Simple..! try these links:
for 35389 gmdn code query:
http://search.mdco.gov.hk/english/sd/sd_gmdn/sd_gmdn_search.php?c=35389
Result....
Code : 35389
Term : Syringe, hypodermic, insulin
Definition : A device with a small barrel with plunger, calibrated in units of insulin, used with a needle to administer (infuse) insulin subcutaneously. This is a single-use device.
Synonym code :
Template Specifier : nil
Category 1 : Single-use devices
A category that includes devices which are intended to be used only once and then disposed. NOTE: This also includes devices that are used more than once upon the same patient during the same procedure and then disposed. Examples of devices in this category are: intravenous infusion sets, condoms, laparotomy sponges, internal tissue stapling devices.
Whether for product identification? : Product Identifier
and other query:
http://search.mdco.gov.hk/english/sd/sd_gmdn/sd_gmdn_search.php?c=45042
Result...
Code : 45042
Term : Syringe, hypodermic, metered-delivery, retractable-needle
Definition : A device comprised of a graduated barrel with plunger and an attached retractable-needle designed to deliver (infuse) an accurate metered dose of a substance (e.g., medicine or drug) during an injection. The integral needle retraction mechanism (e.g., the needle may be retracted into the syringe of the barrel) prevents the needle from being exposed to protect users from potential injury. This is a single-use device, which can be used by healthcare personnel or the public.
Synonym code :
