Manufacturing Process Auditor Requirements - IATF 16949
jimmymustang06
I'm hoping someone can help with this, I've been researching for awhile and I can't find an answer. This is a manufacturing plant and I'm needing to know if I have folks only auditing the manufacturing processes (cutting, cleaning etc.) on the three different shifts, do they have to go through the entire training that an internal auditor that does full system audits does?
jimmymustang06
... and right after I typed the question, I think I found the answer... I believe I'm trying to convert Layered-process Audits to Manufacturing Process Audits.. LPA auditors wouldn't necessarily have to be trained, but an auditor doing a "Manufacturing Process Audit" as defined by IATF, would need to be "Trained"... Am I correct on this?
jimmymustang06
I guess I need to know what training an auditor would need to perform 9.2.2.4 Manufacturing Process Audit ? I realize it would be much better to have every auditor fully trained as an internal auditor, but it gets difficult taking folks from an off-shift out of production for 3-5 days to be trained.
Golfman25
You need to look up the latest sanctioned interpretations. They have relaxed some of the internal audit competency requirements.
jimmymustang06
Golfman!!!! THANK YOU SO MUCH!!!! This is perfect!!! I only need to train them on the process, control plan and PFMEA.. That's so much easier than a 3-day workshop.. A question for ya, how did you know about this document? Should my registrar be telling me about them or something? I mean jeez, I would think spending over $15k a year, to maintain a certificate to a standard, would entitle me to receive "updates" to the standard!?
Jen Kirley
Quality and Auditing Expert
Golfman is terrific, yes? :) I agree it would have been nice if the CB had told you more of IATF, but I can at least share their web site with you in case you haven't seen it yet. Better late than never, I suppose...
jimmymustang06
Yes, thank you. I did go there and sign up for their newsletter or whatever is called so maybe now I'll know if there is another revision.. funny, they call them "sanctioned interpretations", they're friggin revisions, good Lord!
UncleFester
Be careful - the clause you state - 9.2.2.4 is for Product Audit. Clause 9.2.2.3 is Manufacturing Process Audit. The S.I. No. 4 has relaxed the requirements for manufacturing process audits and product auditors, but don't forget that any of your customer's specific requirements may over-rule any of these.
For example, General Motors require layered process audits, annual special process audits, and auditors qualified as an ISO9001 Lead Auditor and a minimum of 5 years experience of the process under audit.
FCA require members of site senior management to perform process audits at least weekly.
You should also consider any 'special' processes that you have (welding, plating, painting etc.) which may require more thorough audit.
Golfman25
Well you have to be a member of the secret society and know the secret handshake.
To be honest, I usually find out that there was an update here. Then I head over to IATF to check it out. It's something you do need to monitor as you audit/update your system. Don't expect much help from the powers that be.
jimmymustang06
We are a tier 2. Basically bulk commodity. If you look under the hood of your car and see aluminum HVAC tubing, we made the tube most likely, but just the tube. We don't bend or form or any of that. We do have GM sort of, it's General Motors Components Holdings GMCH, they are the closest customer we have to being an OEM. I'm assuming that if I have production personnel, front office personnel and managers doing Manufacturing Process Audits, this would suffice as LPA's. I may be wrong in that assumption. As for auditors qualified as leads, in the past we took exemptions to this. I believe Visteon used to require this, but as of a couple weeks ago we do now have an employee who is a certified lead auditor, but thanks for the heads up, I did not know that GM required this now.
L Most appropriate Auditor to check the FMEA & PCP of a Manufacturing Process IATF 16949 - Automotive Quality Systems Standard 5
Z Rapid audit template for plastic parts manufacturing process Manufacturing and Related Processes 12
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
L Manufacturing Process Audit Help IATF 16949 - Automotive Quality Systems Standard 6
M Description of the requirements of clause 9.2.2.3 manufacturing process audit- needs your feedback IATF 16949 - Automotive Quality Systems Standard 0
Watchcat Does 820.30 include the manufacturing process? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Watchcat Does ISO 13485 7.3 include the manufacturing process? ISO 13485:2016 - Medical Device Quality Management Systems 14
K Differences between Manufacturing Process Audit & Layered Process Audit Lean in Manufacturing and Service Industries 4
C IATF 16949 8.3 Exclusion - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 6
G QMS requirements for legal manufacturer when outsourcing manufacturing process Other Medical Device Regulations World-Wide 25
I ISO 10993 Biocompatibility Requirements - manufacturing process chemicals Other Medical Device Related Standards 8
S Improving Quality inspection gate in one piece flow manufacturing process Manufacturing and Related Processes 0
H IATF 16949 9.2.2.3 - Manufacturing process audits IATF 16949 - Automotive Quality Systems Standard 11
M Requirement for manufacturing process validation in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 8
J Lean MFG (manufacturing) process and Work order templates Lean in Manufacturing and Service Industries 6
A Is a Manufacturing Process Sheet required for each Component? Manufacturing and Related Processes 4
V IATF 16949 Manufacturing Process & Product Audits IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 Cl. 8.3 - Manufacturing process design and development IATF 16949 - Automotive Quality Systems Standard 1
M IATF 16949 - Cl. 8.3.3 - Product design inputs, manufacturing process design inputs IATF 16949 - Automotive Quality Systems Standard 4
L IATF 16949 Cl. 8.3.3.2 Manufacturing process design input - Process capability IATF 16949 - Automotive Quality Systems Standard 1
S Manufacturing Work Instruction examples that include process pictures Manufacturing and Related Processes 3
A IATF 16949 Cl. 8.3.5.2 e) - Manufacturing Process Flow Charts & Layout IATF 16949 - Automotive Quality Systems Standard 5
C Manufacturing Process Work Instructions - Format Manufacturing and Related Processes 4
B Process Risk Assessment Example for a Manufacturing Company Quality Tools, Improvement and Analysis 2
O PFMEA - Reducing Severity (S) Ranking - Manufacturing Process Design Changes FMEA and Control Plans 4
I Manufacturing build requests - process and form Other Medical Device Regulations World-Wide 4
Crimpshrine13 Is VDA 6.3 required for Manufacturing Process Audit (ISO/TS 16949)? Manufacturing and Related Processes 5
M Manufacturing Process Validation Destructive Testing Sampling Plan Advice Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A SOP for Marketing Process for a Medical Devices Manufacturing Company wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Process FMEA w/ Contracted Manufacturing ISO 14971 - Medical Device Risk Management 2
D Number of Manufacturing Lots for Process Validation Manufacturing and Related Processes 10
Q Medical Device Manufacturing Process Monitoring Best Practice ISO 13485:2016 - Medical Device Quality Management Systems 2
J What is Incorporation in Assembly/Manufacturing Process in FMEA? FMEA and Control Plans 4
T What tools are there to monitor a Manufacturing Process or Operation? Quality Tools, Improvement and Analysis 2
D Membrane Filter Materials - What process and Equipments used in Manufacturing? Manufacturing and Related Processes 1
C Severity of Effect on Process (Manufacturing/Assembly Effect) Scrap or Reworking FMEA and Control Plans 3
A ISO/TS 16949 - 7.3.3.2 Manufacturing Process Design Output IATF 16949 - Automotive Quality Systems Standard 6
Chennaiite Control Chart for Non-Manufacturing Process Indicators - Is it worth? Statistical Analysis Tools, Techniques and SPC 1
T Manufacturing Process Deviation linked to DMR (Discrepant Material Report)? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
L Changes to Manufacturing Process or Device with CE Marking CE Marking (Conformité Européene) / CB Scheme 2
L Process Flow Chart for manufacturing of Light Switch requested Process Maps, Process Mapping and Turtle Diagrams 5
D How to measure Process Capability for Homogeneous Batch Manufacturing Capability, Accuracy and Stability - Processes, Machines, etc. 4
kedarg6500 Manufacturing Process Design and Development Review ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S TS 16949 7.3.3.2 Question - Manufacturing Process Design Output. IATF 16949 - Automotive Quality Systems Standard 8
R SOPs in Manufacturing - Has anyone got a management process that works? Document Control Systems, Procedures, Forms and Templates 4
J Production Process vs. Manufacturing Process - Differences IATF 16949 - Automotive Quality Systems Standard 2
N Causes of Disbond Defects in Composites Manufacturing Process Manufacturing and Related Processes 7
T Calculation of Sigma Level of Defects for a Manufacturing Process Statistical Analysis Tools, Techniques and SPC 8
