PPAP Requirements for Tool Repair or Refurbishment
Understanding that A PPAP is required when production of a new product or part is planned and when there is any significant change to a product or process, what is the actual requirement for a PPAP when a tool is repaired or refurbished and there is no change to the product or process?
We have suppliers that submit Level 2 PPAPs to us upon request. We have suppliers that supply an ISIR with dimensionals and parts. What I am looking for is what the actual requirement is. Is there a point in a repair where it becomes a significant change? Are we asking too much of our suppliers or not enough?
I should mention that these are our tools manufactured at the supplier and the supplier is running production parts off of the tools.
This is covered in section 3 of the AIAG PPAP manual, and the requirement is to notify the customer who will then determine whether to require PPAP.
Example 2: new or modified tools, dies, molds - perishable tools are specifically excluded. This only applies to tools that can be expected to influence the final product
Example 3: upgrade or rearrangement of existing tooling/equipment - This specifically excludes normal maintenance, repair or replacement of parts for which no change in performance is expected and post repair verification activities have been established.
Thanks for the quick reply.
In our case, there is no change at all to the tool. It is wear that has shown a trend in the quality of the product. The only repair will be returning the tool to it's original condition. In this case, based on what you are saying, we should not require a PPAP from our supplier to make the repair.
Without specific details, this appears to be what is called routine maintenance, which would not require a PPAP. However, you are the customer, so you make the rules.
Thanks again. A big part is whether "our" customer will require a PPAP or not from us. There is nothing in the contract that is different than the AIAG requirement. We of course want to put our quality first and reduce risk. But, at the same time, balance that with cost and timing. Trying to put a standard around that is very difficult except putting the general statement in there that "The customer can request a PPAP at any time." I am starting to see more and more PPAP fees from suppliers. It helps to have this forum to bounce seemingly simple questions off of when the "gray" areas come into play.
It is hard to fight these charges if you have an existing supplier and you suddenly add such a requirement, but you can proactively handle this with new suppliers, or when you renegotiate a contract. Simply add PPAP requirements to the contract and tie PPAP approval to your company's payment for tooling. If the supplier cannot demonstrate via PPAP that the mold they had made can produce product that meets spec, you don't pay them for it. I found out at a previous company that the suppliers that complained the loudest had the most difficulty proving their product met the requirements.
C PPAP requirements for consumer product APQP and PPAP 2
P Managing How PPAP Requirements are Communicated in the Manufacturing Process and to Suppliers APQP and PPAP 5
K OEM specific requirements - PPAP was rejected by STA Customer and Company Specific Requirements 5
Pau Calvo PPAP customer requirements in the APQP APQP and PPAP 25
eule del ayre List of Level 3 PPAP requirements for automotive suppliers APQP and PPAP 20
P Paint shop vs PPAP requirements IATF 16949 - Automotive Quality Systems Standard 5
Sidney Vianna AS9100 News PPAP in the Aerospace Sector - What is it? AS9145 - Requirements for Advanced Product Quality Planning and Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
M Annual Layout requirements for PPAP/Control Plan FMEA and Control Plans 6
G Supply Chain PPAP Requirements APQP and PPAP 11
P Automotive Supplier PPAP Level Requirements Supplier Quality Assurance and other Supplier Issues 12
G PPAP 4th edition or VDA - VW Requirements APQP and PPAP 2
Y Customer Specific PPAP Level 3/4 Requirements - Fastener Manufacturer APQP and PPAP 2
A Cost of Deviating Away From PPAP Requirements APQP and PPAP 3
V Inactive Gauge Retention Time - PPAP Section 6 Requirements APQP and PPAP 1
I AS9100 PPAP requirements for outside Heat Treat vendors/suppiers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M PPAP requirements when adding Part Transfer Robots between Machines APQP and PPAP 1
P Bulk Material Requirements Checklist to send along with my PPAP APQP and PPAP 2
B Bulk Materials (Lead {Pb} Alloys) PPAP Requirements APQP and PPAP 5
T PPAP Requirements for Contract Manufacturers APQP and PPAP 4
J PPAP (Production Part Approval Process) Requirements for Annual Revalidations APQP and PPAP 1
V PPAP Requirements including GMW 3179 Zinc Plating Specification Requirements APQP and PPAP 3
V PPAP Requirements for Plating a "Family of Parts" APQP and PPAP 8
P PPAP Requirements for Sub-Assemblies APQP and PPAP 6
V Plating Supplier PPAP Revalidation Requirements - A-Coat GM 9984132 Plating Process APQP and PPAP 1
V PPAP - Requirements when Cpk is <1.67 - 100% Sort for Defectives APQP and PPAP 8
R Does anyone have the list of Toyota PPAP requirements? APQP and PPAP 6
M For Bulk Material (eg. paint), are there any guidelines for Ford PPAP Requirements? APQP and PPAP 1
B TS16949 Annual PPAP Submission Requirements for Ford and Chrysler Parts IATF 16949 - Automotive Quality Systems Standard 2
B TS 16949 PPAP/ Layout Inspection Frequency Requirements APQP and PPAP 8
Q Level of PPAP - Bulk Chemicals Supplier Requirements APQP and PPAP 2
F PPAP Material Test Results Requirements - Material Supplier Identification QS-9000 - American Automotive Manufacturers Standard 1
S PPAP Requirements for Submission to our Customers for a New Supplier APQP and PPAP 1
Q Supplier PPAP Requirements - TS 16949 Clause 7.3.6.3 IATF 16949 - Automotive Quality Systems Standard 12
S Can PPAP be submitted when not all customer requirements can be met? APQP and PPAP 5
K Supplier PPAP Requirements - Level 3 or Level 4 APQP and PPAP 6
J PPAP Requirements - Suppliers who are changing their Suppliers APQP and PPAP 7
L PPAP List Requirements - Molds, Tools or the Checking Tools? APQP and PPAP 5
J Requirements for Retaining PPAP Master Samples APQP and PPAP 2
J Prior Notice of Sub-Supplier or Material Source Change - PPAP Requirements Question APQP and PPAP 13
J PPAP Requirements Question APQP and PPAP 4
S PPAP requirements for sub-suppliers APQP and PPAP 5
C Honda PPAP requirements APQP and PPAP 12
H Requirements in TS for PPAP - Full PPAP or as per Customer Requirement? IATF 16949 - Automotive Quality Systems Standard 14
S Are the AIAG document (FMEA, PPAP, SPC, MSA, APQP) guidelines or requirements FMEA and Control Plans 6
K PPAP Requirements for Raw / Bulk Materials? APQP and PPAP 6
R GM revised its Specific Requirements for TS16949 and PPAP 4th, effective immediately Customer and Company Specific Requirements 4
B PPAP Document Submission and Retention requirements APQP and PPAP 21
B PPAP Requirements - Laboratory results and IMDS system RoHS, REACH, ELV, IMDS and Restricted Substances 12
M DaimlerChrysler (DCX) Customer Specific Requirements for PPAP 4th Edition Customer and Company Specific Requirements 8
Sidney Vianna Chrysler Customer Specific Requirements For PPAP 4th Edition IATF 16949 - Automotive Quality Systems Standard 10
