Your OASIS representative should find the Nonconformity Report under the recent audit. The NCR(s) will tell what nonconformity(s) the auditor identified. The first question is whether containment is called for. If yes, there is a due date for that. In Section 2 there is a response due date. The corrections you enter have a planned and actual completion date fields and Corrective Actions have planned and actual dates. Don't forget the Cause Code, which one of 16 preset codes. Generally, they will want you to upload some Objective Evidence of the correction(s) once completed. If you modified some procedure to rev 4, then the evidence is rev 4 of the procedure. If you did a training, then a training record is objective evidence. If a finding was recorded as a Major Nonconformity, there is a higher degree of follow-up, which might involve a return visit by the auditor. In OASIS you should also find a copy of the Closing Meeting presentation (once it is uploaded) and that is another place to look for instructions. Good luck.
