How to satisfy with AS9100 Clause 8.4.3 a, Information for external providers?
ImLost
Auditor issued a non-conformance stating, the process to communicate to external providers its requirements for the processes, products, and services to be provided including the identification of relevant technical data is not effective.
In this instance; purchase orders sent to the supplier did not have a configuration (Rev) level to be provided, however, drawings used in Receiving Inspection activities contain product configuration level.
As a business, we purchase exactly what the customer requests, and very rarely is a revision required. While we originally stated that the revision requirement would be removed in RI, the Auditor stated this is in relation to purchase orders, not RI.
We're stuck - we don't have to request revisions if there is no requirement (most items are COTS), and purchasing is toying with the idea of a statement "to latest mfg spec revision".
Can this even be done?
Sidney Vianna
Post Responsibly
Re: AS9100 Clause 8.4.3 a
If the hardware being procured is subject of revision level changes, your purchasing documents MUST state the proper revision levels.
In the aerospace sector, sometimes, a hardware revision level results into a new part number. In those cases, a revision level would be redundant. But, and once again, if you can procure parts at different revision levels, that information must be in the PO or alternative documents.
Since prevention via risk based thinking is a given, to rely on receiving inspection to catch any possible discrepancy is not "preventive enough".
Rev. C of AS9100 was more explicit on the requirement:
7.4.2 Purchasing information shall describe the product to be purchased, including, where appropriate the identification and revision status of specifications, drawings, process requirements, inspection/verification instructions and other relevant technical data,
Golfman25
Well it does say "where appropriate."
In our case (non-aerospace) with our customers revisions levels are a mess. Somehow they constantly fail to inform us of rev level changes. We only find out because we verify the rev level when they order. So it is usually a good idea to know the latest rev level. So the question is why wouldn't you include the rev level? It should be relatively easy -- just keep your system updated.
BoardGuy
Here is some clarification from the IAQG on 8.4.3:
Question: The standard 9100:2009, clause 7.4.2 requires that purchasing information shall identify purchased product including revision status of technical data. The standard 9100D, clause 8.4.3 does not include this requirement. This information is no more required?
Answer: The clause 8.4.3 requirement...identification of relevant technical data...would include the revision status.
Re. IAQG 9100:2016 Clarifications, Rev. Date: 11/2017
ImLost
But, not all parts have revisions - at least in our case, only parts which are custom - otherwise, the customer has no requirement (99% of the time) which revision we purchase/receive.
The impracticality of identifying a revision when
a) the customer has no requirement
b) we are never notified of a Revision rolls from a supplier
is large - its just not possible when the revision is not even known.
Putting a revision on every PO... are we just fighting the actuality that this just needs to be done?
Golfman25
I think you are overthinking it. If the revision is none, then it's none. So you identify it as "none, NA, 0, -" or something. As for not being kept up do date on the current revision, join the club. All you can do is according to the latest revision level you have notification of. Do you use some type of ERP or purchasing program where you could keep the revisions recorded? Should be real easy.
BoardGuy
You need to remember that it is the technical data (specifications, drawings etc.) you are communicating to your suppliers not the other way around. If you are ordering catalog items, then you should list within your purchasing procedure a statement something like this one modified from Paragraph 1.3 found on Page 13 of AS9102B:
“Unless contractually required by the customer, a revision indicator for standard catalogue items, Commercial-Off-the-shelf (COTS), or deliverable software does not apply.”
If you are ordering raw materials (metals, plastics, etc.) to an ANSI or ASTM specifications, then your purchase order should state the specification and its revision especially if you are receiving material test reports. If you do not specify, any revision of these materials will meet the PO requirements and contractually you’re stuck with it.
Ralba
So to summarize to make sure I understood the conclusion to the thread correctly, the revision requirement must be communicated when needed, and the process by which it may be communicated must be part of purchasing in order to ensure it is able to be done for the customers who require revision levels on components?
Kronos147
...purchase orders sent to the supplier did not have a configuration (Rev) level to be provided, however, drawings used in Receiving Inspection activities contain product configuration level.
Did the PO reference the drawing or configuration level?
Do you feel comfortable citing the exact wording of the objective evidence reviewed (minus any names and exact PO\part numbers, etc.)?
Kirby
I realize this is an older discussion and I'm hoping my issue is relevant, so... I'm trying to determine if a revision to our Customer Requirements doc is needed to address the communication to suppliers requirements. (This is an Opportunity for Improvement / Preventive Action rather than an audit finding CA.) The current practice has evolved from the original through revisions to the procedure that supports compliance to 8.4.3 and I have began to question if it has been a bit corrupted with respect to the information actually provided to the suppliers. A statement on our P.O.s directs suppliers to our website where our requirements can be reviewed. This document addresses some of the items noted in 8.4.3, but not all of them. I understand that the statement in 8.4.3 is that the organization shall communicate " its "requirements and I've read various opinions as to what that really means. Some say that you needn't include the items that do not typically apply while others feel it's just safer to include everything, with phrases such as "when applicable" or "when appropriate" or "when required" or "when requested", etc. I have a draft of a revision to our document that covers all of the items in 8.4.3 where I've used some of these terms - "Special requirements shall be provided, when applicable." (just an example, it's not written exactly like this). What's the consensus ? Has anyone had similar issues / questions, if so , what was the final resolution? Any input that you have would be appreciated. Thanks in advance.
B How to satisfy clause 5.7.1.5 process validation for valve production API 6D Oil and Gas Industry Standards and Regulations 13
A How to satisfy the "Interested Party" Management Review Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Does a process map satisfy 21 CFR 820.20(d) (Quality Plan)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Q The ability of computer software to satisfy the intended application ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
M ISO 14971, IEC 60601 Satisfy 98/37/EC, 2006/95/EC, 2004/108/EC Directives? Other ISO and International Standards and European Regulations 3
H Form that will satisfy Design Review and Design Verification Requirements (7.3) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
W MSA on a Hardness Tester to satisfy a Customer who is requiring Hardness Cpk Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
R 6.2.2 - Any other ways to satisfy it if No Performance Evaluation carried out? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
I Confirmation of Computer Software to satisfy Intended Application Misc. Quality Assurance and Business Systems Related Topics 2
M 8.2.1.1 - Customer Satisfaction - How to satisfy the end requirement? IATF 16949 - Automotive Quality Systems Standard 1
R IEC 62133 to satisfy 60601-1 3rd edition - What happen to 60086-4 Other Medical Device Related Standards 18
M How to satisfy the Management Review requirement without a meeting? Management Review Meetings and related Processes 29
D SPC Software that will satisfy auto/furniture data submissions - Opinions wanted Quality Assurance and Compliance Software Tools and Solutions 5
J CMM MSA - Can you use 1 GRR to satisfy requirement for all Key Features? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
A Sample Documented Procedures that satisfy 4.4.6 Operational Control wanted ISO 14001:2015 Specific Discussions 2
D Documentation used to satisfy ISO 9001:2008 Clause 7.3 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
I Reply requirements to satisfy 21 CFR 820.198(e) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
N Customer Care - Building relationships to acquire, satisfy and retain customers Customer and Company Specific Requirements 2
C Definition ATP Requirements (QAT, FAT, OSAT, FAI) - How to Satisfy FAT and OSAT? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
H How to Satisfy the Auditors with regards to these ISO Clauses? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Will the Certificate of Accuracy that comes with thread gages satisfy ISO9001? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
J How can we satisfy TS 16949 clause 4.2.3.1 Engineering Specifications IATF 16949 - Automotive Quality Systems Standard 10
E What is Required of Me to Satisfy the NSF Auditor? TS16949 Internal Audits IATF 16949 - Automotive Quality Systems Standard 2
ScottK Will this satisfy 8.2.1 Customer Satisfaction? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A What would we do to satisfy ISO 17020:1998 Clause 14.2 General Measurement Device and Calibration Topics 3
C Minimum number of procedures to satisfy ISO9001 requirements Document Control Systems, Procedures, Forms and Templates 14
Q ISO 9001 Clause 7.6 - Computer software to satisfy the intended application Records and Data - Quality, Legal and Other Evidence 8
S How to confirm the ability of computer software to satisfy the intended application? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
K Identifying production dies to satisfy the 7.5.4 Customer Property clause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K How can we satisfy TS16949 Clause 8.2.2.3 Product Audit IATF 16949 - Automotive Quality Systems Standard 3
K How can we satisfy TS 16949 Clause 7.1.1 - Quality Plan - Visteon Supplier IATF 16949 - Automotive Quality Systems Standard 6
Marc Customer Satisfaction - Satisfy customers, make money Philosophy, Gurus, Innovation and Evolution 8
A Is ISO enough to satisfy these TQM approval questions? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
S 8.2.3.1 Reliability, Maintainability and Availability - How to satisfy requirement? Reliability Analysis - Predictions, Testing and Standards 4
J Statistical Data Analysis - How to satisfy ISO 9001 : 2000, Clause 8 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
N Customer Satisfaction - How to satisfy sub clause 5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J How many procedures to satisfy TS 16949 and what are they? IATF 16949 - Automotive Quality Systems Standard 6
Scott Catron Contract Manufacturing Pre-Qualification? How much 'due diligence' to satisfy the FDA ISO 13485:2016 - Medical Device Quality Management Systems 7
apestate How do I satisfy 4.1 - Identify and determine the sequence and interaction processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
I Stating our goals to satisfy customers - What words can we use? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
T Internet Report Card to Satisfy Customer Satisfaction - Delivery Performance, PPM IATF 16949 - Automotive Quality Systems Standard 21
L Field Returns - 6.3.2 s - Contingency plans to satisfy customer requirements IATF 16949 - Automotive Quality Systems Standard 9
A ISO 9000 Clause 4.2.2 - Interactions Between Processes - How do you satisfy this? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
Z What are the SPC Requirements to satisfy clause 4.20? QS-9000 - American Automotive Manufacturers Standard 2
T What should be considered or asked to certified body auditors before selecting them for AS9100 Audit? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
L Counting contractors for determining AS9100 audit days AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T AS9100 Internal Audit (Quality System) Program AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T Guiding document or resource to process AS9100 audit findings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
T Clarity on requirements for indirect suppliers per AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
L AS9100 work for another site outside scope AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
