How to apply Incoming (Receiving) Inspection to Customer Supplied Material?
harry
#11
Re: How to apply Incoming Inspection with customer supplied material?
Our material is cut parts cloth, leather (for seat trim cover), about 40,000 parts per lot.
1. These are not 'manufactured' products and hence unrealistic if you talk about 'zero defect'. Moreover, they are usually supplied in bulk, giving you no chance to inspect whatever is inside the whole bundle.
2. You can exercise some control through selection of suppliers but unfortunately, that is outside your scope.
3. I'll agree with the others that you treat it as customers property but do check with your higher ups on how the agreement or contract with your customer is structured.
4. Chances are, your responsibility is to check the raw material as it moves along your production line. The earlier you detect it, the less is the wastage (in terms of value added work on your part).
qusys
#12
Hi Nkson,
you are on the right way.
However I think that clause 7.4.3.1 deals with the quality of the purchased product. If your unique Customer ( that is also your Supplier for this kind of material you than assembly) does not issue any Purchase Order to formally sell you the material, I think that the clause can be meet with the 5th line of the 7.4.3.1 requirement "....utilizing another method agreed with the Customer".
In this sense I had asked for an eventual formal agreement with it for this process.
I think you are not required to have a written procedure for incoming.
As other Covers have said, you can refer to control plan and make reference to work instruction, after put them in controlled document, for example.
What about?
Thank you for all replying.
We don't have any agreement with Customer of Incoming inspection.
I also thought about applying 7.5.4 "Customer Property".
But at this time I was not sure of conformation with TS requirement 7.4.3.1 "Incoming Product Quality" if we don't have an individual Incoming inspection procedure in-place.
Currently, we only have procedure of Control NC Product mentioned about disposition of NC material, but not yet have any documented work instruction to show operators and QC how to verify suspect material (only verbal). If I make it, so no need any more Incoming Inspection procedure?
#13
I haven't read through all of the replies in this thread, so this may be redundant. 7.4.3.1 applies to purchased product. If you're not paying for the material your customer supplies, 7.4.3.1 doesn't apply. 7.5.4 (Customer Property) describes the requirements for "...customer property provided for use or incorporation into the product."
On the other hand, if you are paying for the material, 7.4.3.1 allows for a "...method agreed with the customer." This means that you don't need to have incoming inspection per se, and what you're currently doing, if put in writing by the customer, will suffice.
bobdoering
Stop X-bar/R Madness!!
#14
You should be treating customer supplied incoming material the same way you should any other supplier, except with the strict accounting of rejected parts that is required. That being said, you can only push so hard...they are your customer. Your best defense is you are trying to meet your quality system requirements - the same requirements that assures the quality they receive.
#15
There could be (and probably are) good reasons to treat customer-supplied material differently from purchased material. There should be some form of understanding regarding liability for value added to nonconforming customer-supplied material, for example. While this sort of thing should also be accounted for in dealing with purchased material, if there's no invoice involved there's nothing to debit when it comes to material supplied by customers.
bobdoering
#16
To be more specific, the verification of the incoming quality should not be affected. The accounting may differ, although an invoice may not be specifically involved, typically there is some type of accounting of the material shipped and received, as well as the difference of finished material outgoing (a part of the strict accounting I was referring to).
N
nkson
#17
:thanks: Thank you all! I know how to do now!
jhoniegudel
#18
Congratulations. You found the right place for asking about your problem.
Citizen Kane
#19
I think the fair and logical approach is to detect eventual failures before the production. So, incoming inspection should be linked either with your WRH or with a specific department (SQM - supplier quality, warranty, incoming quality, etc. - different dept. names).
The production should receive good parts - production must produce, not sort the pieces - they should verify if the value was added as it shoulded, not if they have something bad from the start. This is a clear task of your SQM/WRH ! And, if they don't have any people to cover the 100% inspection, than they should hire external company for sorting.
Also, it should be installed 100% check when a part is wrong in a lot - so, no for the whole lots. Still, if they are a lot of failures/defects, then should be 100% check.
S MDR - System and procedure pack article 22 and all sub processes that apply ISO 13485:2016 - Medical Device Quality Management Systems 0
shimonv Worthwhileness for a small startups to apply for EUA (Emergency Use Authorization) for COVID-19 US Food and Drug Administration (FDA) 17
qualprod Records where apply and stop recording everything? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Operator protection - When to apply table 7, Dielectric strength test voltage IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B How to apply external voltage to SIP/SOP IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
G Do HIPAA Rules Apply to a 3rd Party Logistics Shipper? Other US Medical Device Regulations 2
D Do purchasing controls apply to non-medical parts? ISO 13485:2016 - Medical Device Quality Management Systems 5
D Monitoring and measuring resources - Example of how section ISO 9001 7.1.5 would apply to a manufacture of software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Does ITAR apply to Exporters only? Other ISO and International Standards and European Regulations 6
E Does CQI-23 (Molding Sys. Asses.) apply to RUBBER molding? IATF 16949 - Automotive Quality Systems Standard 2
M Informational From RAPS – UK NB Will Not Apply for EU MDR/IVDR Medical Device and FDA Regulations and Standards News 11
B Does EMC Directive 2014/30/EU cease to apply when the Machine Directive 2006/42/EC is applicable? CE Marking (Conformité Européene) / CB Scheme 4
E Discussion between co-worker on tolerance and uncertainty and how to apply it. Thoughts? 17025 ISO 17025 related Discussions 1
B How to assess which directives and standards apply - Brewing and distilling products CE Marking (Conformité Européene) / CB Scheme 1
N Student trying to apply Lean Six Sigma on a Construction project in my thesis Lean in Manufacturing and Service Industries 3
F Device Standards - Managing Changes to existing standards that apply to our devices Other Medical Device Related Standards 1
A ISO 9001:2015 - How to apply 7.1.5 to an organization performing only design ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F What directives/regulations apply to Analyte Specific Reagents (ASRs) in EU EU Medical Device Regulations 0
F Can an individual apply for an MDEL in Canada, as an establishment? Canada Medical Device Regulations 6
N Apply control limits to a non-normal distribution Statistical Analysis Tools, Techniques and SPC 13
M IATF Clause 8.4.2.2 - What procedures does this apply to? IATF 16949 - Automotive Quality Systems Standard 1
S Optical coherence tomography (OCT) device - Do we need to apply IDE? Other US Medical Device Regulations 0
R Communication of CSR's throughout the organization and who they apply to IATF 16949 - Automotive Quality Systems Standard 4
M Apply for a job when no opening is posted? Career and Occupation Discussions 64
M AS9100 D - How to apply 8.1.1-8.1.4 to a coating service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Does ISO 10993 Apply to Packaging? (e.g. Travel Case) Other Medical Device Related Standards 4
C Optic Patchcord Cables - Does 8.3 (Design) Apply Here? ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Does the Scope of 21 CFR Part 820.72 (Equipment) apply to Design? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Does IATF 16949:2016 Clause 7.3 (now 8.3) Apply to "Grandfathered" Products IATF 16949 - Automotive Quality Systems Standard 4
Moncia Tall Manufacturer - VDA Audit - Which parts of the audit apply to us? IATF 16949 - Automotive Quality Systems Standard 4
Q How to apply 21 CFR Part 11 and/or cGMP in the Life Sciences industry Qualification and Validation (including 21 CFR Part 11) 3
V When and How to apply the Bayes Success Run approach for Sample Size Determination Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
A 3 scenarios of accident and I want to apply OHSAS18001 Occupational Health & Safety Management Standards 2
I ISO 26262 standard may apply to automotive IC suppliers IATF 16949 - Automotive Quality Systems Standard 1
GStough Looking to Apply for IRCA Certification Using 2nd Party Audits Career and Occupation Discussions 2
M Does AS9120 (aerospace first article inspection) apply to all customers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J If/how to apply LVD (Low Voltage Directive) in this case CE Marking (Conformité Européene) / CB Scheme 6
A How soon can I apply for ISO 9001:2015 certification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Who needs to apply for a CLIA waiver 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Does Record Control apply to the company business processes as well? Records and Data - Quality, Legal and Other Evidence 6
P When can we apply DOE (Design of Experiments)? Six Sigma 8
L AS9100 7.5.2 Special Processes - Clean Room Apply? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
M Not sure what standards apply to non-electrical patient bed EU Medical Device Regulations 6
A Shall I apply for this job position (Quality Manager)? Career and Occupation Discussions 5
V Can we apply bracketing & matrixing simultaneously for stability studies @ ICH Q1D US Food and Drug Administration (FDA) 1
N Which regulations apply to Medical Stand Alone Software in Europe? ISO 13485:2016 - Medical Device Quality Management Systems 3
W Where to apply a Class I Medical Device Barcode in Canada Other Medical Device Related Standards 5
A When to apply Markov Chain Analysis over Weibull Analysis Reliability Analysis - Predictions, Testing and Standards 2
