Re: Corrective Action vs. Preventive (Predictive) Action (CAPA) - A Definitive Discus
I usually explain it like this:
Corrective action focusses on the sympoms of the non conformance. It's like hiding the problem by making it invisible (hiding it behind a curtain). Usually these actions add costs to the non-conforming process.
Preventive actions focus on the root cause(s) of the problem preventing it from happening again in the same process or prevent it from occurring in a similar process elsewhere. These actions usually need an investment but, due to improved process efficiency, eventually lower the running cost of the previously defect process.
When I teach about Quality I like to use this example from when I worked at Johnson Controls where we built the complete dash assy for a car.
There was a problem with flash on an edge of an injection moulded plastic part. We did a RCA and found out that the mold halfs weren't perfectly flat. During the analysis we hired workers who did nothing but manually deburring the plastic part. In the mean time we decided to have the mold halfs reworked so that there was no issue with flesh anymore.
Corrective action: Manually deburring plastic parts (Customer didn't see the problem anymore, but we had to hire extra people for deburring = extra costs)
Preventive action: Reworking the molds halfs. (relative large amount of money & time)
Completely disagree with this explanation.
What you describe to me sounds like you took action to control the nonconformity "Manually deburring the plastic parts" (ISO 9001:2008 8.3 a. taking action to eliminate the detected nonconformity) Just because you came up with this "band-aide" solution during the analysis doesn't automatically assign it to ISO 9001:2008 8.5.2 Corrective Action.
When I explain the concepts, I use very plain terms...we satisfy ISO 9001 8.3 when we apply a quick fix or band-aide solution to the problem. This can be either fix it and forget it (although it really is being monitored through the system records to see if it a trend develops that warrants corrective action at that time) or it can happen as you describe, as a fix to buy you time while you figure out a permanent solution to the problem (ISO 9001 8.5.2)
Corrective Action really occurs once you figure out WHY the problem keeps happening and apply a fix that stops it from happening over and over again. (of course you also monitor the fix to make sure it did indeed work to completely answer the requirements of ISO 9001 8.5.2)
ISO 9001 8.5.3 Preventive actions...Our preventive action plans primarily come from our audit program OFIs, Management Review improvement actions, and the good ideas our employees have come up with to make their work faster, better, easier, etc. The benefit that we get from this is that we have a formal method of tracking the progress of these improvement projects.
We also linked our preventive action process to our document control process to ensure these good ideas once deemed effective are formalized in our QMS documentation.
