Did the supplier send you the wrong material? What is the documentation provided to the incoming inspector? Is there a specification sheet? How is acceptance documented?Hello everyone
First check point, receiving raw material from supplier, but didnt check the paper´s thickness
How does the person responsible for checking the thickness know what to do in verifying the material? Why is this done if the material was accepted as conforming at incoming inspection?Second check point, Before starting production, have to check thickness, and was too confident, he thought was the same product as always , no need to check it.
If the material is checked twice before the Quality Coordinator does the final check, why would thickness of the paper be checked again?Third check-point Quality coordinator, even if procedure, states to perform the final checking against customer requirements before the release, checked only some aspects not all what is required, he supposed everything was ok.
The root cause is that the supplier of the paper sent the wrong material. You shouldn't have to verify it three times in order to have confidence that the material is as specified.IT seems overconfidence , and root cause???? not easy to find it nor eliminate it.
So you're writing a CAR for the operation where someone did the right thing? What about the supplier?I may apply resources to find something but nothing really applicable under a QMS.
What do you do in these cases?, What have you done in the past, or how do you analyze a case like this?
To start off, I´m writing up a Corrective action in the final process where was detected.
Also, this is not a case of shared responsibility as has been claimed in previous replies. Each person had individual responsibility in this case. It would be shared responsibility if two or more people conferred and decided jointly what to do.
