Control Plan Entries - Outgoing Visual Inspection - What should be on a Control Plan?
Bobbinz
Dear All
There has been some debate here at work lately regarding what should be on a control plan, and I just wondered what people's opinions were.
Working in the semiconductor manufacturing industry we generally want controls on the C/P to be measurable using methods that have a robust MSA procedure. However, some stages such as manual visual inspection are generally subjective and thus don't really suit MSA practises. It has been decided therefore, that visual inspection should not be included on the C/P. However, others believe that visual inspection (particularly OVQ inspection) *is* a control as it, to some degree, protects the customer from recieving potentially defect product. Section 6 of the APQP Control Plan manual actually states that inspections are a valid form of control, but the manual only appears to refer to MSA of measurement and test systems.
Anybody care to add their views opinions?
Thanks for reading
BBz
ScottK
Not out of the crisis
Re: Control Plan entries
If one is using visual inspection as criteria for acceptance, how can it not be a control point?
Bobbinz
That is true, it is a control point, but the very subjective nature of it has deemed it inappropriate to many. Please note, the views described above are not my own, I am mediating! Hence the requirement for further input from the helpful Covers
You could perform an attribute agreement analysis to assess the repeatability and reproducibility of visual inspection.
Bobbinz
Re: OVQ Inspection
Oops sorry, thought it was a standard acronym, my bad. It is Outgoing Visual Quality
Marc
Re: OVQ Inspection
No problem - OVQ is an acronym I have not seen used before and I'm kinda nutty in wanting to be sure those of us who are not familiar with certain acronyms (myself included) know what they are.
Bobbinz
For some reason, my boss seems to be against R&R on manual inspection. Perhaps he needs convincing otherwise. I'm not sure why he's so against having manual inspection on the control plan, I think it is assumed it leaves too many "awkward question" invites from external auditors so he is trimming it in attempt to make it auditor proof. I assumed a customer would welcome an inspection on the C/P rather than leaving it out completely.
ScottK
Re: What should be on a Control Plan - Control Plan Entries
I'm in printing so visual quality is everything.
But you can quantify a lot of that if you choose to - missing print, smears, ink spatter, can all be measured and counted through various means. Color can even be measured with a spectrophotometer.
Now - back to things that are inspected just by eye....Isn't that what the "detection" number in the FMEA is for?
If there is a wide gap in perception of a visual defect then the detection number might be higher, which might trigger one to start quantifying some the "visual" items as preventive actions.
Re: What should be on a Control Plan - Control Plan Entries - Outgoing Visual Inspect
Dear All
Thanks for reading
BBz
The process of visual inspection--or any kind of inspection for that matter--is a measurement system. There are standards against which products are compared. While the idea should be to remove subjectivity as far as possible, it's not unusual for visual inspection to be less than 100% objective. That's one of the main reasons you should be doing comparisons as Miner suggested; you should know something about how subjectivity affects the process.
Simply dropping something from the control plan (and, presumably altering the PFMEA) won't make it go away.
A Prototype control plan FMEA and Control Plans 2
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
D All Dimensions listed on control plan FMEA and Control Plans 10
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
D Supplied Product on Control Plan - Lot ranging in 40,000 pcs per product FMEA and Control Plans 3
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 0
G Control Plan - Include the processes for each sub component? APQP and PPAP 2
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
M Dynamic Control Plan Draft - need review FMEA and Control Plans 2
Ashland78 IATF 16949 Control Plan Authorizations IATF 16949 - Automotive Quality Systems Standard 2
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
Rameshwar25 What is a Control Plan at "Material Level"? IATF 16949 - Automotive Quality Systems Standard 4
L Control Plan - Multiple Process Steps FMEA and Control Plans 8
W Purchased Part Control Plan (IATF 16949) FMEA and Control Plans 7
J VDA audit, control plan - My hair is almost gone now VDA Standards - Germany's Automotive Standards 5
Howard Atkins MSAs are now required on every feature of the control plan - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 13
Jeff Putman EQI Prelaunch Control Plan - Definition Customer and Company Specific Requirements 0
V How to Add Annual Revalidation requirements to Control Plan? FMEA and Control Plans 5
N Control plan references FMEA and Control Plans 6
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
J Functional group / area responsible on a Control Plan IATF 16949 - Automotive Quality Systems Standard 1
T Should Testing be a separate operation in the Control Plan? FMEA and Control Plans 5
M Annual Layout requirements for PPAP/Control Plan FMEA and Control Plans 6
T IATF 16949 Control Plan and Process Monitoring Requirement(s) IATF 16949 - Automotive Quality Systems Standard 1
J Why Control Plan Review needs to be Approved by the Customer IATF 16949 - Automotive Quality Systems Standard 1
B PFMEA and Control Plan Links APQP and PPAP 2
A Corrective Action Column in Control Plan and aligning PFD, PFMEA and Control Plan FMEA and Control Plans 6
M Control Plan MSA's - Pressure Gages IATF 16949 - Automotive Quality Systems Standard 2
S Family / Generic type of FMEA & Control Plan and Symbols FMEA and Control Plans 3
V Do I need to add everything on print to control plan? FMEA and Control Plans 1
H Control plan example format for CNC machining activities FMEA and Control Plans 3
M Mention "according to Work Instruction" in Control Plan FMEA and Control Plans 3
W Does TS16949 require MSA on all measurement systems in the Control Plan? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Software for linking Process Flow Diagram, Process FMEA and Control Plan APQP and PPAP 9
S Attribute G&R for all Visual Controls in Control Plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Any recommendations on software for managing the APQP, PPAP, PFMEA, Control Plan etc? Quality Assurance and Compliance Software Tools and Solutions 2
F What goes into a Control Plan? FMEA and Control Plans 1
J Tighter Tolerances than Control Plan FMEA and Control Plans 1
E Control Plan Contents - Part Number / Latest Change Level FMEA and Control Plans 2
R Recording Control Plan Changes Document Control Systems, Procedures, Forms and Templates 3
K Control Plan vs PFMEA Control Methods FMEA and Control Plans 1
