IATF 16949 / ISO 9001:2015 audit criteria
Rameshwar25
#11
Yes, all forms should be controlled and there should be a list of formats in use. This is separate matter and is covered by procedure for document control.
I have included forms (formats) in audit criteria list because formats too have sometimes requirements written in them. For example, i have seen a sampling plan in formats for final inspection. This sampling plan becomes part of audit criteria.
sometimes, dimensional requirements (specifications) are already printed in blank forms. These specifications are also part of audit criteria.
eule del ayre
#12
Like the Masterlist of the forms sir Rameshwat25? for all the process including on the PCDA cycle?
Rameshwar25
#13
PDCA is an approach and does not specify any requirement for any format. For implementation of any standard, you need to fill some forms. Like you will record minutes of management review for which you need a format. You need to make a annual audit plan for you need a format. All these format should be controlled (given unique identification number, master copy approved etc).
i think your question of audit criteria is answered. You can search posts for information on document control on this website. Lot of information is available. If you still need help, you can start a new post on document control.
eule del ayre
#14
I mean sir, the forms included in the PDCA cycle such as Planning, support group and operation, the forms needed underlying the PDCA cycle
Mr.Ruiz
#17
what are the criteria for ISO Audits? just in case anyone knows
for certification purposes
As defined per ISO 19011:2018
5.5.2 Defining the objectives, scope and criteria for an individual audit.
The audit criteria are used as a reference against which conformity is determined. these may include one or more of the following: applicable policies, processes, procedures, performance criteria including objectives, statutory and regulatory requirements, management system requirements, information regarding the context and the risks and opportunities as determined by the auditee (including relevant external/internal interested parties requirements), sector codes of conduct or other planned arrangements.
Basically, all documented information that helps you prove the consistency and compliance of your QMS should be part of, your QMS and, part of the Audit Criteria for each individual audit.
Like AndyN says... If you have documented information (e.g. forms) not included in your QMS, what is the reason for it existence? try to review all of your documents against 7.5 clause, and decide what should exist and what not, and those that you choose to be part of your QMS, will be part of your A.C.
eule del ayre
#18
If you have forms which are not, in some manner, linked to your procedures etc. why are they there?
First and foremost Sir Andyn, i'm not that too professional enough to explain this documented files here in our company because i'm just a new employee here and this industrial plant we have is not in line with what i graduated to(Graduated chemical engineer), so this things are new to me. As i was saying some files here sir, are so redundant, like they're the same in content but different titles, some are not registered and some are, like what's the use of this one, it just that it doesn't sink in, in my own perspective. And some(supervisors) says that we don't need to control that it's for our monitoring. And i was like "okay" (for i'm just a newbie)
B Updated IATF 16949 - Will IATF 16949 get revised when ISO 9001:202X is released? IATF 16949 - Automotive Quality Systems Standard 4
S Thoughts on managing ISO 9001, 13485, IATF 16949 and 17025 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B Go Beyond ISO 9001 WITH IATF 16949 (January 28) [Paid] Training - Internal, External, Online and Distance Learning 1
M IATF 16949:2016 clause 8.4.2.3 - We don't have ISO 9001:2015 certificate IATF 16949 - Automotive Quality Systems Standard 26
Crimpshrine13 IATF 16949 and ISO 9001 Remote Support - Pass Through Inventory IATF 16949 - Automotive Quality Systems Standard 20
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
S Necessity of Legal Register to conform to ISO 9001, ISO 14001, IATF 16949 ISO 14001:2015 Specific Discussions 6
B IATF 16949 manufacturing cell in ISO 9001 factory? IATF 16949 - Automotive Quality Systems Standard 15
A ISO / IATF 16949 Requirements for Second Party Services IATF 16949 - Automotive Quality Systems Standard 10
Coury Ferguson Report the CB... Certification Audit (IATF 16949) not to ISO 17021 Registrars and Notified Bodies 1
xfngrs How similar or different are IATF 16949 Vs. ISO 13485 IATF 16949 - Automotive Quality Systems Standard 0
GStough IATF 16949: 2016 and ISO 9001:2015 - How Similar Are They? IATF 16949 - Automotive Quality Systems Standard 15
Sidney Vianna IATF 16949:2016 still doesn't get 7.1.4 of ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 15
J 3 Questions about Management Review - ISO 9001 and IATF 16949 Management Review Meetings and related Processes 4
QMMike ISO (in search of) IATF 16949 vs. TS 16949 changes summed up IATF 16949 - Automotive Quality Systems Standard 7
C Upgrading from ISO 9001:2015 to IATF 16949:2016 - Anyone have a gap analysis tool? IATF 16949 - Automotive Quality Systems Standard 2
G Combining ISO 9001:2015 and IATF 16949:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
F IATF 16949 - Cl. 8.4.2.3 - Which type of suppliers could be exempt of ISO 9001 IATF 16949 - Automotive Quality Systems Standard 16
K Top Executive Management ISO 9001:2015 and IATF 16949 Overview IATF 16949 - Automotive Quality Systems Standard 4
M ISO/TS16949 to IATF 16949:2016 Gap Analysis Questions IATF 16949 - Automotive Quality Systems Standard 2
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
Anerol C IATF or ISO TS 16949 rules about Scope of QMS IATF 16949 - Automotive Quality Systems Standard 7
B Rules for Achieving IATF Recognition: 4th edition for ISO/TS 16949 IATF 16949 - Automotive Quality Systems Standard 97
F ISO/TS16949 (to become IATF 16949:2016) alignment to ISO 9001:2015 IATF 16949 - Automotive Quality Systems Standard 79
S ISO/TS 16949 IATF Rules: 2.9 Management of Impartiality IATF 16949 - Automotive Quality Systems Standard 8
J Certification Scheme for ISO/TS 16949:2002 - Rules for achieving IATF Recognition IATF 16949 - Automotive Quality Systems Standard 4
automoto Requirements of certification bodies recognized by IATF for ISO/TS 16949:2002 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 12
Sidney Vianna Ten CB's have had their IATF contract terminated - ISO/TS 16949:2002 Registrars and Notified Bodies 3
Icy Mountain IATF Guidance to ISO/TS 16949:2002 - Not auditable? IATF 16949 - Automotive Quality Systems Standard 16
Marc IATF SIGNIFICANTLY Changes ISO/TS 16949:2002 'Rules' ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 5
H IATF approved vs. ISO 9001 / TS 16949 Auditor Requirements IATF 16949 - Automotive Quality Systems Standard 11
A Rules for Achieving IATF Recognition - A Second Edition for ISO/TS 16949:2002 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 10
T IATF Guidance to ISO/TS 16949:2002 ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 10
S IATF 16949 Internal Audit Example IATF 16949 - Automotive Quality Systems Standard 7
B Remote IATF 16949 audit preparation General Auditing Discussions 10
R IATF 16949 Certification for new site with transferred product--what is the impact with CSR and scorecards? IATF 16949 - Automotive Quality Systems Standard 0
B IATF 16949 Cert Expire- New certification body IATF 16949 - Automotive Quality Systems Standard 5
M IATF 16949 - Audit of Remote Location/Support Site and IT IATF 16949 - Automotive Quality Systems Standard 4
O Informational Ford Motor Company Customer Specific Requirements for IATF 16949:2016 - 08 Jan 2021 Customer and Company Specific Requirements 0
O Release of Sanctioned Interpretations (SIs) related to Rules 5th Edition and Sanctioned Interpretations related to IATF 16949:2016 IATF 16949 - Automotive Quality Systems Standard 0
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
R IATF 16949 - Outsourcing of internal audits Internal Auditing 10
Crimpshrine13 Laboratory Scope - Calibration vs. Test Methods - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 3
L IATF 16949 certification costs IATF 16949 - Automotive Quality Systems Standard 3
B FCA US Customer Specific IATF 16949- Critical Characteristics 8.6.2 Customer and Company Specific Requirements 0
