AS9102 FAI report Forms 1-3
O
Orwell
Hello everyone. I work as a Quality Manager for a small company in the heart of Europe. Our company is focused on production / assembly of stators. Our company has customers who's got specific requirement with necessary documentation (i.e. drawing, specs. etc). In some cases our customers deliver components, raw material, catalog parts and so on to our warehouse. We are ISO 9001:2008 certified company at this moment.
Our latest customer is German aerospace company, ISO 9001, ISO 14001, AS9100, REACH certified, a company that is many years in the business.
Our customer made a Purchase Order for 5 stator prototypes with different specs, and dimensions and they are interested in mutual cooperation and serial production. All prototypes were made according to the customer's drawing, all of them passed our internal quality check. We were never dealing with a company/customer from an aerospace area and I was surprised by a request to include, provide FAI report, which according to my knowledge consists of 3 forms. I've done research on my own this week about the FAI report, read many threads here at elsmar, googled it, watched few youtube videos but at this moment I'm still confused and need your help.
Below I will provide as much info as I can with my questions.
AS9102 Rev A Form 1 (XX.YYYY FAI - 112233.docx)
parts_list_for_112233.xls these are the 13 parts that are necessary for one stator (stator No. 112233), these are catalog parts. All these parts were sent to us by our customer.
1. First things first. Is this Detail FAI or Assembly FAI ? In the process of making a stator we use solder, we also crimp the cable/wire, apply coating etc. As I read here on the elsmar forum, these are modifications made to the catalog part(s) and therefor we cannot call it 'Assembly' and it must be a Detail FAI, am I right ?
2. In the AS9102 Rev A Form 2 (XX.YYYY FAI - 112233.docx), all the 13 parts goes in there(?) As you can see on the pic. vendor_manufacturer_cut.jpg our customer cut the Vendor/Manufacturer name of the part (on most of the parts actually). How am I supposed to provide "8. Special Process Supplier Code" and "10. Certificate of Conformance number" ? Only 1 item out of 13 came with the Certificate. Number "9. Customer Approval Verification" was pre-filled with "NA" by our customer who gave us these 3 forms.
3. Form 2 wants from us to provide even a process name, number, CoC etc. Let's say this process is called "soldering". We don't have a process name, number nor certificate for this process. How would you include this into the Form 2? Am I supposed to create internal process for soldering, write the process on an A4 and give it a special number? What about the certification for this process? I just don't understand ...
4. Form 3 (XX.YYYY FAI - 112233.docx)
Column “5 Char No.” in the drawing YYYY-0100-0100 there is “a”, “b” etc in the cirle, is this the so called bubble drawing ? Drawing was made in 1988. For example the high voltage test 1000 V 50 Hz, shall I draw a circle with number, I don't know, "5" next to this req. into the drawing? And then in the form 3 is it going to be "5 Char No." "5"?
Last question. Dimensional measurements. Our laborers measure each stator during and prior the finishing process with a Vernier caliper. We do not make any reports on the Dimensional measurements. Either the measurements correlate with the drawing and if not, then the stator is removed and recycled from the production process. We do not make any final dimensional measurements on the product. Final product is tested in a special machine (tester) for its characteristics, 26 measurements were done (statistical_summary.jpg). So what am I supposed to include in the Form 3?
All the documents, pictures, forms are in the attachement. XX.YYYY FAI - 112233.docx has red "?" question mark in each cell which I do not understand. Please, be aware of the fact that we are not AS9100 certified, this is our first contract with an aerospace company. Thank you
mikeh54
This is how I would do it
I would call it an assembly. List all of the component parts manufactured or purchased on Form 1
Form 2 would list all of the materials used in assembling. Lubes, sealants, glues. It looks like the Elmotherm Coating may fit that description. I believe functional testing/results also goes on Form 2.
Form 3 - You will need to measure and document the measurements for one part and you will need an accompanying bubble drawing or something to relate the drawing characteristic to the FAI entry. Like you suggested, pick a logical spot to start and put a 1 inside a circle, and work your way around until you run out of things to number. EVERY characteristic on the drawing, and any additional PO requirement, that applies to the part you are documenting has to have an entry on the FAI. This includes dimensions and any applicable drawing notes. You need to document the requirement and the actual for each characteristic. You'll learn to hate this in a real hurry.
Did they also ask for certifications?
dsanabria
Q - During contract review - Is the customer asking for a FAIR on the assembly or individual parts? - get clarification and charge them accordingly.
Eredhel
Quality Manager
AS9102 FAIRs are definitely costly and should be added into the cost if it's not too late. They can take a long time to prep and then complete. Do you have the extra pages that tell you what each numbered cell is, or do you just have the form pages you fill in?
BoardGuy
An AS9102 is euphemistically called a tour of the world for good reason. You must verify all requirements listed on the drawing and within customer required specifications line by line. If your customer is purchasing to a procurement drawing, only those requirements apply and not the sub-assembly drawing unless they are also listed on the procurement drawing.
The International Aerospace Quality Group (IAQG) has AS9102 training materials found in the Supply Chain Management Handbook (SCMH) section of their website. The link to IAQG is International Aerospace Quality Group
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Charged for an AS9102 FAI Report when requested as part of a Purchase Order? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q FAI IAW AS9102 - First Article Inspection Documentation Question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 20
D AS9102 B (FAI - First Article Inspection) is Released - October 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A AS9102 First Article Inspection and NC Parts - New FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
WCHorn AS9102 Paragraph 5.3-5 - Lapse in Production - FAI Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S AS9102 FAI requirements - Inspecting with fixtures, templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J How often can AS9102 FAI be invoked? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
G What is meant by FAI (First Article Inspection) and how do we comply? AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 26
A AS9102 FAI Case Outline Difference AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D AS9102 FAI - Detail vs Assembly FAI (Form 1, Box 13) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T Distributor Value Add work to an AS9102 FAI part - Lubrication AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P What is the acceptable content on FAI form 3? AS9102 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T AS9102 FAI - What is a distributor of ball bearings supposed to do? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
T Another FAI AS9102 form question Document Control Systems, Procedures, Forms and Templates 3
V AS9100 and AS9102 - Does our supplier have to do the FAI using the 3 AS9102 forms? Document Control Systems, Procedures, Forms and Templates 3
L COTS (Commercial Off-The-Shelf) Parts with AS9102 FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Z AS9102 FAI (First Article Inspection) - Is a Ballooned Drawing Required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
B AS9102 FAI (First Article Inspection) per standard or contract? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S AS9102 Form 1 Item 19 FAI Complete / Not Complete Box - Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
R AS9102 Info - Must each Assembly Component have FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J AS9102 FAI (First Article Inspection) Full or Partial - Changes to NC programming Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
S AS9102 FAI for part number with no official drawing? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C AS9102 FAI Bubble Drawings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S FAI compliant to AS9102(A) - Quantity - Measurement Range Results Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Does the AS9102 FAI requirement apply to wire assembly sub-kits? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
I AS9102 lapse in production requirements - Customer FAI request AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M What are the FAI requirements for an assembly? New to AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9102 FAI for Circuit Card Assembly - Measure each hole and document it? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
J AS9102 FAI Reports. Need for Standard Parts? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
B FAI (First Article Inspection) per AS9102 Form 2, sections 5 & 6 question Document Control Systems, Procedures, Forms and Templates 10
T AS9102 FAI (First Article Inspection) Form example Document Control Systems, Procedures, Forms and Templates 30
T AS9102 Section 5.3 - FAI anytime a machinist tweaks a CNC program? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J AS9102 - Do I have to do FAI for all Standard Catalog Hardware items???? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L AS9102 FAI acceptance - Currently having issues getting prompt approvals AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D Following AS9102 for FAI Requirements - Does EVERY Component Need Its Own FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 40
P AS9102 Form 3 Inclusions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
