I have a measuring machine that measures up to 1000mm in length, but my traceable standard is only 400mm long. When I calibrate I align the standard parallel , start at the left side and measure every 10mm to check for accuracy deviations. I then move the scale to the right, overlapping approx. 20mm, align it parallel and measure from the left end of the scale (every 10mm) to the end at 400mm. Then again , covering the full 1000mm of measurement range.
My question is; how do I include the multiple use of this scale into my uncertainty calculation.
I think I need to include the following in my uncert calc. for each range; (in addition to repeatability, temperature effects, etc.)
What am I forgetting about (or don't know!) about staging a line scale standard like this?
0-400 mm
uncert of std.
400-780 mm
2x uncert of std
max error found in 0-400 mm range
780-1000 mm
3x uncert of std.
measurement uncertainty for measuring error in 0-400 mm
max error found in 400-780 mm range
measurement uncertainty for measuring error in 400-780 mm
Thanks to all!
0-400 mm
uncert of std.
400-780 mm
2x uncert of std
780-1000 mm
3x uncert of std.
Thanks to all!
