GoKats78 said:
Incoming Product - product brought to a finishing cell (long length tube to be cut and end finished) to be processed at the machine
And I assume that the material has been verified via incoming inspection?
GoKats78 said:
Lineup - Schedule in Business System which list material to be processed.I note that cosmologists are quite willing to abandon earthly physics to support their ends, but biologists are loathe to do the same.
The equivalent of a process router?
GoKats78 said:
Information verifed visually (by comparing tag to lineup) - Tube OD, Wall, Customer.
This step serves to verify the "lineup" and not the material, it seems.
GoKats78 said:
Information verifed by measurement - Tube OD and Wall
And this step verifies the material, which seems to be redundant if it's already been verified at incoming inspection, and the "lineup" has been verified to be correct.
Assuming my surmisals are correct, you should have a line in your
PFMEA for receiving inspection, and it should list the potential failure modes of that operation. The assumption should be made that the state of the incoming material is unknown, and that it's possible for the material to be misidentified, mis-tagged damaged (in receiving inspection, not by the supplier or the trucker) or somehow misdirected. There should be Severity, Occurrence and Detection factors assigned to each possibility. The Detection factor assumes that something bad has happened, and predicts the likelihood that the problem will be detected before value is added to the product, or before the final product is shipped to the customer. A Detection value of 1 means that the probablility of the problem going undetected is negligible; a factor of 10 means that the problem is impossible to detect.
Once the incoming product reaches the finishing station, the tag is compared to the "lineup." Again, an RPN should be developed. The Detection factor should follow the same reasoning given above. Note that whether or not the requirement for this (or any other) step reaches the control plan depends on the outcome of the PFMEA. You might determine that special controls aren't necessary. Just because an operation appears on the PFMEA doesn't mean that there must be a corresponding control plan line item.
Finally, the tubing is measured at the finishing station before further processing takes place. I said above that this might be a redundant control, and perhaps redundancy is a good thing. It depends on the level of risk involved, which you have to determine based on experience. If you find that redundant controls are necessary due to upstream bungling, that's another problem, and one that's not likely to be driven to extinction by more inspection. Inspection shouldn't be used to solve personnel problems.
