Document Control and Distribution - How to save paper?
E
energy
#41
Re: documentation and links
Karen-Dawn said:
The docs provide the specifications, instructions, checksheets and calculators. We have a hard time maintaining the links. i.e. the spec in one doc changes which would trigger a change in the operating doc check sheets, another in the inspection requirement doc and perhaps the excel calculator. I hope you get the gist of it.
Karen-Dawn :p
KD,
Are you looking for a way to upgrade the links everytime you change the Mother document. Something that will do this automatically? My limited experience with hyper-linking in Word and Acrobat is that the associated links have to be changed manually. As for Access and Excel, I defer to Martin or Randy. When you say "trigger" a change, do you mean that this happens without manual input? Or, are you saying a change "triggers" you to go and manually change the links? I don't get the gist of it yet, I guess!:confused: :smokin: :bonk:
K
Karen-Dawn
#42
Documentation and Links
Hi Guys,
Thanks for the input and I am not about to give up. I pretty much have the ability to change how we design and control our procedures, checksheets and data collection all I really need are some fresh ideas on how....
The current system consists of probably way more specifications than what most of you are used to. (Basically an NEC modelled system that was forced on us about 10 years ago). "Time for Change". So say we have a product dimension cited in a product spec., now that same dimension is also written on a checksheet in an operating spec and on a check sheet in an inspection spec. And...finally the dimension is needed in an Excel 'calculator' that say gives the operator the 'area' when they enter length and width. We are looking at a lot of time to revise/release each document whenever that initial part dimension changes, not to mention that we occasionally miss updating one of the needed changes in the thread. What I would like to do is link all the docs so that when you change the initial product spec, the checksheets and the spreadsheet change as well. But, operators cannot have access to changing the intitial product spec but need to write to the checksheets and the calculators...
I hope this defines my dilemma a little clearer.
One easy transition I can see is moving all the separate docs to Excel and use a separate page for each doc type (eg product spec, operating instr, inspection instr, start up checksheet, insp checksheets and finally applicable calculators). However, by giving operators write permission to complete the checksheets and use the calculator they can change the actual product dimensions as well... Is there a possible way to make Excel work or is there a better way?
Thanks Muchly, Still believe you can help me.
K-D:confused:
Randy Stewart
#43
The Missing Link
K-D,
I believe that is the only way to do in your current setup. What I would do is have the Product Spec sheet protected so the dimensions can't be changed. When you move to the calculations, reference the cell with the required dimension and hide the formula. All the operator will be doing is typing in the findings and the program will do the rest.
Have you thought about an SPC software?? Some of them are very cheep.
K
Karen-Dawn
#44
Thanks Randy,
But 'protection' is the concern right now. Is there a way to really protect the spec info from operator changes. (Anyone can hit a button or two and turn cell protection off.)
Karen-Dawn
Randy Stewart
#45
To Protect & Serve
I was just looking into a password protect when I was notified of your message on the board. Here is what I found, it's out of the help file.
Limit viewing and editing of an individual worksheet
When you protect the worksheet, the cells and graphic objects that you did not unlock in steps 2 and 3 are protected and cannot be changed.
Switch to the worksheet you want to protect.
Unlock any cells that you want to be able to change after you protect the worksheet.
How?
Unlock any graphic objects that you want to be able to change after you protect the worksheet.
How?
Hide any formulas that you don't want to be visible.
How?
On the Tools menu, point to Protection, and then click Protect Sheet.
To prevent changes to cells on worksheets or to data and other items in charts, and to prevent viewing of hidden rows, columns, and formulas, select the Contents check box.
To prevent changes to graphic objects on worksheets or charts, select the Objects check box.
To prevent changes to the definitions of scenarios on a worksheet, select the Scenarios check box.
To prevent others from removing worksheet protection, type a password, click OK, and then retype the password in the Confirm Password dialog box. Passwords are case sensitive. Type the password exactly as you want to enter it, including uppercase and lowercase letters.
If you assign a password, write it down and keep it in a secure place. If you lose the password, you cannot gain access to the protected elements on the worksheet.
Hope it helps.
Mike S.
Happy to be Alive
#46
K-D,
I agree with Randy's idea. You can also use MS Word if most of the stuff is text, pictures, etc. and insert a small Excel spreadsheet to do any calculations with.
As far as protection so the spec's. cannot be changed, I'm not sure why you are so worried about that. Has this been a problem? Isn't turning on sheet protections enough security to keep floor-level people from making changes? Seems to me it would take a maliscious employee to do that, in which case a person like that will always find ways to cause problems. Besides, they could only change it on the open file, not the "master", right?
Am I missing something?
K
Karen-Dawn
#47
Excel Protection
I just tried Stew's suggestion with a dummy spreadsheet and it seems to work, the password seems to follow the file even if you move it to a new folder.
I agree that keeping malicious employee's from screwing things up is almost impossible but I am sure you have all experienced more problems than you ever wanted to related to the 'not so experienced' user, just hitting the wrong keys:frust:
Thanks-Muchly I will definitely submit these options at our next meeting. I have to admit that I have been reading these forums for awhile now but as a first time user, I am genuinely impressed!:D
K-D
G
Graeme
#48
time for a chiphead powerbar!
Karen-Dawn,
I see in an earlier post that Energy thinks I may have something useful to contribute. :bigwave: I will try. (By the way, your name is really catching to me -- my wife is a Karen and her youngest sister is a Dawn!)
From your descriptions, my opinion is that you may need an electronic system based on something a little more powerful than Word and Excel. Your people are having to enter the same data multiple times, something that is never a good idea because every keystrove is an opportunity for error. (As my spelling sometimes shows!) You probably would be better served by using a relational database system (Microsoft Access 97 or later, as an example of one) and a set of purpose-designed forms, reports and data entry screens. However, setting this up is not really for the novice ...
I think the first step is to organize your information into two types - data that describes what the product is supposed to be, and data that shows what actually happened when each item was made.
  • The data that describes the product is your specifications and tolerances, part numbers, revision date, contract numbers, NC instructions and so on. This information would be entered in the database by the responsible person in the office, and not routinely changed after that. It is more or less "permanent" information. When you create a procedure, form, instruction or checklist, the document can link to tables and fields in the database and automatically plug in the current data when printed. ("Print" can be to paper, but it can also be to another document, or to a PDF file.) Even better, in many systems the documents and forms can actually be stored in the database!
  • The data that describes what happened includes the measurements made during production, and can be entered using custom screens. A typical sequence would be to enter a tracking number (which would then pop up the part specifications), and then the data. Calculations can be handled as well, so a separate spreadsheet may not be needed. at the end, the data is stored in the database, and can be retrieved as needed.
Setting up the database requires expertise with relational database systems. Creating the documents with links to the database requires experience with ODBC or SQL links. (Word's MailMerge feature is a simple example.) Creating custom data entry and viewing screens requires expertise with Visual Basic for Applications (assuming the database is Access.) And all of it requires time, patience and re$ources.
With a properly designed relational database system, you should hardly ever have to enter a data item more than once. Everything should be grouped in small units (tables) of organized and related information, related to one thing that stays the same (the part number?). A real database guru can probably explain it better, but here is a simple example:
One table contains the part numbers. That number links to other tables that have different information -- Dimensions, Revisions, Units_Made, Contracts, and so on. The dimensions table conains the part number (it has to, to allow the linking), the dimensions, the tolerances, and the current revision date (another link). The Units_Made table contains the part number (for the link), a unique tracking number (serial number?), and whatever measurement data was collected for that specific piece of stuff. And so on.
I usually think of a relational database like a special type of file cabinet. Open a drawer and pull out a file folder. That folder has some of the information you want, and it also tells you where to find other information. In an "ideal" system (as opposed to the real world that we live in) a particular piece of information lives in only one file folder. All of the other files that use that information simply have a pointer telling the system (you) where to find it. The big advantage is that if a change is needed, only one thing is changed, one time. The drawback is that is may take the computer a couple of microseconds longer to retrieve it.
Feedback time -- have I helped, or simply added to the confusion?
Mike S.
Happy to be Alive
#49
K-D,
You can do the same kind of thing Stew expounded on regarding Excel in Word. Use section breaks to select certain sections of the document that you want to protect from changes. The Word help file will explain all of this protection stuff -- it is pretty easy. The stuff (text, formulas, specifications, whatever) inside the protected section of the doc can be read but cannot be changed -- you cannot even get the cursor to go there -- unless you supply a password as in Excel.
Either protection method is as idiot proof/jerk proof as you will likely ever need. Anyone who goes to the trouble to crack a Word or Excel password (it is doable) will cause much more trouble than changing a spec. on a quality procedure.
Good luck. Maybe next time you visit you'll be able to help someone else.
K
Karen-Dawn
#50
Thanks Graeme,
I do understand what you are talking about as we use Visual Manufacturing for tracking most (if not all) the items you mentioned. We have discussed that we may have to use a database system like visual (or Access which I am not familiar with) to do what we want (more the links to operator set points, etc. used for set-ups and inspections... However, we have also recognized the need for the resources ($) you mentioned and want to avoid if at all possible.
Muchly Karen-Dawn
And yes I am more than willing to help in the future if/when possible. Although I may sound somewhat 'out-of'it' when it comes to computer programs my real expertise is in designing, implementing Management Systems and Auditing (Internal and External).
Later.:bigwave:
C Document Control and Identifying Distribution ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
H Distribution of Controlled Copies - Document Control Document Control Systems, Procedures, Forms and Templates 10
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
I Document Control on Log Files ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q Tracking Procedure Revisions (Document Control) Document Control Systems, Procedures, Forms and Templates 9
T Control of downloaded document copies by employees Document Control Systems, Procedures, Forms and Templates 3
T Document control ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 5
O Vendor vs Engineering Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A ISO9001:2015 Document control and training aids ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
J Document Control Software Needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Document Control - Revision Number in Document Names Document Control Systems, Procedures, Forms and Templates 4
I First Time Implementing Document Control for ISO-9001 - how far back do you go? Document Control Systems, Procedures, Forms and Templates 15
I Document Control Workflow Document Control Systems, Procedures, Forms and Templates 2
D ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions Document Control Systems, Procedures, Forms and Templates 51
R Changing Document Control software. Must I transfer EVERYTHING? Document Control Systems, Procedures, Forms and Templates 3
B Referencing to Supplier Outputs within our Document Control System 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Sidney Vianna IAF Mandatory Document #23 - Control of CB Franchisees and Agents Registrars and Notified Bodies 3
C Document Control - old revision vs new revision Document Control Systems, Procedures, Forms and Templates 22
D Software for advancing with Document Control Quality Assurance and Compliance Software Tools and Solutions 4
L IATF 16949 Cl. 7.1 - Lotus Notes for Document Control IATF 16949 - Automotive Quality Systems Standard 0
A Removing purchase order form from document control - should it be done? Document Control Systems, Procedures, Forms and Templates 9
I Video under Document Control SOP ISO 13485:2016 - Medical Device Quality Management Systems 2
S Change Control Form vs. Document Change Notification ISO 13485:2016 - Medical Device Quality Management Systems 3
S Document control for tooling drawings (Document control clause 7.5.3) IATF 16949 - Automotive Quality Systems Standard 5
J Document Control Newbie - Control of Nonconforming / Returns Log AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
R External Standards List (Document Control) Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
0 How to deal with resistance to GDP Document Control Discipline Document Control Systems, Procedures, Forms and Templates 7
dubrizo Restructuring Document Control Numbering System Document Control Systems, Procedures, Forms and Templates 3
G Migrating to an ISO 13485:2016 Compliant Document Control System ISO 13485:2016 - Medical Device Quality Management Systems 6
E Document Control MS Access Database Document Control Systems, Procedures, Forms and Templates 42
S Looking for Document Control Templates Document Control Systems, Procedures, Forms and Templates 1
S Document Control Guidelines in Engineering Projects - Excel sheets with VBA coding Document Control Systems, Procedures, Forms and Templates 3
E Challenges in document control, revisional control, and change control Document Control Systems, Procedures, Forms and Templates 8
tony s Performance Indicators for Document Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
T Document Control of FMEAs and Control Plans FMEA and Control Plans 5
T Is there a difference between form control and document control ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
x-files Proper Document Control Requests Document Control Systems, Procedures, Forms and Templates 1
D Nonconformance on document control - Unapproved document on production server Document Control Systems, Procedures, Forms and Templates 4
