The large percentage of defects we're having are bent leads & cosmetic defects. I'm not exactly sure what do you mean with a one size fits all scheme but it seems like my problem is the opposite. We have multiple package types of ICs and each has its own criteria, which I think would be too much for an inspector to memorize as part of the semi-annual certification process.
I do have some pictures & drawings of defects on our work instructions but I think it is not enough. So your suggesion of having a database of pictures showing the defects is the way to go...but collecting these samples will require some work.
Maybe I'd look at our certification process which focused on written exams instead of actual assessment of their skills to find defects.
Morning – I have in the passed been involved in 100% inspection as a manager and a inspector, what I find during the inspection period you being to inspect in the grey areas and as you progress the human brain drifts, this acceptable grey area increases with volume.
An example you start with a component that is only just within the visual / dimensional tolerances, this of cause is acceptable, however as the inspection process moves on a second sample occurs only slightly worse than you passed early, however visually not that much different to the one passed, I have found the brain makes the decision to pass, as the inspection continues this “grey” acceptance standard drifts, until the point the inspector questions him / herself, at this point its to late for many reason to stop the process and retrace earlier passed components – the cause of this in most cases is the believe of failure and fear of management.
As commented at the start I have been in this situation as an inspector and management.
From your information I understand you manufacture IC’s for the electronics industry a couple of questions:
Do you manufacture to an international standard?
Do you supply to more than one customer?
If you supply to more than one customers our their comments / defective results similar?
Some corrective plans have been suggested in this thread, best solution is root cause review and achieve product of a known and accept standard.
The agreed standard should be discussed with the customer / s, I would use Physical visual samples if no profession photographs were available, these could be contained in there protective casings – provide your customer / s with near identical samples – this provides a known “base standard”.
If practical I would rotate inspectors, I’ve been there, after long periods of visual inspection on similar product, the brain starts to make its own standards, mainly moving further into the “grey zone”.
For information on Electronic standards review the following site
www.ipc.org , they provide a very detail range of publications for the whole industry
