approved behavior in our culture."
Bill Pflanz
#16
Although it is informative to see all of the clauses that an auditor can write a non-conformance against, it seems to me that we are making it complicated. Dirk never did say whether "the important instruction" was a documented requirement.
If it was a documented requirement, then the simplist way to write the non-conformance is to identify the specific requirement so that there is no doubt about where the violation occurred. After all, it is possible that upon review, management may decide that the requirement is overly restrictive and the corrective action is to drop the requirement.
If the instruction was not documented but was verbal, then it is questionable whether it is even a requirement since you would expect all quality critical requirements to be documented. Communication involves acceptance of the message not just its delivery.
If the intent is to correct the problem in an understandable way, referring to some clause in the standard that even we have trouble interpreting is probably not value added. Just my :2cents:
Bill Pflanz
Cari Spears
#17
Dirk - do you reference ISO shalls in all of your audit nc's? I usually don't, but I have worked in some environments (though not long for just this reason) where I couldn't get management to do anything about nonconformances unless I showed them where ISO said to do it.
I write them against the document, work instruction, procedure, whatever; this forces them to decide whether they need to enforce the document as is, or change or delete it.
V
vanputten
#18
Randy:
How does one audit against this requirement, ""As long as you want the money I pay you, do as I ask!" Some follow on language could be "I will not ask you to violate any laws, personal ethics, moral obligations or commit any other act contrary to proper business and civily approved behavior in our culture."
To properly audit, a clear and understoood requirement is needed. If there is no requirement to compare facts against, then the outcome will be based on opinion. Without a clear requriement, one cannot be impartial and objective becasue the outcome is now based on opinion.
How does one audit against your statement above? May I simply identify things as nonconformances based on what I think? I would be interested to watch a 3rd party audit using the same methodology.
Thank you for professionally qualifying my question as a "DUH" even though you did not answer my question.
My intent of this entire thread was to disucss the fact that ISO 9001 and TS 16949 have many requirements and some very specific requirements but nowhere did the writers add an overt requriement that simply says "employees must follow instructions." To me, that seems to be a basic requirement that should be cleary included and not inferred or implied.
Thank you, Dirk
Randy
#19
Employers have the right (legal obligation in fact) to require employees to meet requirements (rules, regulations, procedures and all that good stuff), except in touchy-feely good California I guess. Proof could be the documentation generated by an employer showing its action when requirements are not adhered to by its employees. Regardless of 9001, 16949, the Man-in-the-moon or any other dribble employers must document unacceptable or undesirable activities or actions of the individual employee to cover their fannies for a variety of reasons. The "DUH" was for the simple facts that I stated above. Meeting requirements existed long before this management system stuff was thought about, but people tend to take the simple and complicate it beyond recognition.
"Please do as I ask employee or you won't be an employee for long" There it is!
Jackson_kan
#20
7.5.1.2
7.5.1.2
"The organization SHALL prepare DOCUMENTED WORK INSTRUCTION for all employees having responsibilities for the operation of processes that impact product quality…"
if you understand "shall' inTS & "documented work instruction" and also you can tell someone has not responsibilities for the operation of processes that impact product quality, then you may not get available for WI, otherwise, go back and make every single creature get WI. :mad:
M Where to appeal a ridiculous IEC 60601 requirement? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
J ICT Assets and ISO 9001 Clause 7.5.3 - Where Traceability is a Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
N "Where traceability is a requirement" Record - ISO 9001 Clause 7.5.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
M Procedure binding even if not required by the standard - Where's the requirement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 59
R Where I can find the grade requirement for an inspection plate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
F Customer Part Drawings - Is there any requirement as to where they are kept? Document Control Systems, Procedures, Forms and Templates 1
M Testing criteria - where to place Design and Development of Products and Processes 1
J UDI - Where to document it? EU Medical Device Regulations 8
J Where to get a Black belt certification ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 13
D Any recommendations on where to find experienced quality hires in Chicago area? Job Openings, Consulting and Employment Opportunities 3
J Where is the definition of a critical supplier? ISO 13485:2016 - Medical Device Quality Management Systems 5
W Where does a coatings and paint company fall in IATF? IATF 16949 - Automotive Quality Systems Standard 5
B When Travel is allowed - Where are you going? Travel - Hotels, Motels, Planes and Trains 16
G Where to buy Template / sample SCSMS Manual, checklist Supply Chain Security Management Systems 1
M Quality Manual - Where does Revision History Section go? Document Control Systems, Procedures, Forms and Templates 8
C Where to draw the line for "sufficient evidence" to verify safety/performance of a device? CE Marking (Conformité Européene) / CB Scheme 2
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Where to acquire EN 868-5 required dye (Amaranth red)? Other Medical Device Related Standards 2
N Where to find Regulations for Reprocessing and Reuse of Single-Use Devices Other Medical Device Related Standards 2
H Where to get EK MED 1927/16 Other Medical Device Regulations World-Wide 3
D Where to find Guidance Class II Amendment Canada Medical Device Regulations 1
O EN 301 489-1 and EN 301 489-17 - Where do we get the information of the Published versions? CE Marking (Conformité Européene) / CB Scheme 1
A AS9100 Training - Where do I start? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Where to place CE/label in Sterile IVD EU Medical Device Regulations 1
G New to ISO 9001 - Where to begin? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
BeaBea Interesting Discussion Where Does Marketing/ Advertisement of Products fit in to ISO 9001? Process Maps, Process Mapping and Turtle Diagrams 39
K No IFU, where the requirements would go? EU Medical Device Regulations 5
T Assessing Hazard-Related Use Scenarios where control measures exist through standards IEC 62366 - Medical Device Usability Engineering 32
J Where to Place Process Maps in our Documentation? Process Maps, Process Mapping and Turtle Diagrams 4
GreatNate Where to get a KPI dashboard for QMS processes Quality Tools, Improvement and Analysis 5
A Implementing ISO 20000-1 - Where to start Other ISO and International Standards and European Regulations 2
D Where does "as far as possible" stop? FMEA - EN 14971 ISO 14971 - Medical Device Risk Management 29
qualprod Statistics - Where to start in ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
H Calibration of InfraRan Vapor Analyzer - where to get calibration for SF6 General Measurement Device and Calibration Topics 2
M Where can I find examples of PPAP? APQP and PPAP 6
A What if Contract Manufacturers does not have an ISO 13485 certificate? Where will the NB audit take place, at legal mfg. site or contract mfg. site? Other Medical Device Regulations World-Wide 3
J Where can I find the latest update to Reach and ROHS? REACH and RoHS Conversations 9
D Where (in US) can I get the VDA Auditor Edition book? VDA Standards - Germany's Automotive Standards 3
S Where to get online AS standard audit certification classes? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
J Where I can get a copy of either the 3rd or 4th edition of UL544? Other Medical Device Regulations World-Wide 7
G Where to find Proficiency Test provider for photometrics (spectral %R, %T, photo density) General Measurement Device and Calibration Topics 9
Marc Quiz - Where did the idea of an assembly line come from? Coffee Break and Water Cooler Discussions 4
F Quality Objectives - Where in the QMS Quality Objectives should be located ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M Where to obtain a calibrated DICOM image? ISO 13485:2016 - Medical Device Quality Management Systems 1
