ZLYDCOM said:If we make incoming inspection as one of the PFMEA item,how to describe the failure mode?
Does "inspector's mistake" right? or "material problem"?
I'm now confuse on it.
I need help!
Rea said:On page 39 of FMEA third edition under 10) Potential failure Mode it states "However, in preparing the FMEA, assume that incoming part(s)/material(s) are correct."
It also states that exception may be made.
So unless you have already identiified deficiencies in incoming part quality why would you include incoming in a PFMEA? Most companies cannot afford the cost of incoming inspection and work with their suppliers on a "ship to stock" basis.
To restate what Jim has saidRea said:On page 39 of FMEA third edition under 10) Potential failure Mode it states "However, in preparing the FMEA, assume that incoming part(s)/material(s) are correct."
So unless you have already identified deficiencies in incoming part quality why would you include incoming in a PFMEA? Most companies cannot afford the cost of incoming inspection and work with their suppliers on a "ship to stock" basis.
In addition to these, you might also have:Speaking from a customer perspective, I want suppliers to consider the ways in which the process--receiving inspection--might fail. There are basically four bad things that can happen:
- "Bad" material is accepted
- "Good" material is rejected
- Material is somehow misidentified or mislabeled
- Material is damaged after receipt
