AQL Sample Size for Battery Inspection
terranceyu
Hello everyone,
I have one concern on the AQL sampling on battery inspection.
Currently production found one battery failed FCT test - low voltage. Production quantity : 500 pcs.
IQC is measuring the battery voltage using multimeter. Sample size : 4 pcs. Lot quantity: 5000 pcs. Are we suppose to use the AQL sampling size according to ISO 2859-1, to respond to this complaint? Or keep at actual practice, while sending the faulty part to supplier for investigation.
Please, share your thought on this. Thanks.
Terrance
reynald
If the sample size was special due to volume constraints, you can use probability theory to test the hypothesis that the %defective increased in reference to the historical baseline.
My logic would go as follows:
Decision:
if %d is <= some value--> ignore the problem
if %d is > some value--> highlight the problem
Use a p-test
Ho: p is same as hostorical level
Ha: P incresed from historical level
then proceed to whatever conlusion the p-test takes you.
terranceyu
Decision:
Use a p-test
In the sametime, I also using the same theory feedback to him. But he insisted to check the battery lot exactly according to ISO 2859-1. Does this actually serve any purpose?
What if the battery checked as per ISO 2859-1 sample size, so can we judge this lot as good, but in the end of line we found one piece defect after 100% FCT test?
terranceyu
Any advice for me, dear covers? :cool:
I am not sure what you are asking?
Please clarify the relationship of yourself, IQC, the test location and 'he'. who is 'he' that is complaining? (Are you in IQC and 'he' is your manufacturing line?)
What is the ISO2859-1 sample size?
If different from n=4 why did you choose n=4?
It is quite possible that using a different sample size will give you a better understanding of the quality of the lot.
terranceyu
I am IQC engineer. He is the project engineer which is very much concerned for this medical product, if the battery voltage going below requirement, and uncovered by Functional test, the user might not able to get the sufficient dosage due to insuffient energy source.
ISO2859-1 sample size is 200 pcs. I am choosing 4 pcs for voltage measurement due to this is a product that has been checked by supplier 100%, and lack of human resources to actually doing this, because we have almost 6000 items to be checked in one single day!
IMO, we should take care of the battery storage condition, shelf life, and get supplier corrective action and preventive action, other than just depending on AQL inspection at receiving. It should minimize the risk, and satisfied everybody.
Pls, let me know your thoughts. Good advices are welcomed.:D
The process engineer is correct to be concerned and your lack of human resources to perform incoming inspection will not be an excuse if there is a field action on the instrument due to battery voltage.
You are correct that storage and shelf life should be controlled and the supplier should recieve a corrective action.
However, sampling only 4 batteries tells you nothing about the lot and is a waste of time. There are two plans that can be used: the one you mention is for pass/fail data (the battery meets specification or it doesn't) and these will always have larger sample sizes. A second option is to use sampling for continuous data (or as some call it "variable" data). This will get your sample sizes down but wstill allow you to perform a meaningful inspection.
terranceyu
Hi Bev D,
Can you provide in details how sampling for continuous data is done. How many samples should be taken for this? Based on AQL level or....?
Your help is very much appreciated.
I agree with this in spirit but I think clarification might be good. If the OP discovered a single defective in a 4-piece sample from a 500-piece lot, the effort wasn't a waste of time. What is wrong, as you point out, is that a sample size of 4 isn't reasonable given the lot size and the risk involved.
If this is a situation where one defective is too many and the risk is high, it's possible that sampling inspection is inappropriate altogether.
H Determining the Correct Sample Size when AQL points to two Sample Sizes AQL - Acceptable Quality Level 7
S AQL - Sample Size to test Chickens for Salmonella Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
I AQL Formula in Excel - Calculating Sample Size based on an AQL Chart AQL - Acceptable Quality Level 8
T Determining the appropriate Sample Size using an AQL Table Inspection, Prints (Drawings), Testing, Sampling and Related Topics 29
S Determining the Total Sample Size using AQL - AQL Lot Quantity question AQL - Acceptable Quality Level 8
N Calculating Sample Size for very low AQL AQL - Acceptable Quality Level 13
P Calculating Confidence Level and AQL with Increased Sample Size Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
P Why sample size for c=0 sampling plan reduces across the increases of AQL AQL - Acceptable Quality Level 2
1 Determining AQL and Sample Plan - Batch size is from 1-500 AQL - Acceptable Quality Level 24
B Sampling Plan - AQL effect on Sample Size AQL - Acceptable Quality Level 9
S Calculating an AQL given a sample size, accept/reject numbers, and lot size AQL - Acceptable Quality Level 2
M AQL vs. Cpk - Sample Size and Reduced Sample Size AQL - Acceptable Quality Level 16
T Using SPC Control Charts to Reduce AQL Sample Size AQL - Acceptable Quality Level 16
M AQL and Sample Size - Section 9.4 of ANSI Z1.4 AQL - Acceptable Quality Level 3
C Software or Excel .xls spreadsheet to calculate sample size and the AQL - ISO 2859-1 AQL - Acceptable Quality Level 2
M Sample size of SQRT(n)+1 an alternative to AQL? AQL - Acceptable Quality Level 2
M AQL table - I need to sample 1250pcs AQL - Acceptable Quality Level 3
E AQL with Multiple Attributes - Sample Sizes AQL - Acceptable Quality Level 8
A AQL Sample Sizes - Explain how Sample Sizes in an AQL table are calculated AQL - Acceptable Quality Level 4
B 4.10 Inspection and Testing - Do we have to do AQL (MIL-Std-105) sample inspection? AQL - Acceptable Quality Level 3
R AQL, Consumer Risk and MA Statistical Analysis Tools, Techniques and SPC 2
A AQL - How to count samples with defects for each defect class AQL - Acceptable Quality Level 17
S ARMY AQL - Requirements which don't have an AQL associated with them Manufacturing and Related Processes 2
Nicole Desouza Sampling plan for a customer who wants AQL 1.0 (per ANSI Z1.4) AQL - Acceptable Quality Level 5
V How to interpret AQL sampling tables AQL - Acceptable Quality Level 5
A AQL sampling bags of parts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
I Sampling processes - Who must define the AQL level? AQL - Acceptable Quality Level 9
J AQL for Effectiveness Check - What AQL tiers to use on this type of sampling? Nonconformance and Corrective Action 9
S AQL Inspector's Rule - bring into CQE Exam? Professional Certifications and Degrees 5
N The question asks about sampling plans and AQL Reliability Analysis - Predictions, Testing and Standards 5
K Defining Acceptance Quality Level, I need clarity on AQL 1.5, 2.5, 4.0 AQL - Acceptable Quality Level 5
V Receiving Inspection AQL - Am I allowed to just pick a AQL? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 10
L Established a c=0 "AQL" or "RQL" table AQL - Acceptable Quality Level 5
A AQL Sampling Plan SOP / WI - Medical Device Industry Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
C Example Work Instruction/Procedure for AQL (Acceptable Quality Level) AQL - Acceptable Quality Level 4
L How to calculate the Probability of Deficiency of the AQL of an Inspection AQL - Acceptable Quality Level 16
P Setting Acceptance Quality Limits (AQL) for New Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
K AQL for Sterile Product - Laminate Tubes 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M How to Mathemetically Derive the AQL Tables given Lot Sizes AQL - Acceptable Quality Level 5
L AQL ANSI z1.4 & z1.9 - What are the differences between these 2 standards? AQL - Acceptable Quality Level 5
P RQL/AQL from Attribute Data Six Sigma 1
B Designing a Sampling Plan - AQL AQL - Acceptable Quality Level 19
V AQL for Component Level and Assembled Finished Product AQL - Acceptable Quality Level 1
alonFAI AQL and Sampling Size for Components Solderability Test Statistical Analysis Tools, Techniques and SPC 3
A Inspection Plans - How to choose AQL (MIL STD 105E) Excel .xls Spreadsheet Templates and Tools 1
U AQL, Lot Size vs Sampling Plans AQL - Acceptable Quality Level 8
R Formula to tie together - Confidence/Reliability Level AQL? LTPD? Reliability Analysis - Predictions, Testing and Standards 3
