Re: DOE - Qualitative response - 4 variables at 3 levels max
Hi Sriram,
I'm also embarking on a series of DOE with discrete data to improve on the IC handler in my company.
The response for the DOE is a measure of the visual mechanical defects (discrete data), in particular, mold gap as found in the IC.
The mold gap on the IC is causing the IC copper trace to break off leading to open failures during testing.
We find it quite impoosible to convert the defects into variable data.
Hence we decided to stick to dicrete data as our response.
I've done up the design matrix for the DOE which in our case is a 6 factors, 2 levels, 16 run, Res IV fractional factorial design.
Pls find attached the pdf file on my DOE design matrix.
However, I'm still pending for the customer to release the handler for us to perform the experiments that would only happens on the last week of Sep 06. Therefore, the attached file will not contain any data and analysis at the moment. I'll post my DOE results up in the forum once completed.
Nonetheless, I found one excellent web site that provide an overview of DOE with discrete data.
Here's the link
https://www.engr.wisc.edu
Pls scroll down to r119 of the website to download the material.You will need to provide some basic information to download the files.
To add on, I'll be using the following graphical methods to analyse the DOE data.
1. Normal probability plot of standardized effects
2. Residual plot vs fitted value
3. Resdual plot vs order
4. Residual plot vs variables
I would suggest that you keep your 1st DOE as simple as possible and if you only have 4 factors, I would recommend you to perform a full factorial on 4 factors and
2 levels instead.
Although not much but hope it helps.
thks.
jeffrey chang
